Is uniform circular motion perpetual?
In summary, if you spin a pencil in space without gravity or air resistance, it will continue spinning indefinitely.
jaydnul
558
If i took my pencil to a place in space without gravity or air resistance and i spun it, would it spin forever? I mean its undergoing a centripetal acceleration, so energy has to come from somewhere to keep it spinning right? (and of course this is not meant to be an idea for perpetual motion, i know those are against the rules)
Things move for a long time in outer space not because they are always consuming energy, but because the vacuum of space offers no resistance to movement, unlike on earth. If you spin a pencil in space, the energy imparted in the initial spin is not diminished by any friction acting on the pencil due to its spinning motion. As Newton said, "A body in motion tends to stay in motion, unless acted upon by an external force."
Likes gracy
If nothing else happens - yep.
Nope. The input of energy occurred at the start when you spun it up.
This sort of perpetual motion is not against the rules ... it's one of Newton's Laws.
The prohibition is not against perpetual motion, it is against perpetual motion machines - the idea that you can get useful work out of something like this. The maximum amount of energy you can extract from the spinning pencil is the amount of work you did making it spin.
Donald Simanek has an excellent resource on these things.
http://www.lhup.edu/~dsimanek/museum/physgal.htm
... see the bit about rotations and wheels.
Hmm. I always thought a constant force was necessary to keep something constantly in circular motion even in absence of friction...
That's when you have something like a ball tied to a string and need a means of keeping the ball afloat in the air in a circular trajectory by applying a sufficient tension across the string while you stand on the surface of the Earth; this is a case of a controlled circular trajectory about some central point. The OP is instead talking about a situation where you given an initial spin to a pencil in deep isolated space; there are no subsequent external forces at work on the pencil hence nothing to disturb that initial spin.
Force is not energy. The centripetal force in uniform circular motion is perpendicular to velocity, so it doesn't do any work on the object.
I was just saying that there would be no force acting on it after it is released, yet it continues spinning..
yes.
reread steamking's post, post #2
particularly the last sentence :)
Dave
Likes 1 person
Perhaps it helps to think of circular motion as having two components, one tangential and the other radial.
A force is required to produce the radial component but since the radius is constant that force does no work.
No force is required to maintain the tangential component (there is no air resistance in space).
There's no net force acting on the entire pencil, so its center of mass isn't moving; the pencil is spinning in place.
There are forces acting on the ends of the pencil. It's a solid object so it resists stretching, bending, changing shape. Without these forces the tip and eraser end of the pencil would go moving off in different directions; with these centripetal forces they're pulled into circular motion around the center of the pencil.
However, these forces aren't doing any work because they're acting along the length of the pencil and the pencil is rigid so doesn't change its length.
Likes 1 person
The forces between the molecules in the pencil keep those molecules moving in a circular path instead of flying off in a straight line.
A ball tied to a string attached to a fixed point, and whirling around in a circle, eventually "spins down" because of air resistance (in the Earth's atmosphere) and energy losses in the flexing of the string at the attachment point. If you do this on the moon, you eliminate the air resistance, but the flexional losses remain. If you could come up with a way of supporting the string at the center in a way that does not involve any friction or flexing of the string, and do the whole thing in a vacuum, the ball would whirl around forever just like the pencil in space would spin forever.
Nugatory said:
However, these forces aren't doing any work because they're acting along the length of the pencil and the pencil is rigid so doesn't change it's length.
The pencil would continue rotating even if it wasn't rigid (which it isn't; there is no such thing as a truly rigid body).
The forces that hold the pencil together don't do any work on the pencil because they are internal rather than external forces. Internal forces that are subject to Newton's third law hold the pencil together but they can't change the pencil's total linear or angular momentum.
It's those internal forces that hold the pencil together that keep the pencil rotating.
What's been missing from the discussion so far is the concept of angular momentum. Angular momentum is a conserved quantity. An external torque must be applied to the pencil to change its angular momentum. You've ruled out that external torque in the original post, so in a Newtonian world, the pencil must keep on rotating forever to keep that angular momentum constant.
Likes 1 person
The spinning pencil does not perform circular motion: but all it points do. A small piece of pencil at distance r from the CM is held at that distance by internal forces acting among the molecules. These internal forces provide the centripetal force to the circular motion of that piece.
The whole pencil just rotates about its CM, with the angular speed you gave it initially. It will keep its angular momentum forever if no external torque acts on it.
You can make the pencil perform circular motion in the space by bringing it close to a massive body and give it the appropriate initial velocity for a circular orbit. Gravity would provide the centripetal force .
ehild
This discussion has been very informative. I had never before thought about the dynamics of circular motion where the center of mass is stationary.
I thank each and everyone of you! :)
There's no net force acting on the entire pencil, so its center of mass isn't accelerating. Mere movement doesn't require a net force.
Whatever forces are acting, no energy is 'consumed' or transferred if there is no movement in the direction of those forces (i.e. the string / pencil gets no longer or shorter). Work done is Force times Distance moved in the direction of the force.
Yes, of course you're right. This happens sometimes when I post before the second cup of coffee... Jd0g33, I hope you read what I meant to say ("accelerating") and not what I did say ("moving").
It would indeed spin forever, and according to Newtonian physics it would keep spinning at the same rate (as is seen with the conservation of angular momentum).
Things get a little weird when we bring relativity into the picture.
What happens is that the pencil is spinning (that is, since the velocity of the atoms are not all the same and keep changing in time), the pencil loses energy as gravity waves.
The rate that energy is being lost depends on how fast the pencil is spinning, so as it slows down, it is also losing energy more slowly. As time stretches on, the pencil never truly stops, but it slows down nearly to zero spin. This doesn't violate any conservation laws, since this angular momentum is transferred to the gravity field.
