MHB Jack's Rhombus Ring Pattern: A Unique Geometric Design
Jack creates a geometric design using rings of rhombuses centered around a common point, with each rhombus sharing sides with adjacent rhombuses. The first ring consists of identical rhombuses, while the second ring's rhombuses share sides with those in the first ring. Jack continues this pattern until no new rhombuses can be added, resulting in three rings when starting with seven rhombuses in the first ring. A separate pattern is proposed where the last ring's rhombuses have an angle of 20 degrees and the second last ring has an angle of 60 degrees, prompting a discussion on the number of rhombuses and rings in this configuration. The exploration of these geometric patterns highlights the mathematical relationships and constraints in creating rhombus ring designs.
bio
Jack draws rings of rhombuses about a common centre point. All rhombuses have the same side length.
Rhombuses in the first, or inner, ring are all identical. Each rhombus has a vertex at the centre and each of its sides that meet at the centre is shared with another rhombus. They all have the same size angle at the centre. Figure 1 shows a first ring with 7 rhombuses.
Each rhombus in the second ring has two adjacent sides each of which is shared with a rhombus in the first ring. Figure 2 shows the second ring when the first ring contains 7 rhombuses.
Jack continues adding rings of rhombuses in the same way for as long as possible. Figure 3 shows the third ring when the first ring contains 7 rhombuses. In this example, since it is not possible to draw any new rhombuses that share an edge with two rhombuses in the third ring, there are only three rings in this rhombus ring pattern.
a) In another rhombus ring pattern, each rhombus in the last ring has an angle of 20 degrees and each rhombus in the second last ring has an angle of 60 degrees. How many rhombuses are in each ring, and how many rings are there in this rhombus ring pattern?
Figures 1, 2 and 3 can be found at this link. https://imgur.com/a/qN4yDVe
Mathematics news on Phys.org
how to get to the answer
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
20K
