Is this solvable? Projectile motion
In summary, the problem involves standing at the top of a cliff and throwing a rock horizontally to determine the height of the cliff. The equation used is sy=uyt+1/2at^2, with an assumed time of 15 seconds and a calculated distance of 1103m. However, without knowing the angle of the throw, it is difficult to determine the exact height of the cliff. It is important to note that the initial vertical velocity is zero, and if two objects are dropped and thrown horizontally from the same height, they will take the same time to reach the ground.
amber87
You are standing at the top of a cliff and want to know how far it is to the bottom so you throw a rock as hard as you can horizontally over the edge of the cliff and time how long it takes before you hear it hit the bottom. Let us assume it takes around 15 seconds. How high is the cliff?
sy=uyt+1/2at^2
I'm stuck because there's just too many unknowns. I worked out 1103m from the equation above which from memory needs to be divided by sin theta which is also unknown. Can anyone help?
Your answer seems to be correct. The question is a little vague.
I think they mean that you throw the ball horizontally, which means that uy_0 = 0. (that's the initial velocity in the y axis).
That fact that you throw it forwards as hard as you can just enables you to assume that the ball would hit the ground, and not some slope of the cliff.
Tomer is correct.Because the ball is thrown horizontally the initial vertical velocity is zero.Looking at it differently if you drop an object from a certain height and at the same time throw a second object horizontally from the same height then both objects take the same time to reach the ground.If the second object is thrown at an angle to the horizontal the times will be different.Of course this is ignoring air resistance.
FAQ: Is this solvable? Projectile motion
Is projectile motion a solvable problem?
Yes, projectile motion is a solvable problem. It can be solved using mathematical equations and principles, such as Newton's laws of motion and the equations of motion.
What factors affect the solvability of projectile motion?
The factors that affect the solvability of projectile motion include the initial velocity, angle of launch, air resistance, and gravitational force. These factors can be taken into account when solving the problem.
Are there any limitations to solving projectile motion?
There are some limitations to solving projectile motion, such as neglecting air resistance or assuming a perfect vacuum. These assumptions may not accurately reflect real-life scenarios, but they can still provide a good approximation.
Can projectile motion be solved for any type of projectile?
Yes, projectile motion can be solved for any type of projectile, as long as the initial conditions, such as launch angle and initial velocity, are known. This includes objects thrown, launched, or dropped from a height.
How is projectile motion used in real life?
Projectile motion is used in various real-life applications, such as sports, military operations, and engineering. It is also used in physics experiments to study the motion of objects through the air.
