schapman22
- 74
"Implement a new method for the bag class. The new method allows you to subtract the contents of one bag from another. For example, suppose x has seven copies of the number 3 and y has two copies of the number 3. Then after activating x.subtract(y), the bag x will have five remaining copies of the number 3. "
This is the bag class, it is implemented with a linked list. It uses another class called IntNode, the methods from this class can be used as well so i add both classes.
Code:
// File: IntLinkedBag.java from the package edu.colorado.linked
// Complete documentation is available from the IntLinkedBag link in:
// http://www.cs.colorado.edu/~main/docs
package edu.colorado.collections;
import edu.colorado.nodes.IntNode;
* An IntLinkedBag is a collection of int numbers.
* @note
* (1) Beyond Int.MAX_VALUE elements, countOccurrences,
* size, and grab are wrong.
* <p>
* (2) Because of the slow linear algorithms of this class, large bags will have
* poor performance.
* @see
* <A HREF="../../../../edu/colorado/collections/IntLinkedBag.java">
* Java Source Code for this class
* (www.cs.colorado.edu/~main/edu/colorado/collections/IntLinkedBag.java)
* </A>
* @author Michael Main
* <A HREF="mailto:main@colorado.edu"> (main@colorado.edu) </A>
* @version
* March 6, 2002
* @see IntArrayBag
* @see LinkedBag
public class IntLinkedBag implements Cloneable
// Invariant of the IntLinkedBag class:
// 1. The elements in the bag are stored on a linked list.
// 2. The head reference of the list is in the instance variable
// head.
// 3. The total number of elements in the list is in the instance
// variable manyNodes.
private IntNode head;
private int manyNodes;
* Initialize an empty bag.
* @param - none
* @postcondition
* This bag is empty.
public IntLinkedBag( )
head = null;
manyNodes = 0;
* Add a new element to this bag.
* @param element
* the new element that is being added
* @postcondition
* A new copy of the element has been added to this bag.
* @exception OutOfMemoryError
* Indicates insufficient memory a new IntNode.
public void add(int element)
head = new IntNode(element, head);
manyNodes++;
* Add the contents of another bag to this bag.
* @param addend
* a bag whose contents will be added to this bag
* @precondition
* The parameter, addend, is not null.
* @postcondition
* The elements from addend have been added to this bag.
* @exception NullPointerException
* Indicates that addend is null.
* Indicates insufficient memory to increase the size of the bag.
public void addAll(IntLinkedBag addend)
IntNode[ ] copyInfo;
// The precondition indicates that addend is not null. If it is null,
// then a NullPointerException is thrown here.
if (addend.manyNodes > 0)
copyInfo = IntNode.listCopyWithTail(addend.head);
copyInfo[1].setLink(head); // Link the tail of copy to my own head...
head = copyInfo[0]; // and set my own head to the head of the copy.
manyNodes += addend.manyNodes;
* Add new elements to this bag. If the new elements would take this
* bag beyond its current capacity, then the capacity is increased
* before adding the new elements.
* @param elements
* (a variable-arity argument)
* one or more new elements that are being inserted
* @postcondition
public void addMany(int... elements)
// Activate the ordinary add method for each integer in the
// elements array.
for (int i : elements)
add(i);
* Generate a copy of this bag.
* @param - none
* @return
* The return value is a copy of this bag. Subsequent changes to the
* copy will not affect the original, nor vice versa. Note that the return
* value must be type cast to an IntLinkedBag before it can be used.
* Indicates insufficient memory for creating the clone.
public Object clone( )
{ // Clone a nIntLinkedBag object.
IntLinkedBag answer;
try
answer = (IntLinkedBag) super.clone( );
catch (CloneNotSupportedException e)
{ // This exception should not occur. But if it does, it would probably
// indicate a programming error that made super.clone unavailable.
// The most common error would be forgetting the "Implements Cloneable"
// clause at the start of this class.
throw new RuntimeException
("This class does not implement Cloneable");
answer.head = IntNode.listCopy(head);
return answer;
* Accessor method to count the number of occurrences of a particular element
* in this bag.
* @param target
* the element that needs to be counted
* @return
* the number of times that target occurs in this bag
public int countOccurrences(int target)
int answer;
IntNode cursor;
answer = 0;
cursor = IntNode.listSearch(head, target);
while (cursor != null)
{ // Each time that cursor is not null, we have another occurrence of
// target, so we add one to answer and then move cursor to the next
// occurrence of the target.
answer++;
cursor = cursor.getLink( );
cursor = IntNode.listSearch(cursor, target);
return answer;
* Accessor method to retrieve a random element from this bag.
* @param - none
* @precondition
* This bag is not empty.
* @return
* a randomly selected element from this bag
* @exception IllegalStateException
* Indicates that the bag is empty.
public int grab( )
int i;
IntNode cursor;
if (manyNodes == 0)
throw new IllegalStateException("Bag size is zero");
i = (int)(Math.random( ) * manyNodes) + 1;
cursor = IntNode.listPosition(head, i);
return cursor.getData( );
* Remove one copy of a specified element from this bag.
* @param target
* the element to remove from the bag
* @postcondition
* If target was found in the bag, then one copy of
* target has been removed and the method returns true.
* Otherwise the bag remains unchanged and the method returns false.
public boolean remove(int target)
IntNode targetNode; // The node that contains the target
targetNode = IntNode.listSearch(head, target);
if (targetNode == null)
// The target was not found, so nothing is removed.
return false;
else
{ // The target was found at targetNode. So copy the head data to targetNode
// and then remove the extra copy of the head data.
targetNode.setData(head.getData( ));
head = head.getLink( );
manyNodes--;
return true;
* Determine the number of elements in this bag.
* @param - none
* @return
* the number of elements in this bag
public int size( )
return manyNodes;
* Create a new bag that contains all the elements from two other bags.
* @param b1
* the first of two bags
* @param b2
* the second of two bags
* @precondition
* Neither b1 nor b2 is null.
* @return
* the union of b1 and b2
* @exception IllegalArgumentException
* Indicates that one of the arguments is null.
* Indicates insufficient memory for the new bag.
public static IntLinkedBag union(IntLinkedBag b1, IntLinkedBag b2)
// The precondition requires that neither b1 nor b2 is null.
// If one of them is null, then addAll will throw a NullPointerException.
IntLinkedBag answer = new IntLinkedBag( );
answer.addAll(b1);
answer.addAll(b2);
return answer;
public void getBagData()
IntNode b1 = this.head;
for(IntNode cursor=b1; cursor!=null; cursor=cursor.getLink())
System.out.println(cursor.getData());
this is my incomplete attempt.
Code:
public IntLinkedBag subtract(IntLinkedBag b2)
IntNode bag1 = this.head;
IntNode bag2 = b2.head;
for(IntNode cursor=bag1; cursor!=null; cursor=cursor.getLink())
//remove if same as bag2
return this;
