evinda
MHB
- 3,836
Hello! (Wave)
I want to show for the initial value problem of the wave equation
$$u_{tt}=u_{xx}+f(x,t), x \in \mathbb{R}, 0<t<\infty$$
that if the data (i.e. the initial data and the non-homogeneous term $f$) have compact support, then, at each time, the solution has also compact support.
I have thought the following:
The initial data are these, right?
$$u(x,0)=\phi(x) \\ u_t(x,0)=\psi(x)$$
The functions $f, \phi, \psi$ have compact support and so they are zero outside a bounded set $[-L,L]$.
The solution of the initial value problem is
$$u(x,t)=\frac{1}{2}[\phi(x+t)+\phi(x-t)]+\frac{1}{2} \int_{x-t}^{x+t} \psi(y) dy+\frac{1}{2} \int_0^t \int_{x-(t-s)}^{x+(t-s)} f(y,s) dy ds.$$
Let $t=T$ arbitrary.
Then
$$u(x,T)=\frac{1}{2}[\phi(x+T)+\phi(x-T)]+\frac{1}{2} \int_{x-T}^{x+T} \psi(y) dy+\frac{1}{2} \int_0^T \int_{x-(T-s)}^{x+(T-s)} f(y,s) dy ds.$$
We check when $u(x,T)=0$.
We have $u(x,T)=0$ if
From $3$ we get that $x<-L+s-T$ or $x>L+T-s$ and thus $x<-L$ or $x>L$.Thus the bounded set outside of which $u$ is zero is $[-L-T,L]$, right?
Or have I done something wrong? (Thinking)
Then
- $x+T, x-T \in \mathbb{R} \setminus{[-L,L]} \Rightarrow ((x+T<-L \text{ or } x+T>L)) \text{ and } (x-T<-L \text{ or } x-T>L)$
- $(x-T<-L \text{ and } x+T<-L) \text{ or } (x-T>L \text{ and } x+T>L)$
- $(x-T+s<-L \text{ and } x+T-s<-L) \text{ or } (x-T+s>L \text{ and } x+T-s>L) \text{ for } 0 \leq s \leq T$.
