MHB Is this theory regarding the graph and the square root valid?
The discussion centers on a method for finding square roots using a graph of the quadratic equation x^2 - 2x - 3. A participant claims to have discovered a technique to derive the square root of any number by substituting it into the equation. However, another contributor points out a logical inconsistency in the approach, noting that if x equals the square root of 3, it cannot simultaneously satisfy the equation derived from the substitution. This raises questions about the validity of the proposed theory regarding the relationship between the graph and square roots. Ultimately, the validity of the method remains contested within the discussion.
mathlearn
http://mathhelpboards.com/pre-algebra-algebra-2/find-value-squareroot-3-using-graph-drawing-suitable-straight-line-19973.html
greg1313 said:
Mathematics is a science and experimentation is a valuable tool. The first thing I did was to substitute $\sqrt3$ for $x$ in the given quadratic and observe the results. Get your hands dirty!
I guess I found a method to obtain the square root of any number using the above graph.
$x^2-2x-3$ What I did to find the square root of 3 was replace $x^2$ with the desired square root
$\sqrt{3}^2-2x-3=3-2x-3=-2x=0=y$
And check this out if we replace the $x^2$ of the formula of the formula to obtain a square root of any number
$\sqrt{7}^2-2x-3=7-2x-3=-2x+4=0=y$
Check the $x$ axis of the intersection point of the graph and the x axis
Is this theory regarding the graph and the square root really valid?
[graph]z0awzx3ity[/graph]
Mathematics news on Phys.org
Re: An amazing discovery regarding the graph and the square root
If [math]x = \sqrt{3}[/math] then [math]x^2 - 2x - 3 = (\sqrt{3})^2 - 2 \sqrt{3} - 3[/math]. You have to replace all the x's.
Also: [math]\sqrt{3}^2-2x-3=3-2x-3=-2x=0[/math] says that -2x = 0, but you originally had [math]x = \sqrt{3}[/math], which both can't be true.
-Dan
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
