MHB Is Weak Stationarity of Y_k Achievable in AR(1) Process?
The discussion centers on the weak stationarity of the sequence \(Y_k = X_{a_k}\) derived from an AR(1) process defined by \(X_t = bX_{t-1} + e_t\), where \(e_t\) is a zero-mean error term with constant variance. Weak stationarity requires that the mean and variance of the process remain constant over time. Initial insights suggest that since the mean and variance of \(e_t\) do not change, this may indicate weak stationarity. However, further analysis is needed to confirm that the expectation of \(X_t\) is finite and independent of time, which could complicate the conclusion. The discussion emphasizes the need for a deeper understanding of the definitions and properties related to weak stationarity.
fireb
Consider AR(1) process \(X_t=bX_{t-1}+e_t\)
where \(e_t\) with mean of 0 and variance of \(\sigma^2\)
and |b| <1
Let \( a_k \) be a recursive sequence with \( a_1 \) =1 and \( a_{k+1} = a_k + P_k +1\) for \( k = 1, 2 ,...,\) where \(P_k \) is Poisson iid r.v with mean = 1
also, assume \(P_t\) and \(X_t\) are independent.
Is \(Y_k\)= \(X_{a_k}\) for k =1,2,... weakly stationary?There arent any similar problems in the my textbook and i have no clue how to begin
Im not looking for a straight answer, just something to point me in the right direction.
Thanks in advance
and |b| <1
Thanks in advance
Hi
I have some experience with AR but don't claim to be an expert or provide you with a correct solution. I can't post links yet...
According to a basic definition of weakly stationary (google wikipedia and weakly stationary) we need to see whether the mean and variance of the AR model changes over time. If it does, then the process is not weakly stationary. From your definition above the variance and mean of \(e_t\) is not modified and does not change over time. Whilst I cannot state or be confident that this is the answer, my hint would be that this points to weakly stationary.
However according to section 4.1 (google weakly stationary definition and see the result from ohio state) you need to show the expectation of \(X_t\) is finite and does not depend on t (which I don't think it does but this is where the problem may lie)
Hope this helps, again this is not the correct solution just some hints.
Cheers
The standard _A " operator" maps a Null Hypothesis Ho into a decision set { Do not reject:=1 and reject :=0}. In this sense ( HA)_A , makes no sense. Since H0, HA aren't exhaustive, can we find an alternative operator, _A' , so that ( H_A)_A' makes sense? Isn't Pearson Neyman related to this? Hope I'm making sense. Edit: I was motivated by a superficial similarity of the idea with double transposition of matrices M, with ## (M^{T})^{T}=M##, and just wanted to see if it made sense to talk...
  • · Replies 175 ·
26K
