Island of Stability: Answers to Questions
  • Thread starter Lazernugget
  • Tags
    Stability
In summary: I'm not an expert on the subject, but that's what wikipedia says.Thanks!In summary, Element 126 supposedly if it had 126 of each nucleon particle, (protons and neutrons) would mean it would be stable, but why is element 126 supposed to be super special, because it would be heavy+stable or what? According to the Shell Model, having a nucleus with 126 protons is beyond what we've observed to date, but would be more stable than its neighbors, provided it had a suitable number of neutrons as well.
Lazernugget
52
Okay, so even though I really don't need to, I do a LOT of research on astronomy, physics, math, etc. I was doing research on the extended periodic table, and super heavy unstable elements. I was quickly turned to the Island of Stability, and I get the theory but have a few questions.
1. Element 126 supposedly if it had 126 of each nucleon particle, (protons and neutrons) would mean it would be stable, but why is element 126 supposed to be super special, because it would be heavy+stable or what?
2. (This is a bit off topic) What does the number left of an element mean? (I'm only 11, so this may seem like a stupid question) for example what's the 234 in 234U ?
3. Could someone explain why The Bohr Model shows difficulty for existence (In elements) Beyond 137?
Thanks,
Lazernugget :D
Q1. - A nucleus that large would need a lot more neutrons than protons to have any hope of stability. For example, element 110 isotopes range from 267 to 273 nucleons (157 to 163 neutrons).
Q2. - 234 is total number of nucleons (92 protons + 142 neutrons).
Lazernugget, A very successful model for the nucleus is the single particle shell model in which each nucleon is considered to move independently within a background field produced by all the others. It predicts that nuceons as they are added to the nucleus will occupy well-defined orbitals until a closed shell is completed, very much like the way that electrons fill orbital shells in an atom. The shell model further predicts that a nucleus with exactly the right number of protons or neutrons to complete a shell will be exceptionally stable. The number of nucleons required for this are called magic numbers and have the values 20, 50, 82, 126, etc.
A nucleus with 126 protons is beyond what we've observed to date, but would be more stable than its neighbors, provided it had a suitable number of neutrons as well. For heavy nuclei, the required ratio of neutrons to protons is about two to one.
In answer to the third question, the Coulomb field that surrounds the nucleus is predicted to become strong enough at Z ≈ 137 to cause pair production, and therefore nuclei this heavy would likely decay by capturing virtual positrons from the pairs.
Thanks, these are great answers, but again, Element 126 supposedly if it had 126 of each nucleon particle, (protons and neutrons) would mean it would be stable, but why is element 126 supposed to be super special, because it would be heavy+stable or what?
The Coulomb repulsion between the protons inside the nucleus makes it impossible to have a nucleus with 126 protons and only 126 neutrons.
Those magic numbers are predicted and explained by the Shell Model as posted before. It makes that all nucleons are paired and all quantum mechanical shells are closed. The binding energy between the nucleons is then sufficient to keep all of them together. The mass has nothing to do with being stable or unstable.
I don't know why it's an island of stability and the nuclei before the island are so unstable.
It looks more like 3 to 2.
I think "stability" in this case means that it doesn't decay quite as fast as it would otherwise, right?
At least that's what wikipedia says here: http://en.wikipedia.org/wiki/Island_of_stability
Lifetimes in the order of seconds I thought. But it's still an anomaly which I can't explain, but my first guess is deformation. I could ask one of my professors after my exams.
What are you saying here exactly? Your first guess for what is deformation?
Such very exotic nuclei are probably very deformed and that's why the nuclei surrounding the island of stability are very unstable.
IIRC, there's some indication that those 'magic numbers' may not apply as strictly to 115+ region, as the many nucleons can arrange themselves non-spherically...
A bit like transition elements' electrons shuffle into unexpected configurations...
These numbers shift and this can be calculated using advanced Hartree-Fock methods. The results are shown in a Nilsson diagram like http://ns.ph.liv.ac.uk/~esp/nuclear/WS/Nilsson.gif The beta stand for the ratio between major and minor axis or the other way around.
Related to Island of Stability: Answers to Questions
What is the Island of Stability?
The Island of Stability is a theoretical concept in nuclear physics that refers to a region of the periodic table where elements with extremely long half-lives are predicted to exist.
Why is the Island of Stability important?
The existence of the Island of Stability would have significant implications for the understanding of nuclear structure and the stability of elements. It could also potentially lead to the discovery of new elements with unique properties.
How is the Island of Stability predicted?
Scientists use mathematical models to predict the stability of different nuclei. The theory suggests that when an atom contains a specific number of protons and neutrons, it will be much more stable and have longer half-lives than surrounding elements.
Has the Island of Stability been discovered?
As of now, no elements in the Island of Stability have been confirmed or discovered. However, some recent experiments have shown evidence for the existence of some isotopes with longer half-lives than previously predicted, giving support to the theory.
What are the challenges in studying the Island of Stability?
Since the elements in the Island of Stability are predicted to be extremely heavy and unstable, they are difficult to produce and study. Additionally, the short half-lives of these elements make it challenging to obtain accurate data about their properties.
