Is weak isospin conserved by all interactions?
In summary, there is some confusion about whether weak isospin is exactly conserved or sometimes not conserved. Some argue that it is not conserved by any interaction, while others point out that it is an exact symmetry before electroweak symmetry breaking and therefore must be conserved. The issue becomes more complicated after symmetry breaking, with some claiming that the Higgs field being an isospin doublet causes non-conservation of isospin, while others argue that the interaction terms in the Lagrangian still conserve isospin. Additionally, it is noted that the electromagnetic interaction does not violate weak isospin, but the photon is not an eigenstate of weak isospin. Despite the confusion, it is generally agreed
metroplex021
151
Hi people: I keep reading one day that weak isospin is exactly conserved by all interactions; other days that sometimes weak isospin is *not* conserved. Can anyone clear this one up?!
Ask there for processes that violate the conservation?
Maybe some BSM models violate it, no idea, the standard model does not as far as I know.
Edit: Okay, this is wrong, see Bill_K.
Edit2: It is more complicated than a single yes/no answer, see later replies.
Quoting from this Google book:
The weak isospin is not conserved by any interaction... The left-handed components of all elementary fermions are assigned weak isospin 1/2. The right-handed components have Tw = 0. The non-conservation of weak isospin is already apparent in the fact that, with the possible exception of the massless neutrino, there is no particle with a definite handedness and therefore with a defined weak isospin.
Aargh! I don't understand... why would we have even introduced isospin symmetry if it were not conserved by any interaction?! Isn't the above phenomenon more indicative of parity violation than anything else?
Surely the issue is a little more subtle? If we write down the Standard Model Lagrangian before electroweak symmetry breaking, there is an exact SU(2)_isospin symmetry. Any process described by this Lagrangian should conserve weak isospin, period.
Yes, the gauge symmetry is then "spontaneously broken," but isn't it true that this is something of a misnomer and symmetries can't actually be "broken", only "hidden"? After spontaneous symmetry breaking, the vacuum is not invariant under weak isospin rotations, and so the particle spectrum does not consist of particles with definite weak isospin. But as far as I know that doesn't mean that weak isospin isn't conserved, contrary to what Bill_K's quote implies.
For example, consider a 1D double-well potential with an ##x \to -x## parity symmetry, and let the barrier between the two wells be essentially infinite. This system will exhibit "spontaneous breaking" of the parity symmetry: you can construct energy eigenstates that localized to one well only, and so are not parity eigenstates. Nevertheless parity is still conserved in this system.
Likes 1 person
Spontaneous symmetry breaking is not what's involved. As the book points out, any interaction that fails to preserve handedness, fails to conserve weak isospin.
Also, the electromagnetic interaction disconserves weak isospin, the photon being a mixture of Tw = 1 and Tw = 0.
Isospin is exactly conserved before symmetry breaking but it is not conserved after symmetry breaking because the Higgs field is not an isospin singlet and it forms a condensate. Particles are moving through this condensate at all times and interacting with it. Why then introduce the weak isospin at all as a symmetry, someone asked?
That's the only way to renormalize the weak interaction correctly.
The Higgs field is chosen to be an isospin doublet specifically to guarantee that the interaction term eR v EL = (singet) (doublet) (doublet) comes out to be invariant under isospin, and consequently conserves isospin. The vacuum state spontaneously breaks the symmetry, but that's unrelated to the effect of the interaction term with fermions.
So how do you reconcile this claim with the fact that if you write down the Standard Model Lagrangian before electroweak symmetry breaking, weak isospin is an exact symmetry and so must be exactly conserved?
Surely spontaneous symmetry breaking is at the heart of the matter here. Before electroweak symmetry breaking, the mass term for the electron (say) is actually a three-particle interaction between the left-handed electron, the Higgs doublet, and the right-handed electron. So the electron can change from left-handed to right-handed as long as it emits a Higgs boson, which carries away the conserved weak isospin. Here is an interaction that changes the handedness of an electron but manifestly conserves isospin.
If you write down the Lagrangian after spontaneous symmetry breaking things are more confusing, to me. Then there is an electron mass term that seems to violate weak isospin. There is also an electron-Higgs interaction term that violates weak isospin. But if you add these terms together the sum conserves weak isospin.
I think the electromagnetic interaction definitely doesn't violate weak isospin. Electromagnetism is the unbroken part of weak isospin and weak hypercharge; how can it break weak isospin or weak hypercharge?
