Ivan's Creek: Low-head hydro-electric power
  • Thread starter Integral
  • Tags
    Power
In summary: Since it is a seasonal creek and is known not to contain anadromous fish populations, and since I have water rights as it crosses the property, in principle, a hydroelectric plant should be feasible. However, the location of the dam would need to be carefully considered in order to minimize environmental impact.
  • #36
Integral said:
http://home.comcast.net/~integral50/scenery/streamlr.JPG
The state of the stream today... Not nearly as exciting.
Have you considered the "rustic" approach? Can't tell a whole lot about the topography, just picturing an undershot wheel 'tween the trees and bridge, 'bout even w' the bar.
How much cutting goes on during the high water?
  • #37
Anything but a crossflow turbine is too inefficient to be worth doing. It just wouldn't be enough power to be useful in a practical way that would offset the cost. Undershot wheels can run as low as 20% efficient...in fact I think that's more like a best case.
And it does move an amazing amount of rock during heavy flows. The little island seen in the one shot was formed in about one day. I have seen it dig straight down through six feet of rocky clay in a week.
  • #38
I didn't even notice that the original paper is linked at the end.
http://home.carolina.rr.com/unclejoe/banki_scan.pdf
Also, ignore all of the whining about the paper. I had no trouble reading it and then designing my own turbine. [Yes, unfortunately I got that far].
  • #39
One more thought here: I think a major trap for the alternative energy crowd is the idea of selling power back to the power company. At $10K for the safety switch that is legally required in order to prevent back-feeding the lines during an outage and possibly killing a lineman, I don't think it's worth trying to sell the power back unless we are talking about a very large installation. But in many more cases it does make sense to isolate the system from line power and design the loads to follow the supply power available - to keep the system operating at max efficiency. The plan was to design one of the four heater modules [~5KW each] so that by using triacs, a 1, 2, 3, 4, or 5 KW load could be selected so as to maintain a nearly constant turbine speed. This seemed a best option as opposed to trying to PWM a highly inductive load or trying to vary the load linearly. In both cases the potential complications seemed best to avoid altogether. But this was a judgement call and unique to my situation. Linearly variable loads would probably work fine in most cases. The additional water heater element would be a fixed load in this plan, which would cause some additional losses, but it calculated out that those losses would be relatively small, and acceptable.
If the creek was more stable with an easily had four feet of effective head, and assuming a typical Oregon winter, this installation calculates out as being worth about $250 per month, eight months of the year. And keep in mind that a typical flow is about 16% of that seen here. Integral came by because of the unusually large flow due to a month of heavy rain.
Late edit [sorry]: for those who don't know this, one of greatest sources of energy loss and expense for alternative energy systems is the need for energy storage. This design seeks to avoid this problem. Also, the final parameters were for a variable 1- 10 KW load as the flows in the creek vary over the season. The max efficiency of the system occurs at a constant turbine speed and is otherwise independent of the load or the power being generated.
