iamjon.smith
- 117
- 3
JAVA Animated Logo **DUE TODAY** HELP!
My instructor has provided the code to use, we were told to simply modify the images for the program to work with our logo. The code comes straight from the textbook.
I have followed the steps of my instructor but when I run the program I get the following error:
Exception in thread "main" java.lang.NullPointerException
at javax.swing.ImageIcon.<init>(ImageIcon.java:167)
at LogoAnimatorJPanel.<init>(LogoAnimatorJPanel.java:39)
at LogoAnimator.main(LogoAnimator.java:19)
Java Result: 1
Code is as follows:
class
main class:
I am using a folder named Images to contain all of the images for the animation. The images are named "1" through "113" respectively, for a total of 113 images. They were created in paint and are .png images. I have included the first three images as attachments for you to use.
Please, help me as soon as possible. I just need to be pointed in the right direction. I have run the debugger and set breakpoints to try and figure out what is wrong, but I am lost in the sauce.
Java Result: 1
Code is as follows:
class
Code:
* To change this template, choose Tools | Templates
* and open the template in the editor.
* @author Jon and Jessica
// Fig. 21.2: LogoAnimatorJPanel.java
// Animation of a series of images.
import java.awt.Dimension;
import java.awt.event.ActionEvent;
import java.awt.event.ActionListener;
import java.awt.Graphics;
import javax.swing.ImageIcon;
import javax.swing.JPanel;
import javax.swing.Timer;
public class LogoAnimatorJPanel extends JPanel
private final static String IMAGE_NAME = "1"; // base image name
protected ImageIcon images[]; // array of images
private final int TOTAL_IMAGES = 112; // number of images
private int currentImage = 0; // current image index
private final int ANIMATION_DELAY = 50; // millisecond delay
private int width; // image width
private int height; // image height
private Timer animationTimer; // Timer drives animation
// constructor initializes LogoAnimatorJPanel by loading images
public LogoAnimatorJPanel()
images = new ImageIcon[ TOTAL_IMAGES ];
// load 30 images
for ( int count = 0; count < images.length; count++ )
images[ count ] = new ImageIcon( getClass().getResource(
"Images/" + IMAGE_NAME + count + ".png" ) );
// this example assumes all images have the same width and height
width = images[ 0 ].getIconWidth(); // get icon width
height = images[ 0 ].getIconHeight(); // get icon height
} // end LogoAnimatorJPanel constructor
// display current image
public void paintComponent( Graphics g )
super.paintComponent( g ); // call superclass paintComponent
images[ currentImage ].paintIcon( this, g, 0, 0 );
// set next image to be drawn only if Timer is running
if ( animationTimer.isRunning() )
currentImage = ( currentImage + 1 ) % TOTAL_IMAGES;
} // end method paintComponent
// start animation, or restart if window is redisplayed
public void startAnimation()
if ( animationTimer == null )
currentImage = 0; // display first image
// create timer
animationTimer =
new Timer( ANIMATION_DELAY, new TimerHandler() );
animationTimer.start(); // start Timer
} // end if
else // animationTimer already exists, restart animation
if ( ! animationTimer.isRunning() )
animationTimer.restart();
} // end else
} // end method startAnimation
// stop animation Timer
public void stopAnimation()
animationTimer.stop();
} // end method stopAnimation
// return minimum size of animation
public Dimension getMinimumSize()
return getPreferredSize();
} // end method getMinimumSize
// return preferred size of animation
public Dimension getPreferredSize()
return new Dimension( width, height );
} // end method getPreferredSize
// inner class to handle action events from Timer
private class TimerHandler implements ActionListener
// respond to Timer's event
public void actionPerformed( ActionEvent actionEvent )
repaint(); // repaint animator
} // end method actionPerformed
} // end class TimerHandler
} // end class LogoAnimatorJPanel
* (C) Copyright 1992-2007 by Deitel & Associates, Inc. and *
* Pearson Education, Inc. All Rights Reserved. *
* DISCLAIMER: The authors and publisher of this book have used their *
* best efforts in preparing the book. These efforts include the *
* development, research, and testing of the theories and programs *
* to determine their effectiveness. The authors and publisher make *
* no warranty of any kind, expressed or implied, with regard to these *
* programs or to the documentation contained in these books. The authors *
* and publisher shall not be liable in any event for incidental or *
* consequential damages in connection with, or arising out of, the *
* furnishing, performance, or use of these programs. *
main class:
Code:
// Fig. 21.3: LogoAnimator.java
import javax.swing.JFrame;
// execute animation in a JFrame
public static void main( String args[] )
LogoAnimatorJPanel animation = new LogoAnimatorJPanel();
JFrame window = new JFrame( "Animator test" ); // set up window
window.setDefaultCloseOperation( JFrame.EXIT_ON_CLOSE );
window.add( animation ); // add panel to frame
window.pack(); // make window just large enough for its GUI
window.setVisible( true ); // display window
animation.startAnimation(); // begin animation
} // end main