It's true that the photon isn't an *eigenstate* of weak isospin. But despite the claims of the book you cited, I don't see how this proves anything about whether weak isospin is conserved. A spontaneously broken symmetry isn't manifest in the particle spectrum, but the corresponding current is still conserved.
Bill_K had it in #6, but maybe the implication needs to be expanded. If you have, e.g., an electron in your hand, it is not in an eigenstate of weak isospin.
I am a bit confused by this post. Is the weak isospin conserved before symmetry breaking? if not, then what is the conserved charge associated with [itex] SU(2)_L [/itex]? and why is it a useful quantity? and if it is, then how does symmetry breaking violate that? and how is the electron not having a defined chirality different before and after symmetry breaking?
I am getting confused with the isospins...
What kind of isospin are we talking about? The SU(2) of the SM is broken by the Higgs mechanism...
The SU(2) isospin which appears in the strong sector is conserved by strong interactions (in the limit of massless quarks) and is broken (except for the 3rd component) by electromagnetic...
I am talking about the weak isospin. I am not sure how post #6, which says that symmetry breaking is not involved, is consistent with #8, which looks like the Higgs breaks this symmetry. If someone can write some math and explain this.
About the hadronic isospin - since you mentioned that, I think the requirement is that the quark masses are equal, not necessary zero.
The weak isospin is not conserved only if you mix the left-right components in the Lagrangian. That's because those two by themselves transform differently (the one as a singlet and the other as a doublet).
I don't understand why that book says that the weak isospin is not conserved - it is not after the SSB and because of the Higgs vev (or in other words because the fermions are massive) . The force bosons (W,Z,gamma) appear only after the symmetry breaking and so you can say that those interactions (weak and em) don't preserve this symmetry...the strong interactions still do (since they don't couple left to rights)
Electroweak unification is based on exact [itex]SU(2) \times U(1)[/itex] symmetry which leads to (on shell) conserved iso-spin current and time independent charges. Beaking the group spontaneously simply means there exist some charges [itex]Q_{a}[/itex] such that [itex]Q_{a}| 0 \rangle \neq 0[/itex], but this DOES NOT mean [itex]dQ_{a} /dt \neq 0[/itex].
Likes ChrisVer
But...what I find in wikipedia(Weak isospin, the second paragraph) is that The weak isospin conservation law relates the conservation of T3; all weak interactions must preserve T3. It is also conserved by the other interactions and is therefore a conserved quantity in general. (Weak isospin is usually given the symbol T or I with the third component written as Tz, T3, Iz or I3.[1]).
So I am confused again...
I think one needs to distinguish between the "weak isospin" (##T##, ##\vec{T}##, ##I##) and "third component of the weak isospin" (##T_3##, ##I_3##). The first one is apparently what this book is referring too, while the conservation law from wikipedia is about the latter one (note the next sentence after your quote: "For this reason T3 is more important than T and often the term "weak isospin" refers to the "3rd component of weak isospin".").
Sorry, I didn't see that difference. Thanks to point it out.
As The_Duck said, "the electron can change from left-handed to right-handed as long as it emits a Higgs boson, which carries away the conserved weak isospin" and "the vacuum is not invariant under weak isospin rotations".
IOW, our vacuum contains a Higgs condensate, which you may visualize as the ability to consume without a trace, or supply "invisible" Higgs bosons.
FAQ: Is weak isospin conserved by all interactions?
1. What is weak isospin?
Weak isospin is a fundamental property of subatomic particles that describes their interaction with the weak nuclear force. It is analogous to electric charge, but it applies specifically to the weak interaction.
2. How is weak isospin conserved?
Weak isospin is conserved in interactions involving the weak nuclear force, such as beta decay and neutrino interactions. This means that the total weak isospin of the particles involved in the interaction remains the same before and after the interaction.
3. Is weak isospin conserved by all interactions?
No, weak isospin is only conserved by interactions involving the weak nuclear force. It does not apply to interactions involving the strong or electromagnetic forces.
4. What happens if weak isospin is not conserved?
If weak isospin is not conserved, it would indicate a violation of the laws of conservation of energy and momentum. This would have significant implications for our understanding of the fundamental laws of physics.
5. How is weak isospin related to other quantum numbers?
Weak isospin is related to other quantum numbers such as electric charge and flavor. In fact, it is often combined with the third component of weak isospin to form a larger quantum number known as weak hypercharge, which is conserved by all interactions including the weak force.
