Isoceles triangle in absolute geometry
In summary, the interior point on a chord is also interior to the circle containing the chord. My proof would be complete if I could show that an angle created by the interior point on the chord is always smaller than the angle created by the circle.
ness9660
35
Im working to prove that an interior point on a chord is also interior to the circle containing the chord. I've got the entire proof almost finished and laid out, however I am stuck on one part. My proof would be complete if I could show this:
Given an isoceles triangle, in absolute geometry (no parallel postulate, sum of triangle <= 180)
http://img114.imageshack.us/img114/9844/isonj2.jpg
For an arbitrary point P, interior to segment AC. Prove that segment PB is always less then AB=CB.
I establish that since P is interior to AC, P will never equal A or C. From there I've been trying to establish that angle A or C will always be smaller then the angle created by P, so that by the scalene inequality side AC or BC will always be larger (since they correspond to angles created by P).
However I cannot figure out how to make a general proof for this in absolute geometry, can anyone offer any insight?
You can't prove it- it's not true. Consider an is triangle on the surface of a sphere: One vertex at the "north pole", the other two on the "equator". The length of any line segment through the "north pole" to the "equator" interior to the triangle has length equal to the two sides.
I see where the lengths would be equal for a sphere but not this case for the circle.
Here's what I'm thinking: In your original triangle, you start with a 60 degree angle for both A and C. Whenever you draw the line PB, in essence you're making a new triangle. Whenever you do that, you take some of the degrees away from what was angle B in your original triangle. Angle P must make up for that loss in degrees. So, angle A=60; B=60-x; P=60+x. I don't think that's really a proof, but I don't know what else to say!
The question was about proving that an line segment passing through the vertex of an isosceles triangle must be shorter than the two sides, in absolute geometry. My point is that there is a counterexample to that in spherical geometry so it cannot be true for general absolute geometry.
Doesn't spherical geometry have sum of triangle >= 180 degrees?
Thanks, office shredder, I didn't notice that "sum of triangle <= 180". Okay, so his version of "absolute geometry" does includes hyperolic but not elliptic. That's often done since elliptic geometry does not satisfy the "two points determine a line" axiom. My "counter-example" doesn't work in this case.
If I Understood The Problem...
  • pythagoras.doc
Related to Isoceles triangle in absolute geometry
1. What is an isosceles triangle in absolute geometry?
An isosceles triangle in absolute geometry is a type of triangle where two sides are equal in length. This means that the two angles opposite the equal sides are also congruent.
2. How is an isosceles triangle different from an equilateral triangle?
An isosceles triangle has two equal sides, while an equilateral triangle has three equal sides. Additionally, in an isosceles triangle, only two angles are equal, while in an equilateral triangle, all three angles are equal.
3. What are the properties of an isosceles triangle in absolute geometry?
The properties of an isosceles triangle in absolute geometry include: two equal sides, two equal angles, the base angles are equal, the sum of the angles is 180 degrees, and the base angles are congruent to the opposite angles.
4. How can you prove that a triangle is isosceles in absolute geometry?
To prove that a triangle is isosceles in absolute geometry, you can use the congruence of sides and angles. If two sides and the angle opposite one of those sides are congruent to another triangle's corresponding sides and angles, then the triangle is isosceles.
5. What is the importance of isosceles triangles in absolute geometry?
Isosceles triangles are important in absolute geometry because they are used in many geometric constructions and proofs. They also have unique properties that make them useful in solving problems and understanding other geometric principles.
  • Math POTW for Secondary and High School Students
