Ventrella
- 29
- 4
I am exploring the behaviors of complex integers (Gaussian and Eisenstein integers). My understanding is that when a complex integer z with norm >1 is multiplied by itself repeatedly, it creates a series of perfect powers. For instance, the Gaussian integer 1+i generates the series 2i, -2+2i, -4, -4-4i, etc., and the norms are powers of 2. The series generated from such an iteration always lies on a logarithmic spiral, unless the initial value of z is on the real axis, in which case the series follows a line that extends straight along the positive side of the real axis. I hope I stated that correctly :) Here's a nice web page with an interactive tool to explore the behaviors of complex powers:
http://plansoft.org/edu/power.html
The set of Gaussian integers forms 8 axes of symmetry (the real and imaginary axes, and the four diagonals). The set of Eisenstein integers forms 12 axes of symmetry. These axes correspond to the "pie slices" that are isomorphic to each other, given rotations and reflections. If z lies on an axis of symmetry, then I believe the numbers in the series will always lie on an axis of symmetry. Is this assumption correct?
My question concerns the inverse: if z (does not) lie on an axis, will the resulting series of powers (never) lie on an axis? If we do not constrain ourselves to the complex integers, then I believe it is possible that there are certain values of z that will generate series in which a (subset) of numbers lie on an axis - however, in this case, the notion of "axis" has a different meaning. My question pertains to complex integers specifically.
Thank you!
-Jeffrey
Thank you!
-Jeffrey
