Is \( U \) a Subspace of \( F[0,1] \)?
  • MHB
  • Thread starter Dethrone
  • Tags
    Subspace
In summary: I think I understand what you're trying to say. But, what if the zero vector is not contained in the subset?Then the subset is not a subspace of the original space.
Dethrone
717
Is the following a subspace of $F[0,1]$?
$U={}\left\{f|f(0)=f(1)\right\}$
First, it contains the 0 vector if you consider $f(x)=0$, which is 0 for all $x$. Now I'm not sure how to prove that it is closure under addition. Here's what I have so far:
If $f_1, f_2 \in U$, then $f_1(0)+f_2(0)=f_1(1)+f_2(1)$
but I'm not sure how I can draw any conclusion from this. Since the functions aren't the same, I can't really combine them.
I assume you are adopting the usual operations over the space of functions, that is, $$(\alpha f)(x) = \alpha \cdot (f(x)),$$ and $$(f_1 + f_2)(x) = f_1(x) +f_2(x)$$ for $f_1, f_2, f \in F[0,1]$ and $\alpha \in \mathbb{R}$ (this also assumes the underlying field is $\mathbb{R}$). In this case, you have to show that for every linear combination $$\alpha_1 f_1 + \alpha_2 f_2$$ of functions in that subset, that linear combination has the desired property.
Take it slow. You know that $(\alpha_1 f_1)(0) = \alpha_1 \cdot f_1(0)$, same for the index $2$. Using the usual operations, we know that $$(\alpha_1 f_1 + \alpha_2 f_2)(0) = \alpha_1 \cdot f_1(0) + \alpha_2 f_2(0).$$ Since both functions $f_1, f_2$ are in that subset, they satisfy the conditions $f_1(0) =f_1(1)$ and $f_2(0) = f_2(1)$. Therefore, $$\alpha_1 \cdot f_1(0) + \alpha_2 \cdot f_2(0) = \alpha_1 \cdot f_1(1) + \alpha_2 \cdot f_2(1).$$ Can we combine this into the operations in the vector space? Yes, we can: $$\alpha_1 \cdot f_1(1) + \alpha_2 \cdot f_2 (1) = (\alpha_1 f_1 + \alpha_2 f_2)(1).$$ Thus $$(\alpha_1 f_1 + \alpha_2 f_2)(0) = (\alpha_1 f_1 + \alpha_2 f_2)(1).$$ What happens if the desired property is that $f(1) = 1$? Would that subset, namely, $$\{ f \in F[0,1] \; | \; f(1) = 1 \},$$ be a subspace of $F[0,1]$? :)
Hmm, why are we taking linear combinations? That concept is introduced in the next section, so I'm not sure if that tool is available to use. But, can we also say this? (based off your proof) :D
Let $f_1, f_2 \in U$, then $(f_1+f_2)(0)=f_1(0)+f_2(0)=f_1(1)+f_2(1)$. Then $(f_1+f_2)(0)=(f_1+f_2)(1)$. Define $g(x)\equiv f_1+f_2$, then $g(0) =g(1)$ and so $g(x) \in U$. Therefore, it is closed under addition.
I just did this problem! No, because there are no zero vectors in the subspace since $f(1)=1$. But, I don't think I completely understand this. Is it because the zero function $0(x)$ is not contained in this subspace since $0(1)\ne 1$?
I thought you had that shortcut. :confused: You'll prove that a subset of a vector space is a subspace if and only if all linear combinations, using the operations of the original vector space, are contained within that subset.
You can, but you don't need to define $g$. It doesn't clarify anything. Since you don't have the subspace theorem, you would have to show all 8 properties of a vector space. :( Tedious work.
Yes, you are correct. The zero function, which is the neutral element of vector addition, does not belong to this subset. Addition will also not work for any two functions. Multiplication by a scalar will also jumble things up. :) Many ways to see this. Try them!
Hmm...I haven't learned that version of the theorem, it will be something to think about :D The one taught to me was that a subset of a vector space is a vector space if and only if the three properties are satisfied: 1) there is a 0 vector, 2) must be closed under vector addition, 3) must be closed under scalar multiplication.
But, I have another confusion. They say the zero vector must be contained for 1). If the subspace is of functions, how can you have vectors? Wait! Is it because "vectors" are defined to be elements of a vector space? Also, what do you mean by a "neutral element"? :D
I have some serious communication issues. :confused: That's what I was talking about. Those last two properties can be combined in one, which is showing for elements of the subset we have $\alpha_1 v_1 + \alpha_2 v_2$ belonging to the subset.
Yes, you are right! We call them vectors because they are elements of a vector space. :) Polynomials are vectors, too!
By neutral element I mean a vector $e$ such that, for all vectors $v$, we have $v+e = v$ and $v+(-v) = e$. :)
I see! This makes a lot more sense now. Thanks! :D
FAQ: Is \( U \) a Subspace of \( F[0,1] \)?
What is a subspace?
A subspace is a subset of a vector space that satisfies the properties of a vector space, such as closed under addition and scalar multiplication.
How do I determine if $U$ is a subspace of $F[0,1]$?
To determine if $U$ is a subspace of $F[0,1]$, you must check if it satisfies the properties of a vector space, such as closure under addition and scalar multiplication. You can also check if $U$ contains the zero vector and if it is closed under linear combinations.
What is the difference between a subspace and a vector space?
A subspace is a subset of a vector space that satisfies the properties of a vector space, while a vector space is a set that contains vectors and has operations of addition and scalar multiplication defined on it.
Can a subspace of $F[0,1]$ be infinite-dimensional?
Yes, a subspace of $F[0,1]$ can be infinite-dimensional. For example, the set of all polynomials in $F[0,1]$ forms a subspace, and it is infinite-dimensional.
Can a subspace of $F[0,1]$ contain non-polynomial functions?
No, a subspace of $F[0,1]$ must contain only polynomial functions since $F[0,1]$ is the set of all polynomial functions defined on the interval $[0,1]$. Any non-polynomial function would not be a member of $F[0,1]$ and therefore cannot be a subspace of it.
