Is y = | x | - 2 Symmetric About the x-axis, y-axis, or Origin?
In summary, the graph is symmetric about the y-axis if and only if m is positive, and the graph is symmetric about the x-axis if and only if m is negative.
mathdad
1,283
Test for symmetry about the x-axis, y-axis and origin.
y = | x | - 2
What are the rules for testing for symmetry?
Mathematics news on Phys.org
On this forum you are supposed to show an attempted solution or at least describe the difficulty. Surely you can plot the first graph: there is nothing that requires ingenuity about it.
In general the equation f(|g(x,y)|) = 0 for any functions f and g is equivalent to the following:
\left\{\begin{aligned}f(g(x,y))&=0\\g(x,y)&\ge0\end{aligned}\right.\quad\text{or}\quad
\left\{\begin{aligned}f(-g(x,y))&=0\\g(x,y)&<0\end{aligned}\right.
To make |x + y| = 2 a special case of f(|g(x,y)|) = 0 we define f(x) = x - 2 and g(x,y) = x + y; then f(|g(x,y)|) = 0 is |x + y| - 2 = 0. According to the statement above, it is equivalent to
\left\{\begin{aligned}x+y-2&=0\\x+y&\ge0\end{aligned}\right.\quad\text{or}\quad
\left\{\begin{aligned}-(x+y)-2&=0\\x+y&<0\end{aligned}\right.
So you need to find the set of (x, y) that lie on the line x+y-2 = 0 and also satisfy x + y >= 0, and take the union with the set of (x, y) that lie on the line x+y+2 = 0 and also satisfy x + y < 0.
I changed the question. Forget the graph. What are the rules for testing for symmetry?
Forget the graph.
why? ... easiest way to check symmetry is by viewing the graph.
If you are going to reply using textbook jargon, then what's the point of asking for guidance? I changed the question. What are the rules for symmetry?
y = | x | - 2
-y = | x | - 2
Not symmetric about the x-axis.
y = | -x | - 2
y = x - 2
Not symmetric about the y-axis.
-y = | -x | - 2
-y = x - 2
Not symmetric about the origin.
Let:
\(\displaystyle f(x)=y=|x|-2\)
We find:
\(\displaystyle f(-x)=|-x|-2=|x|-2=y=f(x)\)
Thus, this function is symmetric about the $y$-axis. No further tests for symmetry are needed. :D
I thought the | -x | = x.
Does | x | = x?
Are you saying that y = | x | - 2 means y = x - 2?
Does | x | = x?
We can correctly state:
\(\displaystyle |x|=|-x|\)
But, we can only state:
\(\displaystyle |x|=x\)
if:
\(\displaystyle 0\le x\)
Or we can state:
\(\displaystyle |x|=-x\)
if:
\(\displaystyle x<0\)
How is | x | = | -x |?
- - - Updated - - -
Absolute value equations are tricky.
One way to show this is to think of the definition:
\(\displaystyle |x|\equiv\sqrt{x^2}\)
And so we have:
\(\displaystyle |-x|=\sqrt{(-x)^2}=\sqrt{x^2}=|x|\)
Another way to think of this is to view |x| as the distance on the number line between the origin (0) and x (the magnitude of x). Then, we observe that for all real x, -x is the same distance from the origin, even though it's on the opposite side of the origin.
This will take more thinking on my part. Check out the other symmetry post. Right or wrong?
Consider the function:
\(\displaystyle f(x)=m|x-h|+k\)
This is much like the vertex form for a quadratic. The vertex is at:
\(\displaystyle (h,k)\)
The axis of symmetry is the vertical line:
\(\displaystyle x=h\)
If:
\(\displaystyle 0<m\)
then the graph opens upwards, and the range is:
\(\displaystyle [k,\infty)\)
But if:
\(\displaystyle m<0\)
then graph opens downwards, and the range is:
\(\displaystyle (-\infty,k]\)
The magnitude of m will determine how "skinny" the graph is...the greater the magnitude, the skinnier the graph.
Here is a graph with sliders so that you can see the effect the parameters have:
[DESMOS=-10,10,-10,10]y=m\left|x-h\right|+k;k=0;h=0;m=1[/DESMOS]
Your knowledge of math is cool.
FAQ: Is y = | x | - 2 Symmetric About the x-axis, y-axis, or Origin?
What is a "Test for Symmetry"?
A "Test for Symmetry" is a method used in science to determine if an object, system, or function exhibits symmetry. Symmetry is a property of nature where an object or system is unchanged when certain transformations are applied to it, such as reflection, rotation, or translation.
Why is it important to test for symmetry?
Testing for symmetry can help scientists understand the underlying structure and organization of an object or system. It can also provide insights into the physical laws and principles that govern the behavior of the object or system.
What are some common examples of symmetry in nature?
Some common examples of symmetry in nature include the symmetry of snowflakes, the bilateral symmetry of animals, and the radial symmetry of flowers and other plants.
How is symmetry tested in science?
In science, symmetry is typically tested by applying specific transformations to an object or system and observing if the resulting object or system remains unchanged. This can be done through mathematical calculations, experiments, or observations.
What are the benefits of using symmetry in scientific research?
Using symmetry in scientific research can help simplify complex systems and make them easier to analyze. It can also provide a deeper understanding of the fundamental principles that govern the natural world, leading to new discoveries and advancements in various fields of science.
