Is Using a Calculator Necessary for Solving Precalculus Problems?
  • Thread starter ECHOSIDE
  • Tags
    Calculator
In summary, the conversation revolves around the topic of whether or not to use a calculator for long and time-consuming arithmetic problems while studying Precalculus. Some argue that using a calculator is more efficient and practical, while others believe that doing calculations by hand can improve skills and minimize errors. It is suggested that using a combination of both methods may be the best approach. Additionally, a specific example problem is discussed and different methods of solving it are presented.
ECHOSIDE
I am making my way through a Precalculus text. It is not for a class, just independent study. I am doing every problem in the book. So far, I have done all of the problems without a calculator to better my arithmetic skills. This is frequently time consuming because the book isn't giving me "nice" numbers. I frequently need to calculate 8 and 10 digit numbers with long division and long multiplication.
I am finding that some of the problems require 10 minutes or more of arithmetic. When I am finished, I frequently end up with the wrong answer because of human error. When this happens, I re-work the problem from the beginning but will frequently make the same arithmetic error(s) the second and third times I work the problem.
I have a bit of a dichotomy.
If my arithmetic is as bad as it seems to be, I need more practice with it, not less. Thus it seems I should continue to work the problems out longhand. (Although it is frustrating and not fun.)
On the other hand, if the risk of human error introduced to the problem is unreasonable, perhaps I should approach the problems like the rest of my buddies and use a calculator.
I assume I am not the only person who has run into this decision. Do any of you have thoughts, experiences, or input?
Thanks!
Mathematics news on Phys.org
Never in real life will you ever have to do 8 digit long division by hand. On the other hand, you should be worried that it takes 10 minutes and you keep getting wrong answers. I'm pretty sure 4th graders can do it more quickly.
Example problems?
Calculating long multiplication and division for 8 and 10 digit numbers sounds a little excessive if you're trying to polish your precalc concepts.
Jack21222, perhaps I was unclear. I'm sorry about that.
Example problems?
Olivermsun, I can give you an example.
This problem took me at least 15 minutes to solve and check.
0.03x-0.02=0.2(x+0.03)
Maybe it shouldn't have taken me so long. I admit that I'm not great at math.
I'd say: YES, use a calculator! Calculating 8 digit long divisions by hand is madness, there are better things to put your time in.
Try to judge for yourself, if it's just a calculation like 72-4.5.2, then don't use a calculator, but if the calculation gets ugly, then there's nothing much to learn by doing evertything by hand.
I do respect your courage, though...
A lot of "hand" math depends on making the problem easier.
On this one, for example, you can eliminate some decimals by multiplying everything by 100. You could of course do it keeping the decimals in until the end, but sometimes doing it this way helps to minimize decimal place mistakes:
3x-2 = 20(x+0.03)
3x-2 = 20x+0.6
-2.6 = 17x
And at this point I don't see any reason not to use your calculator, although you could also learn to recognize that you can multiply by 5 to get rid of the remaining decimals :
-13 = 85x
-13/85 = x
which is a perfectly valid answer.
Nothing that can't be fixed up with a little practice. But again, make it easier not harder for yourself.
I like to do all my calculations by hand, also when it is frustrating, boring and too easy to make errors, although occasionally I make a check with a calculator. The effort is balanced with a better concentration while working on a problem, the search for better ways in doing calculations and in obtaining better precisions. There is always something to learn while doing hand calculations. Usually I compute also sines, cosines, tangents, square and cubic roots (!).
Strangely, after many years of this practice I found more mechanical to push buttons on a calculator then in doing computations in my head or on paper.
3x-2 = 20(x+0.03)
3x-2 = 20x+0.6
-2.6 = 17x
-13 = 85x
-13/85 = x
Olivermsun, your insight is brilliant - particularly your ability to get rid of the decimals in -2.6=17x! I will keep this in mind.
However, I'm afraid that in this case it has produced an erroneous result. x=-13/85 does not check. The only real solution to this equation is x=-103/85. Perhaps we could identify what caused your method to fail in this case, because I like your method a lot better.
Try and show the work, if possible.
Olivermsun's answer is correct, maybe you checked wrong -or- the book, etc. is wrong.
I'm providing a simple check
LHS
3x-2
3(-13/85)-2
-209/85
RHS
20(x+0.03)
20(-13/85+0.03)
20(-209/1700)
-209/85
LHS = RHS
-209/85 = -209/85
For the sake of typing out your answer---
LHS--> -479/85
RHS--> -2009/85
As you can see, they are not equal.
-103/85 looks like the answer to 0.03x-0.2=0.2(x+0.03) not 0.03x-0.02=0.2(x+0.03)
My approach to the problem:
0.03x - 0.02 = 0.2( x + 0.03 )
0.03x - 0.02 = 0.2x + 0.006
30x -20 = 200x + 6
(200 - 30)x = - 20 - 6
170x = - 26
x = - 26/170 = -13/85
I'm sorry, Olivermsun, you were correct!
I did not transcribe the problem properly.
Chronon, the error you suspect is the error I made when transcribing.
(embarrassment!)
Thanks!
You need to learn http://en.wikipedia.org/wiki/Trachtenberg_system" because the long multiplication and division are just too inefficient.
FAQ: Is Using a Calculator Necessary for Solving Precalculus Problems?
1. Should I use a calculator for every math problem?
It depends on the complexity of the problem and your personal preference. If the problem requires simple arithmetic, it may be faster and more accurate to use a calculator. However, if the problem involves more complex calculations or you enjoy solving math problems manually, you may choose not to use a calculator.
2. Is it cheating to use a calculator?
No, using a calculator is not considered cheating. In fact, many standardized tests and exams allow the use of calculators. However, it is important to understand the concepts behind the calculations and not solely rely on the calculator.
3. Can using a calculator make me dependent on it?
Using a calculator for simple calculations such as addition and subtraction may make you dependent on it. It is important to practice mental math and understand the concepts behind the calculations to avoid becoming too reliant on a calculator.
4. Are there any situations where I should not use a calculator?
There are certain situations where using a calculator may not be appropriate, such as in a test or exam where it is not allowed. Additionally, in real-life scenarios where quick estimations are needed, it may be more efficient to do mental math rather than relying on a calculator.
5. Can using a calculator affect my math skills?
Using a calculator for simple calculations may not have a significant impact on your math skills. However, it is important to continue practicing mental math and understanding the concepts behind calculations to maintain and improve your math skills.
