zeebek
- 27
I have a feeling that for any n x n non-trivial matrix A, trace(A*A) is always positive.
Is it true?
Is it true?
Knowing whether trace(A*A) is always positive is important because it can provide information about the properties of the matrix A. For example, if trace(A*A) is positive, then A*A must be a positive definite matrix, which has many useful applications in mathematics and science.
The trace of a square matrix A is the sum of its diagonal elements. When A is multiplied by itself (A*A), the trace becomes the sum of the squares of the diagonal elements.
No, trace(A*A) is not always positive for any matrix A. It depends on the properties of the matrix A. However, if A is a square matrix, then trace(A*A) will always be a real number.
No, trace(A*A) cannot be negative. The sum of squares of real numbers is always positive, so trace(A*A) will always be greater than or equal to zero.
The eigenvalues of a square matrix A can be determined using the equation det(A - λI) = 0, where det() is the determinant function and I is the identity matrix. The sum of the eigenvalues is equal to the trace of A, or trace(A) = λ1 + λ2 + ... + λn. Therefore, if trace(A*A) is always positive, it can be concluded that all eigenvalues of A are also positive.
