Iterators and generators and the data they generate
Iterators in Python are objects that implement the __iter__ and __next__ methods, allowing data to be generated one item at a time without consuming large amounts of RAM. They can pull data from existing sources, like text files, without loading everything into memory, and can also generate data dynamically, such as an infinite sequence of numbers. Generators, which are functions that use the yield statement, create custom iterators and return generator objects that can be iterated over. While iterables like range() and map() are not iterators themselves, they can be converted into iterators using the iter() method. Overall, iterators and generators provide efficient ways to handle data generation and retrieval in Python.
fog37
TL;DR Summary
Hello,
I have been focusing on iterators and generators and I understood a lot but still have some subtle questions...
An iterator, which is a Python object with both the __iter__ and the __next__ methods, saves its current state. Applying the next() method to an iterator gives us one item of data at a time. On the other hand, when a regular Python list is created, all the data in the list is generated at once taking a lot of RAM. But when an iterator is created, I believe we are essentially saving the "recipe" on how to create the data but the data is generated a piece at a time and only upon our request. As we ask the iterator for data, step by step using the next() method, we are not creating and storing the data in RAM: the iterator does not save (unless we explicitly code for it) the data ahead of time and the data that is generates, correct?
Example: the data the iterator is using may already exist and be saved in the permanent memory. For example, there may be a huge text file saved on the computer. The iterator may pick a line at time from the text file without loading the entire file in RAM.
The iterator may also generate its data dynamically. For example, when we use an iterator to generate an infinite set of numbers: we don't really create those numbers in memory ahead of time or even save them after they are generated...I believe..
A generator is a special type of function with the return statement replaced by the yield statement. Is a generator just a function whose outcome/return is an iterator? Is a generator essentially a way to create a custom iterator? Python has iterator objects like range(), map(), etc. We can also convert certain iterable data structures, like lists, dictionaries, tuples, etc. into iterators using the iter() method... Are generators a way to create flexible iterators?
Technology news on Phys.org
Correct. It generates the data only as it is needed.
Yes.
Yes. For example, look at the count function in the itertools module.
More precisely, a generator is any function that has one or more yield statements in its body. It can also have return statements in its body, although this is very rarely done. (A return inside a generator causes it to stop iteration immediately.)
Not quite. Calling the generator function returns a generator object, which can be iterated over like any other iterable, for example in a for loop. Calling iter on an iterable (whether it's a generator or any other iterable) returns an iterator (although usually you don't need to do this explicitly, it gets done implicitly inside the interpreter when you use something like a for loop).
Essentially, yes. But see above for some important details.
Actually, those aren't iterators, they are iterables. An iterable has an __iter__ method, but not a __next__ method. The built-in iter function implicitly calls the __iter__ method of an iterable to return an iterator over that iterable. The Python documentation goes into a fair bit of detail about all this.
I'm not sure what you mean by "flexible".
Thread 'Is this public key encryption?'
I've tried to intuit public key encryption but never quite managed. But this seems to wrap it up in a bow. This seems to be a very elegant way of transmitting a message publicly that only the sender and receiver can decipher. Is this how PKE works? No, it cant be. In the above case, the requester knows the target's "secret" key - because they have his ID, and therefore knows his birthdate.
I tried a web search "the loss of programming ", and found an article saying that all aspects of writing, developing, and testing software programs will one day all be handled through artificial intelligence. One must wonder then, who is responsible. WHO is responsible for any problems, bugs, deficiencies, or whatever malfunctions which the programs make their users endure? Things may work wrong however the "wrong" happens. AI needs to fix the problems for the users. Any way to...
