Is this set really not closed ? ?
  • Thread starter quasar987
  • Tags
    Closed Set
In summary, the conversation discusses the concept of closed sets in metric spaces and the difference between open and closed sets. It also clarifies the definition of balls in a metric space and how they relate to open and closed sets. The conversation ends with a clarification on the definition of B(r,x) in relation to open and closed sets.
quasar987
32
Is this set really not closed ?!?
Ok, consider the metric space [itex]\mathbb{R}^2[/itex] armed with the pythagorean metric [itex]d(x,y) = ||x-y||[/itex] and B, the closed ball of radius 1 centered on the origin: [itex]B = B_1(0) \cup \partial B_1(0)[/itex]. Now construct the metric space composed of this closed ball and the appropriate restriction on the pythagorean metric.
Now consider D, a closed ball centered on the origin but of radius r<1, and ask the question: is D closed in B? D is closed iff [itex]D^c = B \slash D[/itex] is open in B. But it is not, for consider a point on the border of B ([itex]x_0 \in \partial B_1(0)[/itex]). No ball with x_0 as center is contained entirely in B. Hence D is not closed in B.
Is that correct?!
No, it's not correct; D is closed in B. If B is your metric space, then the ball of radius s centered at x0 is defined as:
[tex]\{x\ \mathbf{\in B}\, :\, ||x - x_0|| < s\}[/tex]
They key part is the "[itex]\in B[/itex]" part. So a ball in B is the intersection of the ball in R² with the space B itself.
Thx AKG.
But then how would any set NOT be open?
G is open if for all x in G, there exists r>0 s.t. B(r,x) is in G.
But the definition of B(r,x) is all g in G such that d(x,g)<r. So for any r, B contains only elements of G, so B(r,x) is necessarily in G, making G open.
what the heck?!
I would appreciate help quickly. I leave for exam in 13 minutes exactly. *sweat*
At least there were no questions on open sets. phew.
No: if X is your metric space, then B(r,x) is all g in X such that...
very simply, in a metric topology. The set of things distance less than or equal to 1 from some given point would not be open in general.
Oh, of course!
what the heck?!
If G is the entire set, (as you say "the definition of B(r,x) is all g in G such that d(x,g)<r") then yes, it is open. The entire base set in a topological space is always both open and closed.
If you mean that G is a proper subset of some set X on which the topology is defined then "the definition of B(r,x) is all g in G such that d(x,g)<r." is not true. B(r,x) is all g in X such that d(x,g)<r.
Exactly.
FAQ: Is this set really not closed ? ?
What does it mean for a set to be "closed"?
In mathematics, a set is considered "closed" if it contains all of its limit points. This means that any sequence of points within the set will also have its limit point within the set. In other words, there are no points on the boundary of the set that are not included in the set itself.
How can I determine if a set is closed?
To determine if a set is closed, you can use the closure property, which states that the closure of a set is the smallest closed set that contains all of its points. If the closure of a set is equal to the set itself, then the set is closed.
What does it mean for a set to be "really not closed"?
If a set is "really not closed," it means that it either does not contain all of its limit points or it has points on its boundary that are not included in the set. This could also mean that the closure of the set is not equal to the set itself.
Can a set be "really not closed" and still be considered closed?
No, a set cannot be "really not closed" and still be considered closed. If a set is "really not closed," it means that it does not meet the criteria for being considered closed.
How does the concept of closed sets relate to topology?
In topology, the concept of closed sets is important because it allows for the definition of open sets. This allows for the study of mathematical properties and structures, such as continuity and convergence, without the need to define a specific metric for a given space.
