Is this wrong or right? Simplify: -2^2 =-4
  • MHB
  • Thread starter OMGMathPLS
  • Tags
    Simplify
In summary, there is no difference between simplifying and solving in this case. The answer depends on whether you mean $-2^2$ or $(-2)^2$. When evaluating $-2^2$, the "2" should be squared before applying the negative, resulting in $-4$. However, when evaluating $(-2)^2$, the negative is applied to the entire expression within the parentheses, resulting in a positive value of $4$. Simplifying involves reducing an expression to its most basic form, while solving involves finding a final answer. It is important to remember the order of operations when evaluating expressions involving exponents.
OMGMathPLS
64
Because on the test the answer given back says the correct answer for -2^2 is -4. Is there a difference between simplifying and solving?
Mathematics news on Phys.org
In this case, there is no difference between simplifying and solving. And the answer of your question depends on whether you mean $-2^2$ or $(-2)^2$. I'm sure you are referring to the former, $-2^2$, in which the answer is $-4$. :D
But... how? Why is it not (-2)(-2)= +4
Hi OMGMathPLS,
Welcome to MHB! :)
As Rido12 wrote, this is technically correct. When evaluating $-2^2$ (no parentheses) you should square the "2" before you apply the negative. Think of it as $(-1)2^2$. This is kind of pedantic in my opinion with no context since potentially misleading notation is not good to use in practice, but it's important to always remember the order of operations.
Ok, thanks Jameson.
when you do $(-2)^2$ that is equal to (-2)(-2) which is 4. when you do $-2^2$ that is equal to -(2)(2) which is -4. make sense?
Simplifying: bringing it down to the lowest and most basic form
Solving: finding a final answer
How I teach my students is this: exponents "see" or "apply to" only the first thing down and to their left. If it's a parenthesis, then it'll apply to everything between that parenthesis and its matching parenthesis. Otherwise, it only applies to one symbol. The kind of expression for which $3^3-6^2$ is an example, is unambiguous and quite common; this particular expression's value is $3^3-6^2=27-36=-9$.
FAQ: Is this wrong or right? Simplify: -2^2 =-4
Is the answer to -2^2 equal to -4?
Yes, the answer to -2^2 is equal to -4. This is because when evaluating an expression with exponents, the exponent is applied first. So, -2^2 is equivalent to (-2)(-2), which is equal to 4. The negative sign outside the parentheses then makes the final answer -4.
Why is the answer to -2^2 negative when the exponent is even?
This is due to the rules of exponents. When an even exponent is applied to a negative number, the resulting answer will always be positive. However, in this case, the negative sign outside the parentheses makes the final answer negative.
Can -2^2 also be written as (-2)^2?
Yes, -2^2 can also be written as (-2)^2. This is because of the order of operations, where parentheses are evaluated first. So, (-2)^2 is equivalent to (-2)(-2), which is equal to 4. The negative sign outside the parentheses then makes the final answer -4.
Is -2^2 the same as -2*-2?
Yes, -2^2 is the same as -2*-2. This is because when multiplying two negative numbers, the result is always positive. So, -2*-2 is equal to 4. The negative sign outside the parentheses then makes the final answer -4.
Can the negative sign be moved inside the parentheses in -2^2?
No, the negative sign cannot be moved inside the parentheses. This is because the exponent rule states that when an even exponent is applied to a negative number, the result will always be positive. So, -2^2 is equal to -4, but (-2)^2 is equal to 4.
