I Jansky: When Physics Majors Should Expect It
  • I
  • Thread starter Thread starter strangerep
    Physics
The discussion centers on when physics students should first encounter the unit "Jansky" in their studies. It is suggested that this unit, primarily used in radio astronomy, should not be assumed as prior knowledge in general physics courses. Participants agree that exposure to the Jansky should ideally occur during specialized astronomy courses rather than earlier in a physics degree. One contributor shares their frustration after encountering the unit unexpectedly while working through a cosmology textbook, highlighting a gap in educational preparation. Overall, the consensus is that the Jansky is not essential knowledge until students delve into specific subfields like radio astronomy.
strangerep
At what point during study for a reputable physics degree should one normally encounter the "Jansky"?
I.e., at what point is it reasonable for a lecturer (or textbook writer!) to assume the existence and meaning of "Jansky" as basic prior knowledge?
Astronomy news on Phys.org
For a general physics degree, I would say it is not reasonable to assume any knowledge. It is a unit mostly seeing use in a particular subfield and unless students are specialising in that particular subfield they will most likely not be exposed or have very limited exposure.
One should only encounter SI units as part of a degree. Avoid the non-SI Jansky. The Jansky should be ignored until one makes experimental observations in radio astronomy.
Likes vanhees71 and Motore
I made it through an entire physics degree without coming across it as far as I recall. So I'd say you introduce it in the first specialist astronomy course.
Thank you all.
In case anyone is wondering, I came across this unit the hard way...
I've decided to try and improve my knowledge of the non-GR aspects of cosmology. So I've started working through Dodelson & Schmidt "Modern Cosmology" 2nd Ed (2021), intending to do every exercise properly. In ch1 (sigh), Ex 1.4, they ask the reader to convert from the CMB black body ##I_\nu## intensity-vs-frequency formula to the units on their graph Fig 1.7. Their vertical axis is labelled MJy/sr, which I thought meant Megajoule-year/sr (and now I don't know whether to sigh or laugh). Being determined to complete this should-be-simple exercise without looking at the solution, I wasted several hours. They only explain in their solution at the end of the book that the vertical axis is in these weird units called "Janskys".
Oh well, I guess I'll just have to re-acclimatize myself to the sloppy way these things are "taught" in physics courses, as opposed to (say) applied maths.
BTW, does anyone have suggestions for alternate very modern cosmology textbooks that force you to work through all the seriously tedious detail?
As usual, Weinberg is a very good but tedious choice. It's not that "modern" anymore given the quick development of cosmology, but it's reasonably new, I'd say:
S. Weinberg, Cosmology, Oxford University Press (2008)
Is a homemade radio telescope realistic? There seems to be a confluence of multiple technologies that makes the situation better than when I was a wee lad: software-defined radio (SDR), the easy availability of satellite dishes, surveillance drives, and fast CPUs. Let's take a step back - it is trivial to see the sun in radio. An old analog TV, a set of "rabbit ears" antenna, and you're good to go. Point the antenna at the sun (i.e. the ears are perpendicular to it) and there is...
3I/ATLAS, also known as C/2025 N1 (ATLAS) and formerly designated as A11pl3Z, is an iinterstellar comet. It was discovered by the Asteroid Terrestrial-impact Last Alert System (ATLAS) station at Río Hurtado, Chile on 1 July 2025. Note: it was mentioned (as A11pl3Z) by DaveE in a new member's introductory thread. https://www.physicsforums.com/threads/brian-cox-lead-me-here.1081670/post-7274146 https://earthsky.org/space/new-interstellar-object-candidate-heading-toward-the-sun-a11pl3z/ One...