The same thing happens in classical electromagnetism, where charged electrons orbiting an oppositely charged nucleus lose energy as electromagnetic waves, and the electrons spiral into the nucleus in about a hundreth of a nanosecond. Of course, that's the classical theory. Quantum mechanicsally, this doesn't happen because the nature of an electron is (apparently) not to have a well defined position and momentum. There is a minimum energy the electron can have orbiting a nucleus, and this is known as the ground state.
Compared to the electromagnetic force, gravity is extremely weak, so it would take eons for the pencil to slow down appreciably.
So you are saying that a rotating object loses energy/momentum through "gravity waves", and a non-rotating object does not?
I thought that rotational motion is just a special case of linear motion. The difference being that a body in uniform circular motion is undergoing acceleration. So is it the acceleration of rotational motion that is the cause of the energy loss as gravitation waves?
That would indicate to me that there would be a similar energy loss of a linearly accelerating body due to the gravitational waves that you mention. Is this so?
That is right.
Right.
More specific, it is the variable quadrupole moment. A perfectly uniform ring could rotate without emitting gravitational waves, for example.
Right.
Thanks mfb, and quick reply too.
Jd0g33 said:
If i took my pencil to a place in space without gravity ...
Just to be sure you are clear on this, there IS no such place. There are places where gravitational attraction is miniscule, but there is no place where it is zero.
@jd0g33: was any of that any use?
No, it wouldn't.
First off, even if angular momentum was conserved (which it isn't; more below), the pencil would not keep spinning at the same rate. It's angular momentum, not angular velocity, that is conserved sans any angular momentum transfer.
A pencil is ideally a rigid body with one axis of symmetry. A rigid body that is not subject to external torques will only continue to rotate about the same rate, forever, if it is the axis of rotation is perfectly aligned with one of the body's principal axes. An object such as our ideal pencil has one principal axis along that axis of symmetry and an infinite number of principal axes normal to the symmetry axis. Getting the rotation perfectly aligned with one of those principal axes is an impossible task; it's a space of measure zero. An ideal pencil would tumble but with a constant angular momentum.
In reality, a pencil is a non-rigid body with no axes of symmetry. The rotation builds up internal stresses, and it's not perfect. The pencil heats up a bit and radiates this heat away. The pencil loses energy. This means the pencil's rotation will migrate to being about the axis with the largest moment of inertia.
The radiation almost certainly won't be spherically distributed. The asymmetry means that the radiation will transport angular momentum as well as energy from the pencil. The pencil's rotation rate will slowly slow down -- but not near as slowly as the puny gravitational radiation that results from general relativity.
@D H: I would expect that this process slows down the rotation initially, but it stops as soon as the axis of rotation is the largest principal axis of the pencil. Afterwards, it does not influence the rotation speed any more.
Accelerated dielectrics become polarized, and, being accelerated, must radiate. Accelerate conductors radiate, too. Anything spinning is accelerated, and so must radiate.
In the context of Newtonian physics, its angular momentum is conserved. In the context of general relativity, the angular momentum of the pencil plus the field(s) is conserved, though there can be transfer between the two.
And yes, because the pencil is made up of charged particles, there would be electromagnetic radiation too. Considering how weak gravity is, it would be interesting to see if the overall neutral pencil still loses more energy (in a given time) by electromagnetic radiation than gravitational radiation
Not necessarily, see the ring as an example (a disk would do the same).
If both positive and negative charges are completely homogeneous in the pencil, you have charges, but no electromagnetic radiation.
All this is splitting hairs compared with the fundamental misunderstanding illustrated, and dealt with, in the first few posts.
But I think I'll add this one to my puzzle set ... it reminds me of the discussion surrounding a question about how the G&T level in a glass changes as the ice melts.
Haha ya. As soon as someone pointed out that the centripetal force was acting perpendicular to the direction I stopped checking the thread...
  • #31
The distance covered is circular, so isn't there even some component of distance being covered in the direction of the centripetal force?
  • #32
No. The Centripetal force is constantly at right angles to the direction of motion.
Likes 1 person
  • #33
@violent corpse: sketch out the vectors and see.
  • #34
I understand. Thank you gentlemen!
FAQ: Is uniform circular motion perpetual?
What is uniform circular motion?
Uniform circular motion is the motion of an object moving in a circular path at a constant speed. This means that the object is moving at the same speed and in the same direction throughout its motion.
No, uniform circular motion is not perpetual. Perpetual motion refers to the idea of a motion that continues indefinitely without any external energy input. In uniform circular motion, the object is constantly changing direction, which requires a centripetal force to keep it moving. This force must come from an external source, so the motion is not perpetual.
What is the difference between uniform circular motion and perpetual motion?
The main difference between uniform circular motion and perpetual motion is that uniform circular motion requires an external force to maintain the constant speed and direction, while perpetual motion does not require any external force to continue indefinitely. In perpetual motion, the object would have to generate its own energy to keep moving, which is not possible according to the laws of thermodynamics.
Can an object in uniform circular motion ever stop?
Yes, an object in uniform circular motion can stop if the external force keeping it in motion is removed. This could happen if the centripetal force is no longer applied or if there is enough friction to slow down the object. In both cases, the object would stop moving in a circular path and would continue in a straight line.
What is the role of centripetal force in uniform circular motion?
The centripetal force is the force that keeps an object moving in a circular path. It is directed towards the center of the circle and is necessary to counteract the object's tendency to move in a straight line. Without the centripetal force, the object would continue in a straight line tangent to the circle.
