Christian Nguyen
- 4
As part of an ongoing project I have been working on, I have been reading through J.J. Thomson's Cathode Ray Experiment. As part of his setup Thomson writes, "The arrangement used was as follows: — Two coaxial cylinders (fig. 1) with slits in them are placed in a bulb connected with the discharge–tube; the cathode rays from the cathode A pass into the bulb through a slit in a metal plug fitted into the neck of the tube; tins plug is connected with the anode and is put to earth. The cathode rays thus do not fall upon the cylinders unless they are deflected by a magnet. The outer cylinder is connected with the earth, the inner with the electrometer."
Could someone please explain to me the setup of this experiment, especially the part about the coaxial cylinders and how they relate to the image that he drew (I attach that with the post).
Thank You,
Christian
Thank You,
Christian
