iamjon.smith
- 117
- 3
Create a class Product that stores product ID, product name, and price. Using the Comparable interface, create a compareTo() method for your Product class that gives you a default sort order based on product ID.
Create a test application that creates a list of Products, sorts them by product ID and prints the sorted Product list.
Hint: You may want to look into overriding toString() method to provide a readable string representation of Product object.
I have created my classes, and the arraylist to hold all of the information and the program runs correctly and prints all data to the screen. The only thing that I need to do now is make use of the Comparable interface, and using a compareTo() method, sort the data before the output. My current code is as stands:
Product subclass:
And my main class:
Output:
run:
10401 Widgets $3.95
10522 Dingbats $0.99
10401 Thingamabogs $1.25
10402 Thingamajigs $8.38
10001 Doohickies $4.56
10101 SingleStacks $6.32
10203 DoubleSixes $0.23
10402 Wadgets $5.45
10522 Wodgets $6.26
10001 Thathickies $8.48
11011 Thishickies $9.99
BUILD SUCCESSFUL (total time: 0 seconds)
I would like to have the output in ascending order, therefore the compareTo method would come in handy, and fill the project requirements.
Product subclass:
Code:
* To change this template, choose Tools | Templates
* and open the template in the editor.
package myInventory;
import java.text.DecimalFormat;
* @author Jon and Jessica
public class Product {
int productID;
String productName;
double price;
// no-argument constructor calls other constructor with default values
public Product()
this( 0, "Thingy", 0.0 ); // call three-argument constructor
} // end no-argument CityRecord constructor
// initialize a record
public Product(int productID, String productName, double price) {
this.productID = productID;
this.productName = productName;
this.price = price;
}// end three-argument CityRecord constructor
// Decimal format constructor
DecimalFormat money = new DecimalFormat("$0.00");
public double getPrice() {
return price;
public void setPrice(double price) {
this.price = price;
public int getProductID() {
return productID;
public void setProductID(int productID) {
public String getProductName() {
return productName;
public void setProductName(String productName) {
// Overridden toString() method to print Inventory
@Override
public String toString(){
return ( productID + " " + productName + " " + money.format(price) + "\n");
public int compareTo(Object obj){
Product tmp = (Product)obj;
[COLOR="Red"]// got lost here trying to figure out the comparable interface and compareTo method[/COLOR]
return productID;
And my main class:
Code:
import java.io.*;
import java.util.*;
public abstract class ProductTest implements Comparable < Product >{
* @param args the command line arguments
public static void main(String[] args) {
int productID = 0;
String productName = "";
double price = 0.0;
Scanner scanner = null; // scanner to read the file
Product inventoryRecord = new Product( productID, productName, price); // Product inventory constructor
// Create an array list that can grow as data is input by user
ArrayList<Product> inventoryList = new ArrayList<Product>();
// Add elements to array list
inventoryList.add(inventoryRecord);
try{
scanner = new Scanner(new File("inventory.txt")); // Scanner construct that reads the input file
while (scanner.hasNextLine())//Checks if there's any more lines
inventoryRecord.productID = scanner.nextInt(); // reads to first space in line, sets the First Name
inventoryRecord.productName = scanner.next(); // reads to second space in line, sets the Last Name
inventoryRecord.price = scanner.nextDouble(); // reads to the next space in line, sets Street Number
for (Product rec : inventoryList)
System.out.print(rec);
// System.out.print(inventoryRecord.toString());
catch (Exception e)
System.err.println("End of File");
Output:
run:
10401 Widgets $3.95
10402 Wadgets $5.45
10522 Wodgets $6.26
