Isotropic absorption and emission
In summary, the rate of absorption in a molecule depends on the angle between the transition dipole and the polarization of the photon. While applying an electric field can greatly influence this angle and potentially increase absorption, the necessary fields are often too high to be practical. In atoms, the effect is also minimal unless a strong polarization is applied.
ArchieDave
Something I've yet to understand: If a molecule has a dipole moment about a given access than absorption of a photon can readily occur. However, if it is possible to preferentially orient molecules by applying an electric field, would the rate of absorption be greatly increased or decreased? It seems like this would influence typical spectroscopic approaches when a field is present and I've never seen that to be the case. If this is true, is the affect mitigated in atoms where the the electrons can be "pushed around" by the laser field?
Yes, absorption depends on the angle between the transition dipole and the polarization of the photon. When calculating absorption in a gas, one often starts from the maximum transition dipole moment (molecules aligned with the field), and then averages out over all possible angles.
The fields needed to significantly orient molecules are very high. Ususally, to achieve orientation, an intense laser pulse is needed. Static fields are generally much too weak.
To see an effect in atoms, you would need a strong polarization to see an effect. Again, that would require laser-strength fields (or maybe processes such as optical pumping).
FAQ: Isotropic absorption and emission
1. What is isotropic absorption and emission?
Isotropic absorption and emission refers to the process in which a material absorbs and emits electromagnetic radiation equally in all directions. This means that the intensity of the radiation is the same regardless of the direction it is measured from the material.
2. What is the difference between isotropic and anisotropic absorption and emission?
The main difference between isotropic and anisotropic absorption and emission is that in anisotropic materials, the intensity of the absorbed or emitted radiation is dependent on the direction it is measured from the material. This means that the material has different properties in different directions.
3. How does isotropic absorption and emission affect light propagation in a material?
Isotropic absorption and emission can affect light propagation by causing scattering and absorption of the light. This means that the light may be redirected or absorbed as it passes through the material, which can affect its intensity and direction.
4. What factors can influence isotropic absorption and emission in materials?
Several factors can influence isotropic absorption and emission in materials, including the material's composition, structure, and physical properties such as density and temperature. Additionally, the wavelength and energy of the radiation being absorbed or emitted can also play a role.
5. What are some applications of isotropic absorption and emission in scientific research?
Isotropic absorption and emission have various applications in scientific research, including spectroscopy, optical and electronic devices, and materials science. By studying the absorption and emission properties of materials, scientists can gain insights into their structure, composition, and behavior, which can help in developing new technologies and materials.
