(Iterated Integrals) Volume between a Cone and a Sphere
In summary, the sphere and cone intersect at 2 = z^{2}+y^{2}+z^{2}=4. The book says to evaluate the integrals but I'm not sure how to do that with my crappy calculator.
MrMaterial
33
This is a book problem, as follows: Find the volume between the cone x = [itex]\sqrt{y^{2}+x^{2}}[/itex] and the sphere x[itex]^{2}[/itex]+y[itex]^{2}[/itex]+z[itex]^{2}[/itex] = 4
spherical coordinates:
p[itex]^{2}[/itex]=x[itex]^{2}[/itex]+y[itex]^{2}[/itex]+z[itex]^{2}[/itex]
[itex]\phi[/itex] = angle from Z axis (as I understand it)
[itex]\theta[/itex] = angle from x or y axis
I am confused on what solid they are referring to, so I will do it in two different ways.
I will first solve it assuming it is the volume of the cone (cone with spherical top)
It seems obvious that this is best solved using spherical coordinates.
First looking at the cone, it is a cone that appears on its side as it travels in the direction of the x axis.
Looking at the sphere, it is simply a sphere centered at the origin with a radius of [itex]\sqrt{4}[/itex]
At this point I start setting up the triple integral.
[itex]\int\int\int[/itex]p[itex]^{2}[/itex]sin([itex]\phi[/itex])dpd[itex]\phi[/itex]d[itex]\theta[/itex]
p is going to go from 0 to [itex]\sqrt{4}[/itex]
[itex]\phi[/itex] is going to go from [itex]\pi[/itex]/4 to 3[itex]\pi[/itex]/4
θ is going from -[itex]\pi[/itex]/4 to [itex]\pi[/itex]/4
Then i punch it into the calculator and I get 4[itex]\pi[/itex]([itex]\sqrt{2}[/itex]/3)
The book answer is 16[itex]\pi[/itex](([itex]\sqrt{2}[/itex]-1)/(3[itex]\sqrt{2}[/itex]))
For my second answer I will assume they want me to find the volume of the sphere, then subtract my former answer (the cone with spherical top)
First I will find the volume of the sphere
[itex]\phi[/itex] is going to go from 0 to [itex]\pi[/itex]
θ is going from 0 to 2[itex]\pi[/itex]
punch it into the ol' calculator and I get 32[itex]\pi[/itex]/3
then I subtract my previous answer and I get
27.59
The book answer to this problem in decimal form is 9.815
So I must have found the volume of the wrong solid, or i set up my integrals wrong? Can any of you tell by looking at my work?
thanks!
Hi MrMaterial! :smile:
(btw, you do know what √4 is don't you? :biggrin:)
(i assume you mean x = √(y2 + z2))
i] You've missed a fundamental feature of limits in multiple integrals …
only the first limits are always between fixed values,
the next limits usually depend on the value of the first variable :wink:
ii] Also, in this case wouldn't it be a lot easier if you took your x axis as φ = 0 instead of the usual z axis ? :wink:
For x, y, z (rectangular) coordinates the limits on all three integrals are constants only if the region is a rectangular solid. For cylindrical coordinates the limits on all three integrals are constants only if the region is a cylinder. For spherical coordinates, the limits on all three integrals are constants only if the region is a sphere.
ok so it turns out that i was actually finding more of a square cone (piece of a sphere) rather than an actual cone with a spherical top.
Now taking the comments into consideration i will find where both functions intersect.
After substituting and whatnot I get that the sphere and the cone intersect at 2 = z[itex]^{2}[/itex]+y[itex]^{2}[/itex]
Now i am going to reset the bounds on my dpd[itex]\phi[/itex]d[itex]\theta[/itex] integral.
well I converted x = [itex]\sqrt{y^{2}+z^{2}}[/itex] to spherical coordinates and solved for p and here's my guess as to what that bound will look like:
p goes from [itex]\sqrt{(1-tan(\theta)^{2})/(cos(\phi)^{2})}[/itex] to 2
I couldn't seem to find [itex]\phi[/itex] in terms of [itex]\theta[/itex] so i set the remaining bounds to
[itex]\phi[/itex] goes from [itex]\pi[/itex]/4 to 3[itex]\pi[/itex]/4
[itex]\theta[/itex] goes from [itex]\pi[/itex]/4 to -[itex]\pi[/itex]/4
I also decided to do cartesian coordinates at one point!
for an integral of dxdydz I have the bounds:
x goes from [itex]\sqrt{z^{2}+y^{2}}[/itex] to [itex]\sqrt{4-y^{2}-z^{2}}[/itex]
y goes from -[itex]\sqrt{2-z^{2}}[/itex] to [itex]\sqrt{2-z^{2}}[/itex]
and z goes from 0 to [itex]\sqrt{2}[/itex]
do any of these look right? I would evaluate them but my classpad isn't up to the task and I don't feel like doing all the pencil work if they aren't going to be right!
Related to (Iterated Integrals) Volume between a Cone and a Sphere
What is the formula for calculating the volume between a cone and a sphere?
The formula for calculating the volume between a cone and a sphere is V = 1/3πh(r^2 + 3R^2), where h is the height of the cone, r is the radius of the sphere, and R is the radius of the base of the cone.
How do you determine the limits of integration for calculating the volume?
The limits of integration for calculating the volume between a cone and a sphere depend on the shape of the region between the two objects. It is important to visualize the region and determine the points where the two objects intersect. These intersection points will serve as the limits of integration for the appropriate variables in the formula.
What is the relationship between the cone and sphere in this problem?
The cone and sphere are two distinct three-dimensional objects with different shapes and dimensions. However, in this problem, the cone is inscribed inside the sphere, meaning that the base of the cone lies on the surface of the sphere and the cone's height is equal to the sphere's radius. This relationship helps determine the limits of integration and the formula for calculating the volume.
Can the volume between a cone and a sphere be negative?
No, the volume between a cone and a sphere cannot be negative. Volume is a measure of the amount of space occupied by an object, and it is always a positive value. The formula for calculating the volume between a cone and a sphere will always yield a positive value, even if the cone is completely inside the sphere.
How can this problem be applied in real-world scenarios?
This problem can be applied in real-world scenarios, such as calculating the volume of a storage tank with a spherical top and a conical bottom. It can also be used in engineering and architecture to determine the volume of structures with similar shapes, such as silos and domes. Additionally, this problem can be used in mathematics and physics to understand the relationship between different three-dimensional shapes and their volumes.
