Issue With Derivation of Gravitational Time Dilation
In summary, the conversation discusses the use of the equation ##\frac {1}{2}mv^2 = \frac {GmM}{r}## to derive potential velocity and then using it in the Lorentz factor to derive gravitational time dilation. However, this approach is incorrect as it does not take into account the equivalence principle and the fact that ##v## in the kinetic energy formula does not apply to the object whose gravitational time dilation is being calculated. The conversation also mentions that there is no known derivation that uses the classical definition of kinetic energy to derive gravitational time dilation.
bsalha
TL;DR Summary
Why does the derivation of gravitational time dilation use classical mechanics' definition of kinetic energy as opposed to the relativistic definition of kinetic energy?
Why do we use the equation ##\frac {1}{2}mv^2 = \frac {GmM}{r}## to derive potential velocity, and then put that in the Lorentz factor in order to derive gravitational time dilation? Shouldn't we be using the relativistic definition of kinetic energy -> ##mc^2(\gamma - 1)## to derive the gravitational time dilation? Using the first approach we get $$\gamma = \frac 1 {\sqrt {1 - \frac {2GM} {rc^2}}},$$ but using the relativistic definition of kinetic energy we get $$\gamma = \frac {GM} {rc^2}+1$$, so clearly one of these approaches is wrong.
Where have you seen gravitational time dilation derived this way? Can you give a reference?
As Peter is hinting, your derivation is incorrect. ##v## in your calculation is the Newtonian velocity of something dropped from rest at infinity to radius ##r##. But the gravitational time dilation formula you quote applies between hovering observers - who would regard such infalling objects as moving, so a different time dilation factor would apply. Even if the Newtonian calculation of the velocity were correct, which it's not.
Furthermore, ##\gamma## is the kinematic time dilation factor between inertial frames, so can only be used locally in general relativity. It makes no sense to apply it to comparing rates of distant clocks in curved spacetime because ##v## cannot be defined the way it requires.
Peter asked for a reference. If you can provide one, we'd be interested because it's a source to avoid. If, on the other hand, it's something you came up with yourself, you've simply found an amusing coincidence, not a derivation.
That is interesting. I know of two different derivations, and neither uses KE at all. The ones I am familiar with either use the equivalence principle or directly from the metric.
If you don’t like that derivation then I would just find another one that you do like
I did not find it online, someone told me about it.
I knew this derivation made no sense because the energy principle in this scenario is applying to an energy conserved system consisting of an infinite amount of space between the observer and the object and it makes so many assumptions that I can't even comprehend. However it is quite insane that the approximation for kinetic energy in the system can be used in for the velocity in the Lorentz factor and one can get the expression for gravitational time dilation.
Did this someone give you an actual reference? Or were they just making it up?
As you can see from the responses you have gotten in this thread, there is no such derivation.
No, it's not "insane", it's just a coincidence, as @Ibix has pointed out. What's more, the coincidence is even less impressive than it might seem at first glance. Consider: the kinetic energy expression includes a velocity ##v##. But what object has this velocity? Certainly not the object whose gravitational time dilation is equal to the expression you give, because that object is static--that expression for gravitational time dilation is for an object which is at rest relative to the gravitating mass, at radial coordinate ##r## (which is not quite the same as the actual proper distance of the object from the center of the gravitating mass). So the coincidence is the result of mixing together two formulas that don't even apply to the same object.
I know it is a coincidence I'm just saying that it is funny that you can incorrectly come to a correct conclusion by failing to be precise. And no this person didn't have a source he just attempted to oversimplify the derivation then I asked why he used the approximation for kinetic energy and he said you just assume you're not going that fast and then I got even more confused.
He wasn't oversimplifying a valid derivation to begin with: the entire reasoning is invalid because, as I said, the ##v## in the kinetic energy formula can't possibly apply to the object whose gravitational time dilation is given by the formula that is derived. The same would be true if you tried to use the relativistic formula for kinetic energy.
This is essentially numerology, just with algebra instead of arithmetic. Like numerology, coincidences come up more often than you might naively think. Like numerology, there's no meaning to the coincidences.
But why is a mass traveling at a velocity relative to a distant "stationary" observer seen to have a slower ticking clock and why is this the same situation observed for a mass resting (v=0) on the top of a mountain on Earth and the same situation when the object begins to free fall (v=0+ ) off of that mountain top? What is common to these three situations? What is the mechanism at play?
