Jacob's question at Yahoo Answers (Alternating series approximation)
In summary, the Leibniz criterion can be used to approximate the sum of the series $\sum_{n=1}^{\infty} (-1)^n/(5^n*n!)$ to four decimal places. The smallest positive integer satisfying the error bound of 0.0001 is 4, which gives an approximation of the series to four decimal places.
Fernando Revilla
MHB
631
Here is the question:
Approximate the sum of the series correct to four decimal places.
∑ (-1)^n/(5^n*n!)
n=1
Here is a link to the question:
Approx. series help please? - Yahoo! AnswersI have posted a link there to this topic so the OP can find my response.
Mathematics news on Phys.org
Hello Jacob,
The Leibniz criterion for the alternating series $\sum_{n=1}^{\infty} (-1)^{n-1}a_n$ says: if $a_n$ decrease monotonically to $0$ as a sequence of positive numbers when $n$ approaches infinity, i.e. then the alternating series converges. Moreover, let $S$ denote the sum of the series, then the partial sum $S_k =\sum_{n=1}^k (-1)^{n-1}a_n$ approximates $S$ with error bounded by the next omitted term: $\left | S_k - S \right|\leq a_{k+1}$. Then, $$a_{k+1}=\dfrac{1}{5^{k+1}(k+1)!}<0.0001 \Leftrightarrow 10\;000<5^{k+1}(k+1)!\qquad (*)$$ The smallest positive integer satisfying $(*)$ is $k=4$ so, $$S\approx \sum _{n=1}^4\frac{(-1)^n}{5^nn!}=\ldots$$ which approximate the sum of the series to four decimal places.
FAQ: Jacob's question at Yahoo Answers (Alternating series approximation)
What is the Alternating Series Approximation for Jacob's Question at Yahoo Answers?
The Alternating Series Approximation is a method used in calculus to approximate the value of a series that alternates between positive and negative terms. In Jacob's question, he is asking for the value of the series 1-1/2+1/3-1/4+...-1/n.
How do you solve Jacob's Question using the Alternating Series Approximation?
To solve Jacob's question, you can use the Alternating Series Approximation formula: S ≈ sn+1, where S is the sum of the series and sn+1 is the nth partial sum. In this case, the nth partial sum is equal to the sum of the first n terms of the series. So, for example, the 4th partial sum would be 1-1/2+1/3-1/4. By plugging in the appropriate values, you can approximate the value of the series.
What is the purpose of using the Alternating Series Approximation?
The Alternating Series Approximation is useful because it allows us to find the value of a series that may be difficult to calculate exactly. In some cases, the value of the series may not have a closed form solution, so using this approximation method can give us a good estimate of the value.
What are the limitations of the Alternating Series Approximation?
The Alternating Series Approximation is only applicable to series that alternate between positive and negative terms and where the terms decrease in absolute value. Additionally, the approximation may not be accurate if the series has a large number of terms or if the terms do not decrease quickly enough.
Can the Alternating Series Approximation be used for other types of series?
No, the Alternating Series Approximation is specifically designed for series that alternate between positive and negative terms. For other types of series, different approximation methods, such as the Taylor series approximation, may be more appropriate.
