Is this steel structure stable/ready to build?
In summary, Frame shown in your sketch is unstable. If strong wind came from the left the whole construction would rotate clockwise. Frame shown in bus stop picture has a rigid frame with effective ground anchorage. You need to modify your frame so as to have similar ground anchorage. You should have your final design checked by a structural engineer. Wouldn't the weight be enough for it not to rotate? and it is also anchored with those two steel beams (there's no rotating mechanism at the bottom). Also the house sits about 3m to the left of the structure.This is as far as I can get with the expertise sadly, so any further opinion on what I just said is much appreciated. So as you have addressed the wind problem
Pastean
Hi,
My father has been dedicating a lot of his time to making our soon-to-be home as "rewarding" (I guess) and as nice as possible for when its done. The new side project would be this. It is supposed to be some rain-proof place for a bench/table outside.
There are going to be three (more or less if needed) structures like the one in the picture, parallel to each other, with some sort of material (haven't figured it out yet) to make a nice rain-proof spot for a bench or a table.
What inspired him:
My question to you is: does this structure look stable, ready to build? are there any improvements that can be done?
Neither of us work with CAD or software like this and our budget is quite limited for this project, so asking people around is pretty much all the expertise we're going to get.
Thank you.
Frame shown in your sketch is unstable . If strong wind came from the left the whole construction would rotate clockwise .
Frame shown in bus stop picture has a rigid frame with effective ground anchorage . You need to modify your frame so as to have similar ground anchorage .
You should have your final design checked by a structural engineer .
So as you have addressed the wind problem, should I assume that the materials could hold the structure as it sits right now? (no bending and such?)
The problem with this structure is that near the point where two steel tubes are anchored to the concrete foundation, very large local internal stresses will appear, due to wind from the left. That may have two consequences: (a) local stresses in the concrete would be so high that the concrete may develop cracks, and eventually the anchorage would fail; or (b) normal stresses in the tubes (near the anchorage) may exceed the yield stress for steel; as a result, the tubes would bend, and the whole construction (as mentioned in another comment above) would rotate clockwise (local buckling of the tubes may also occur).
Maybe something like this :
Put down some more concrete on the right hand side of base .
Bring the right hand end of the arch beam down to the level of the new concrete and arrange a firm anchorage . Either bury an extension of the beam deep in the concrete or use steel base plates and foundation bolts .
Remove all the struts as drawn . Replace with one simple strut .
Draw that out and we'll see if further work is needed .
I must stress though that whatever design you end up with has to be checked by a structural engineer for safety .
Replacing the steel cable by a steel bar would help as well. Don't underestimate wind.
You would end up with a stronger and simpler design if you reduced the radius of curvature of the arch beam .
Leave the left end where it is and pull the right hand end over onto the existing concrete base .
Note that the arch beam in that bus shelter is very well designed - if you could get somewhere near the same shape that would be ideal .
Related to Is this steel structure stable/ready to build?
1. How do you determine if a steel structure is stable and ready to build?
To determine the stability and readiness of a steel structure, several factors are taken into consideration. These include the structural design, material properties, environmental conditions, and loading conditions. Calculations and simulations are often performed to assess the structural integrity and ensure that the structure can withstand the expected loads. Physical tests and inspections may also be conducted to further verify the stability of the steel structure.
2. What are the common causes of instability in steel structures?
Some common causes of instability in steel structures include inadequate design, poor material quality, corrosion, and excessive loading. Structural flaws or errors in the design can lead to weak points in the structure, making it vulnerable to collapse. Poor quality materials can also compromise the integrity of the structure. Corrosion can weaken the steel over time, making it more susceptible to failure. Excessive loading, whether from external forces or improper use, can also cause a steel structure to become unstable.
3. How important is the foundation in ensuring the stability of a steel structure?
The foundation is a crucial component in ensuring the stability of a steel structure. It serves as the base that supports and distributes the weight of the structure. A strong and stable foundation is necessary to prevent the structure from shifting or settling, which can lead to structural instability. Proper soil testing and analysis are essential in determining the appropriate foundation design for a steel structure.
4. Can a steel structure be made more stable after it has been built?
In some cases, it is possible to improve the stability of a steel structure after it has been built. This can be achieved through structural modifications or reinforcements. However, it is always best to ensure the stability of a steel structure during the design and construction phases to avoid any potential risks or costly modifications in the future.
5. What safety measures should be taken during the construction of a steel structure?
During the construction of a steel structure, several safety measures should be taken to ensure its stability. These include proper bracing and temporary supports to prevent the structure from collapsing during construction, regular inspections of the structure and materials for any defects or errors, and following all safety codes and regulations. Proper training and supervision of construction workers are also essential to minimize the risk of accidents or mistakes that could compromise the stability of the structure.
  • General Engineering
  • Mechanical Engineering
  • STEM Academic Advising
