MHB Jacobson Radical and Direct Sums - Bland, Proposition 6.1.4 ....
  • Thread starter Thread starter Math Amateur
    Radical Sums
The discussion revolves around understanding Proposition 6.1.4 from Paul E. Bland's "Rings and Their Modules," specifically how canonical injections relate the Jacobson radicals of modules. The key point is that Exercise 3 establishes that the image of the Jacobson radical of each module, under the canonical injections, is contained within the Jacobson radical of their direct sum. This means that for any element in the Jacobson radical of a module, its image under the injection also lies in the Jacobson radical of the combined module. Clarification is sought on why this mapping holds true, emphasizing the need for a deeper understanding of the radical properties in the context of direct sums. The conversation highlights the importance of Exercise 3 in solidifying these relationships.
Math Amateur
MHB
I am reading Paul E. Bland's book, "Rings and Their Modules".
I am focused on Section 6.1 The Jacobson Radical ... ...
I need help with the proof of Proposition 6.1.4 ... Proposition 6.1.4 and its proof read as follows:
In the above proof from Bland we read:"... ... If $$i_1 \ : \ M_1 \longrightarrow M_1 \oplus M_2$$ and $$i_2 \ : \ M_2 \longrightarrow M_1 \oplus M_2$$ are the canonical injections, then (a) of Exercise 3 shows that
$$i_k \ : \ \text{ Rad}(M_k) \longrightarrow \text{ Rad}(M_1 \oplus M_2) $$... ...
My question/problem/issue is that I cannot understand the meaning of the statement that (a) of Exercise 3 shows that
$$i_k \ : \ \text{ Rad}(M_k) \longrightarrow \text{ Rad}(M_1 \oplus M_2)$$ ... ...
How do the canonical injections $$i_k$$ apply to $$\text{ Rad}(M_k)$$ and $$\text{ Rad}(M_1 \oplus M_2)$$ ... ...Is it trivially simple in that $$\text{ Rad}(M_k) $$ is a set of elements of $$M_k$$ and so the canonical injection operates as usual? But then... why, exactly, do we need Exercise 3? Can someone explain in simple terms ... ... exactly what is going on ...
Peter
NOTE ... ... The above post refers to Exercise 3 of Bland, Section 6.1 so I am providing the text of that example ... as follows:
Hi Peter,
The Exercise was needed in order to establish $\operatorname{Rad}(M_1) \oplus \operatorname{Rad}(M_2) \subset \operatorname{Rad}(M_1\oplus M_2)$. Let $(x,y)$ be an element of $\operatorname{Rad}(M_1) \oplus \operatorname{Rad}(M_2)$. Then $(x,y) = (x,0) + (0,y) = i_1(x) + i_2(y)$. We want to get $i_1(x), i_2(y)\in \operatorname{Rad}(M_1\oplus M_2)$, for then the sum $i_1(x) + i_2(y)\in \operatorname{Rad}(M_1\oplus M_2)$. By the Exercise, $i_1$ maps $\operatorname{Rad}(M_1)$ into $\operatorname{Rad}(M_1\oplus M_2)$; since $x\in \operatorname{Rad}(M_1)$, then $i_1(x)\in \operatorname{Rad}(M_1\oplus M_2)$. Similarly, $i_2(y)\in \operatorname{Rad}(M_1\oplus M_2)$, as desired. As $(x,y)$ was arbitrary, $\operatorname{Rad}(M_1) \oplus \operatorname{Rad}(M_2) \subset \operatorname{Rad}(M_1\oplus M_2)$.
Euge said:
Hi Peter,
Thanks Euge ... really appreciate your help ...
just reflecting on the proof and what what you have said ...
Peter
Euge said:
Hi Peter,
Hi Euge,
Thanks for the post ... but I need some further help ... sorry if i am not following you exactly ...
You write:
" ... ... By the Exercise, $i_1$ maps $\operatorname{Rad}(M_1)$ into $\operatorname{Rad}(M_1\oplus M_2)$; since $x\in \operatorname{Rad}(M_1)$, then $i_1(x)\in \operatorname{Rad}(M_1\oplus M_2)$. Similarly, $i_2(y)\in \operatorname{Rad}(M_1\oplus M_2)$, as desired. ... ... ""I am unsure how exactly Exercise 1 shows that $i_1$ maps $\operatorname{Rad}(M_1)$ into $\operatorname{Rad}(M_1\oplus M_2)$ ... ... what part of Exercise 3 shows this ...??In particular I am unsure regarding exactly why $x\in \operatorname{Rad}(M_1)$ implies that $i_1(x)\in \operatorname{Rad}(M_1\oplus M_2)$ ... ... can you show me why this is true ... ? I mean, obviously if $$x \in M_1$$ then $$i_1(x) \in M_1 \oplus M_2$$ ... ... but why does it also follow for the radicals of $$M_1$$ and $$M_1 \oplus M_2$$ ... ?Hope you can help ...
Peter
Peter said:
Hi Euge,
You write:
Peter
Based on your reply, it would seem that you don't know what the $i_k$. In case you don't, $i_1 : M_1\to M_1 \oplus M_2$ is given by $i_1(x) = (x,0)$, and $i_2 : M_2 \to M_1 \oplus M_2$ is given by $i_2(y) = (0,y)$. The part I used from Exercise 3(a) was just the result in its first sentence.
Take $f = i_k$, $M = M_k$, and $N = M_1 \oplus M_2$ in the first sentence of Exercise 3(a). The result gives $i_k(\operatorname{Rad}(M_k)) \subset \operatorname{Rad}(M_1\oplus M_2)$. In other words, $i_k$ maps $\operatorname{Rad}(M_k)$ into $\operatorname{Rad}(M_1 \oplus M_2)$. So you can see that if $x\in \operatorname{Rad}(M_k)$, then $i_k(x) \in \operatorname{Rad}(M_1\oplus M_2)$, by the very condition that $i_k(\operatorname{Rad}(M_k)) \subset \operatorname{Rad}(M_1\oplus M_2)$.
I am studying the mathematical formalism behind non-commutative geometry approach to quantum gravity. I was reading about Hopf algebras and their Drinfeld twist with a specific example of the Moyal-Weyl twist defined as F=exp(-iλ/2θ^(μν)∂_μ⊗∂_ν) where λ is a constant parametar and θ antisymmetric constant tensor. {∂_μ} is the basis of the tangent vector space over the underlying spacetime Now, from my understanding the enveloping algebra which appears in the definition of the Hopf algebra...
  • · Replies 25 ·
