Isothermal (almost) compression of gas by water injection
In summary, isothermal compression of gas by water injection involves injecting water into a gas reservoir to increase the pressure and reduce the volume of the gas. This process can be used to extract natural gas from underground reservoirs and is often done in a controlled and gradual manner to prevent damage to the reservoir. The term "isothermal" refers to the fact that the temperature of the gas remains constant during the compression process, which is important for maintaining the quality of the extracted gas. Overall, isothermal compression by water injection is a common technique used in the oil and gas industry to effectively extract natural gas from underground reservoirs.
pranj5
386
http://www.fluidmechanics.co.uk/
I have found this by searching net. The inventor claimed that by using a new kind of piston fitted with fins, he achieved almost isothermal compression and greatly reduced the power consumption process. I want to know how much theoretically sound it is.
If it is slow, the cylinder may be able to dissipate heat sufficiently quickly during a compression to prevent significant temperature increase. It requires much less work to compress the gas if heat is dissipated during compression to keep the temperature constant. So whether it works or not depends on how fast the compression is.
AM
What you have said is already known. But, this process is different. It's sufficiently fast (1500 rpm), but still can control the temperature rise by using water. It's the uniqueness of this technology, which is simultaneously fast and isothermal.
I thought you were asking whether it is theoretically possible. It is. Whether it actually works is a different question.
AM
As per the claims on the website, they have done it.
This seems to be a detailed analysis of a water-injection-cooled compression cycle process: DEVELOPMENT OF A RECIPROCATING COMPRESSOR USING WATER INJECTION TO ACHIEVE QUASIISOTHERMAL COMPRESSION
Purdue.edu said:
ABSTRACT
A novel kind of reciprocating air compressor is being developed, in which quasi-isothermal compression is achieved by the injection of a large quantity of water through spray nozzles inside the compressor. The compressor is mainly intended as a part of a new thermodynamic cycle for efficient power generation, but it could be used in stand-alone applications as well. Due to the high density and heat capacity of the liquid water spray, the temperature increases only slightly during compression. The water is not consumed but separated from the pressurized air, cooled and re-used, offering options for heat recovery. A compression ratio of up to 1:30 can be realized in a single cylinder. Results from a test rig and a full-scale compressor prototype are presented.
Wet bottom compressors and compressors with water injection are old technology . Noah probably used them in his ark .
Likes RonL
pranj5 said:
That simply means that by controlling the temperature, we can reduce power consumption for gas. I am just curious that whether the steam will be applicable to steam/vapour or not.
Your thread title reflects exactly the topic in the white paper link provided.
Actually, I am more interested to know that whether such power consumption reduction can be achieved even for steam/vapour or not.
Related to Isothermal (almost) compression of gas by water injection
1. What is isothermal (almost) compression of gas by water injection?
Isothermal (almost) compression of gas by water injection is a process in which water is injected into a gas reservoir to increase the pressure and compress the gas. The term "isothermal" refers to the fact that the temperature of the gas remains relatively constant during this process, as the water absorbs the heat generated by compression.
2. How does isothermal (almost) compression of gas by water injection work?
In this process, water is pumped into the gas reservoir at a high pressure, causing the gas to be compressed as the water displaces it. The gas is compressed isothermally, meaning that its temperature does not change significantly, due to the heat absorption by the injected water. As a result, the gas becomes more dense and its pressure increases.
3. What are the benefits of isothermal (almost) compression of gas by water injection?
One of the main benefits of this process is that it allows for efficient compression of gas without the need for external energy sources. The water acts as a natural piston, compressing the gas while also absorbing the heat generated. This can also help to reduce the risk of explosion or fire during compression.
4. What are the potential applications of isothermal (almost) compression of gas by water injection?
This process can be used in various industries, such as oil and gas, to increase the pressure of gas in reservoirs for storage or transportation. It can also be used in natural gas processing plants to compress gas for further processing. Additionally, it can be used in renewable energy systems, such as compressed air energy storage, to store and release energy.
5. Are there any limitations to isothermal (almost) compression of gas by water injection?
While this process has many benefits, it also has some limitations. One limitation is that it can only be used for gases that are compatible with water, as some gases may react with water or dissolve in it. Additionally, the efficiency of this process may decrease if the water does not fully displace the gas or if there are leaks in the reservoir.
  • Thermodynamics
  • Mechanical Engineering
13K
