Is this true about the emf in a closed circular wire?
In summary, the emf is defined as the potential difference between two points and is affected by the presence of an emf source, such as a battery. This means that the line integral of the Electric field around a closed path will not be zero due to the non-static nature of currents.
latentcorpse
1,444
the emf is defined as the potential difference between two points [itex]\varphi(\vec{r_1})-\varphi(\vec{r_2})[/itex].
ok so let's say we make a trip round a closed circular wire with a battery to keep the current flowing then r1=r2 and so no emf has been done - is this true and if so why?
The battery in general produces an emf. r1 does not equal r2 because you hit the battery on your walk around the loop. If r1=r2 you can't fit a battery in there.
I'm guessing you're talking about Kirchoff's rules? If you're talking about why the line integral of the Electric field around a closed path is not identically 0, it's because currents are not static.
i don't follow. i haven't covered kirchhoffs rules yet. why does r1 not equal r2, these are just vectors from the origin to the point we're at in the circuit so surely regardless of whether we do a lap or not its still the same position vector from the origin that descirbes the point?
When you walk around the loop, you will inevitably hit the battery or emf source. That source is like a discontinuity in your loop...when you "walk" over the emf source you need to add the voltage given off by the emf to your potential difference.
FAQ: Is this true about the emf in a closed circular wire?
What is EMF and how does it relate to closed circular wires?
EMF stands for electromagnetic force. In a closed circular wire, EMF is the force that drives the electrons through the wire, creating an electric current.
What factors affect the EMF in a closed circular wire?
The EMF in a closed circular wire is affected by the strength of the magnetic field, the speed of the electrons, and the resistance of the wire.
Can the EMF in a closed circular wire be measured?
Yes, the EMF in a closed circular wire can be measured using a voltmeter or by calculating the potential difference between two points in the circuit.
Does the direction of the EMF in a closed circular wire matter?
Yes, the direction of the EMF in a closed circular wire is important in determining the direction of the current flow. The right-hand rule can be used to determine the direction of the magnetic force on a moving charge, which is related to the direction of the EMF.
How is the EMF in a closed circular wire different from an open wire?
In an open wire, there is no complete circuit for the electrons to flow through, so there is no EMF. In a closed circular wire, the EMF is created by a continuous flow of electrons through the wire.
