J1.1.6 Suppose a and b are integers that divide the integer c
In summary: The result is not true if $c\leq d$.In summary, if $a$ and $b$ are relatively prime, then $ab / c$ is a divisor of $c$. If $a$ and $b$ are not relatively prime, then ab need not divide $c$.
karush
MHB
3,269
If a and b are relatively prime, show that $ab / c$
Show by example that if a and b are not relatively prime,
then ab need not divide c
let
$$a=3 \quad b=5 \quad c=15$$
then
$$\frac{15}{3\cdot 5}=1$$
let
$$a=4 \quad b=6 \quad c=15$$
then
$$\frac{15}{4\cdot 6}\quad\textit{not an interger}$$
my feeble attempt:confused:
Mathematics news on Phys.org
If $a$ and $b$ are relatively prime then the prime factors of $ab$ must be in $c$. If $a$ and $b$ are not relatively prime then this is not necessarily true (by "prime factors" I mean exponentiation is included). Consider $8|72$, $9|72$ and $8*9|72$, but $8|72$, $24|72$ but $8*24\cancel{|}72$.
so the $\vert$ means factor of
For any integers $a$ and $b$, if both divide another integer $c$, their lcm always divides $c$. If $\gcd(a,b)=1$, then $\mathrm{lcm}(a,b)=ab$.
Or $a|b\Rightarrow a\text{ divides }b$.
By the way the second line of the OP should read $ab\mid c$.
yeah saw that
but too late to change
but mahalo
karush said:
yeah saw that
but mahalo
ʻAʻole pilikia. (Wave)
Anyway, this result is a generalization of the OP:
Given nonzero integers $a$ and $b$ with lcm $m$ and gcd $d$, $dm=ab$.​
The lcm of $a$ and $b$ can be taken to be the least positive integer that is a common multiple of $a$ and $b$. We have the following lemma:
$m=\mathrm{lcm}(a,b)\ \iff\ a,b\mid m$ and for any $n\in\mathbb Z$, $a,b\mid n\implies m\mid n$.​
In other words, the lcm divides every other common multiple of $a,b$. The proof is straightforward, using the division algorithm.
So, let $a=a_0d$, $b=b_0d$. We wish to show that $m=a_0b_0d=\mathrm{lcm}(a,b)$ (so that $md=ab$). As $m=ab_0=a_0b$, it is a common multiple of $a,b$. Let $n=a_1a=b_1b$ be any common multiple of $a,b$. Suppose $r,s$ are integers such that $ra+sb=d$. We have:
$$\begin{array}{rrcl}{} & ra+sb &=& d \\ \implies & ra_0+sb_0 &=& 1 \\ \implies & ra_0(b_1b)+sb_0(a_1a) &=& n \\ \implies & ra_0b_1b_0d+sb_0a_1a_0d &=& n \\ \implies & m(rb_1+sa_1) &=& n\end{array}$$
Thus $m\mid n$, and so $m$ is the lcm of $a,b$ as claimed.
In the OP, $d=1$ and $c$ is a common multiple of $a,b$.
FAQ: J1.1.6 Suppose a and b are integers that divide the integer c
What is the definition of integers?
The definition of integers is a whole number, either positive or negative, including zero.
Can you give an example of integers that divide another integer?
Yes, for example, 3 and 6 are both integers that divide the integer 12.
What is the result when two integers divide an integer?
The result is also an integer, as the division of integers always results in an integer.
Is it possible for both integers to divide the integer evenly?
Yes, it is possible for both integers to divide the integer evenly, as long as the integer is a multiple of both integers.
How do you know if an integer is divisible by another integer?
An integer is divisible by another integer if the remainder is equal to zero when the first integer is divided by the second integer.