This may be more than coincidence. Perhaps it is a hint that there is an unrecognized, underlying mechanism at work.
The last two aren't different, because the mass resting on the mountain and the mass just starting to free-fall aren't different with respect to time dilation (since the mass just starting to free-fall still has negligible velocity and is still at the same altitude).
The first situation has nothing significant in common with the second except that, like any phenomena in General Relativity, they are both ultimately due to spacetime geometry (see below). Time dilation due to relative velocity is symmetric: each observer sees the other's clock running slow. Time dilation due to different altitudes in a stationary gravitational field is not symmetric: both observers agree that the observer at the higher altitude has a faster running clock.
The underlying "mechanism" in general is spacetime geometry. But see below.
As above, the underlying "mechanism" is spacetime geometry. But nothing in the spacetime geometry requires that there must always be some kind of match between "velocity time dilation" and "gravitational time dilation". The match in this particular case is, as has already been said, just a coincidence.
I strongly recommend that you review the PF rules on personal speculation before posting further on this subject. Your posts are already close to the line on that.
Ticks of a clock turn out to mark regular intervals in spacetime in the same way that marks on a ruler mark regular distances in space. The two clocks' paths through spacetime are not parallel so, just as the tick marks on rulers don't align if they aren't parallel, the clocks' ticks don't align.
It isn't. Two objects at the same height with no relative speed between them tick at the same rate. If the clocks are at different altitudes then they tick at different rates (in some sense). The reason is the same - the "distances" through spacetime indicated by the clocks are along paths that are not parallel, with the added complication that even defining "parallel" in curved spacetime is complicated.
It really isn't. How Newtonian gravity emerges as an approximate form of GR is well understood. And how SR emerges as a special case of GR is well understood. Ripping bits out of both and jamming them together is meaningless, even if there are some coincidences when you do. It's like taking a piece of a jigsaw with sky on it and another piece with grass on it and noticing that the edges happen to fit. You can put them together, but you're rather missing the point if you do.
But why does both the clock traveling at a relative velocity tick slower AND so does the clock located at a deeper position in a gravity field? Inertial-gravitational equivalence .
Their worldlines aren't parallel and/or spacetime is curved so "parallel" is a complicated concept. Thus times along their worldlines are like distances along non-parallel rulers or distances along different latitude lines - they don't align. As I already said.
If this is an attempt at your own answer to the question, please re-read PeterDonis' last paragraph. Note that the "Mentor" badge means he's a forum moderator.
In any case it appears to be just three random words, at least in this context.
Go back and read my post #13 again. These two cases are not the same.
This is not correct. And since I have already cautioned you about personal speculation, you have just been banned from further posting in this thread.
Related to Issue With Derivation of Gravitational Time Dilation
1. What is gravitational time dilation?
Gravitational time dilation is a phenomenon in which time passes at different rates in different gravitational fields. This means that time moves slower in stronger gravitational fields, such as those near massive objects like planets or stars.
2. How does gravitational time dilation affect the passage of time?
Gravitational time dilation causes time to pass more slowly in strong gravitational fields. This means that clocks in these fields will appear to run slower compared to clocks in weaker gravitational fields.
3. What is the equation for gravitational time dilation?
The equation for gravitational time dilation is t' = t√(1 - 2GM/rc^2), where t' is the time measured in a stronger gravitational field, t is the time measured in a weaker gravitational field, G is the gravitational constant, M is the mass of the object creating the gravitational field, r is the distance from the center of the object, and c is the speed of light.
4. How is gravitational time dilation related to Einstein's theory of relativity?
Gravitational time dilation is a consequence of Einstein's theory of relativity, specifically the theory of general relativity. This theory explains how gravity affects the fabric of space and time, causing time to pass at different rates in different gravitational fields.
5. What are some real-world examples of gravitational time dilation?
One example of gravitational time dilation is the time difference between a clock on the surface of the Earth and a clock on a satellite in orbit. The clock on the satellite will run slightly faster due to the weaker gravitational field. Another example is the time difference between a clock on the top of a mountain and a clock at sea level, with the clock at sea level running slightly slower due to the stronger gravitational field.
