Isotopy between overlapping and non-over. Dehn Twists.
In summary, for two Dehn twists D1 and D2 to commute, the annuli A1 and A2 must be disjoint so that the action of D1 does not affect D2. However, if A1 and A2 do overlap, the two twists are still isotopic, meaning that D2oD1 is isotopic to D1oD2 when A1 and A2 are not disjoint. To show this, a homotopy can be used to stretch a common region A3 to a larger annuli A3', creating a new annuli A4 and homotoping the curve to first twist in A3' and then in A4, resulting in an isotopic self homeomorphism of T^
Bacle
662
Hi, everyone:
I am curious about this: two Dehn twists D1,D2, commute if the annuli A1, A2
are disjoint, so that the action of D1 does not affect D2 ( and the respective curves
C1,C2 about which we do the twists.)
Now, there is also a result that if the annuli A1, A2 , _do_ overlap, that
D2oD1 is not, of course, equal to D2oD1 if/when A1,A2 are disjoint, but, we
do have that the two twists are isotopic, i.e., the twist D2oD1 , with A1/\A2={}
is isotopic to the twist D1oD2 , when A1/\A2 =/ {}.
Anyone have an idea for how to show this.? . Sorry I don't have Rolfsen
(nor his book : ) ) available at the moment.
Thanks in Advance.
Um, I will try, but this kind of thing is so much easier to explain on a blackboard. For simplicity, assume D1 and D2 both take place along the "small diameter of the torus" (much easier to visualize) and also assume that both D1 and D2 are 1-turn twists in the same direction!
First, set A3=A1 n A2. Then consider the homotopy that first "stretches" A3 to a big annuli A3' covering like half the torus. Then as a curve goes around the big diameter of the torus, it slowly twists twice around the small diameter as it passer through the region A3'. Select a sub annuli A4 of A3' and homotope the region A3' so that at time t=1 of the homotopy, our traveling curve does its first twists.., then is constant on A4... then does its second twist. Set one of the connected component of A3' \A4 to be A1' and the other to be A2'. Then the resulting self homeo of T^2 at time t=1 of the homotopy is a dehn twist in A1' following by a Dehn twist on A2' as required...
Related to Isotopy between overlapping and non-over. Dehn Twists.
What is isotopy between overlapping and non-overlapping Dehn twists?
Isotopy refers to a continuous transformation or deformation of one object into another. In the case of Dehn twists, isotopy involves a continuous transformation of a surface or space that preserves certain properties, such as its topology.
What is a Dehn twist?
A Dehn twist is a type of transformation that involves cutting a surface or space along a simple closed curve and then twisting one side of the cut by a certain angle before rejoining the two sides. This transformation is named after mathematician Max Dehn.
What is the difference between overlapping and non-overlapping Dehn twists?
The main difference between overlapping and non-overlapping Dehn twists lies in the way the transformation is performed. In an overlapping Dehn twist, the two sides of the cut intersect, resulting in a twist that overlaps itself. In a non-overlapping Dehn twist, the two sides of the cut do not intersect, resulting in a twist that does not overlap itself.
How are Dehn twists used in mathematics?
Dehn twists are used in various branches of mathematics, including topology and geometry. They are particularly useful in studying surfaces and their properties, such as orientability and genus. Dehn twists also have applications in physics, including in the study of knots and their invariants.
What are some real-world examples of Dehn twists?
Dehn twists are not just theoretical concepts - they have real-world applications as well. For example, they can be used in robotics to manipulate and transform objects, in cryptography to encrypt data, and in computer graphics to create interesting visual effects. They also have applications in architecture, art, and design.
  • Differential Geometry
  • General Math
  • Other Physics Topics
