Is water level the same after an anchor is thrown from a boat?
In summary: Fnet=ρfluid displaced/mass of fluid displaced, so the mass of the water displaced by the anchor would be equal to the mass of the anchor.
jamesbiomed
76
(5) A person sitting in a boat floating on a small pond throws a heavy anchor overboard. Does the level of the pond rise, fall, or stay the same? Explain.
FB=mass of fluid displaced times g
Fnety=Fb-mg
Theoretically, the pond level should stay the same. For the boat/man system after the anchor toss, the force of gravity will be less, because the mass of the boat/man system is less without the anchor. The buoyant force since it is floating is equal to the weight of the fluid displaced. As the anchor is tossed from the boat, there will be a shift in the net force up in the positive y-direction (assuming up is positive) causing the boat to rise relative to the water, and a portion of the water once displaced by the boat to return. This will cause an overall drop in water level.
However, when the anchor is thrown in, it will sink, until it reaches the bottom, and its exact mass will displace the same mass of water, which will cause a rise in the pond level exactly the mass of the anchor.
...I wrote that based on my verbal understanding of buoyant force. But what I'm struggling with is exactly how buoyant force will affect the boat after the anchor is tossed. Like I said, it will rise so that the amount of fluid it displaces is less. But how much less? The buoyant force will decrease, because the mass of the water displaced will decrease. I know F net y=Fb-fg. So fg is going to decrease, which will cause F net y to increase. But Fb will also decrease. So how can I better explain this, and determine precisely if the amount displaced by the anchor will equal the change due to the boat being lighter?
Sorry for the length...
Consider the boat by itself (no anchor yet). If you put an anchor in the boat, how much additional water is displaced? (Consider Archimedes' principle.) Compare that to how much water is displaced by the anchor when it's just tossed into the water.
The additional water displaced--would be equal in mass to the added anchor. Does this mean we could set Fnet y =0?
Yes, when the anchor is put on the boat, the additional water displaced equals the mass of the anchor.
What about when the anchor is just put in the water directly?
Not sure what you mean. For something in equilibrium, such as the floating boat, Fnet = 0.
The mass of the water displaced by the anchor will equal the mass of the anchor for sure.
Okay, I wasn't thinking right about the boat being equilibrium.
I think knowing this, I should be able to conclude it.
Thanks a lot for the help!
Really? Why do you think that?
James this would mean the mass of an aluminum anchor would have the same mass as that of a lead anchor. A "water anchor" would have the same mass as the water it displaced.
You see where the good Doctor is leading you...
The water displaced is equal to the VOLUME of the anchor.
Archimedes Principle, Fbuoyant = ρliquidVg
Related to Is water level the same after an anchor is thrown from a boat?
1. What causes the water level to change after an anchor is thrown from a boat?
The water level changes after an anchor is thrown from a boat due to the displacement of water by the anchor. When the anchor is thrown, it sinks to the bottom of the body of water, displacing a certain volume of water. This displacement causes the water level to rise.
2. Will the water level eventually return to its original level after the anchor is thrown?
Yes, the water level will eventually return to its original level after the anchor is thrown. This is because the water that was initially displaced by the anchor will eventually flow back into the space left by the anchor, causing the water level to gradually decrease.
3. Does the weight of the anchor affect the change in water level?
Yes, the weight of the anchor does affect the change in water level. Heavier anchors will displace more water and therefore cause a bigger change in water level compared to lighter anchors.
4. Can the water level change be measured after an anchor is thrown?
Yes, the change in water level can be measured after an anchor is thrown. This can be done by using a measuring tool, such as a ruler or a measuring tape, to determine the difference in water level before and after the anchor is thrown.
5. Does the shape of the anchor affect the change in water level?
Yes, the shape of the anchor can affect the change in water level. An anchor with a larger surface area will displace more water and cause a bigger change in water level compared to an anchor with a smaller surface area. The shape and design of the anchor can also affect how quickly the water level returns to its original level.
