Java Java- CompareTo with Binary Search Tree
The discussion centers on implementing a method to check if a given String name exists within a Binary Search Tree (BST) of Dog objects. The user is struggling with the containsRecursive() method, which is currently set up to compare Dog objects based on weight rather than name. A suggested solution involves modifying the containsRecursive() method to compare names directly, using String comparison instead of relying on the tree's weight-based structure. This adjustment allows for a more accurate search for Dog names within the BST. The conversation highlights the importance of aligning the search criteria with the structure of the data being used.
Smiles1
I am having a hard time implementing comparing a given String name with the names of the Dog objects in my binary Search Tree.
The problem comes from my containsRecursive() method. I need to use a String name to find if the name is already in my Binary Search Tree.Here's what I've tried:
Creating my own compareTo() method in my inner Node class
Code:
public int compareTo(Dog t) {
            int comparisonVal = this.data.getName().compareTo(t.getName());
            if (this.data.getName().compareTo(t.getName()) == 0) {
                return 0;
            } else if (this.data.getName().compareTo(t.getName()) < 0) {
                return -1;
            } else {
                return 1;
I've also tried creating a compareByName() method in my dog class.
Code:
public int compareByName(Dog otherDog) {
        return name.compareTo(otherDog.name);
Neither of these are working as I tried accessing them within my containsRecursive() and the program always returns false when it should return true because the name matches.. I understand the overall formula for creating a compareTo() but I'm not sure how to make it fit in my program.
Here is my App Class:
Code:
public class App {
    public static void main(String[] args) {
        BSTree dogOTree = new BSTree();
        dogOTree.addDog("Jackson", 65.28);
        dogOTree.addDog("Tick", 69.88);
        dogOTree.addDog("Nia", 75.44);
        //Layla is my dog! She was named after the Eric Clapton song.
        dogOTree.addDog("Layla", 32.02);
        dogOTree.addDog("Bagel", 21.06);
        dogOTree.addDog("Milo", 24.73);
//        Dog dog1 = new Dog("BaconEater", 44.88);
        dogOTree.displayInOrder();
        System.out.println(dogOTree.containsDog("Layla"));
Here is my BSTree Class:
Code:
public class BSTree{
    class Node {
        Dog data;
        Node leftChild;
        Node rightChild;
        Node(Dog data) {
            this.data = data;
            this.leftChild = null;
            this.rightChild = null;
                return 0;
                return -1;
            } else {
                return 1;
    private Node root;
    public BSTree() {
        root = null;
    public boolean add(Dog data) {
        root = addRecursive(root, data);
        return true;
    private Node addRecursive(Node current, Dog data) {
        if (current == null) { // If it's root
            return new Node(data);
        } else if (data.getWeight() < current.data.getWeight()) { //navigate left
            //Vrrooom vrroom go left
            current.leftChild = addRecursive(current.leftChild, data);
            return current;
        } else if (data.getWeight() > current.data.getWeight()) {
            current.rightChild = addRecursive(current.rightChild, data);
            return current;
        } else {
            return current;
    public boolean containsDog(String name) {
        return containsRecursive(root, name);
        //Start at the root and looks for data
    // The problem is here!
    private boolean containsRecursive(Node current, String name) {
        Dog tempDog = new Dog(name, 0.0);
            return false;
        if (tempDog.getName().compareTo(current.data.getName()) == 0) {
            return true;
        } else if (tempDog.getName().compareTo(current.data.getName()) < 0) { //Go left!
            return containsRecursive(current.leftChild, name);
        } else {
            return containsRecursive(current.rightChild, name);
    While node is not null
    recursively traverse left child
    Display node's value
    recursively traverse right child
    public void displayInOrder() {
        inOrderTraversal(root);
    private void inOrderTraversal(Node node) {
        if (node != null) {
            inOrderTraversal(node.leftChild);
            System.out.println(" " + node.data);
            inOrderTraversal(node.rightChild);
    //Adds a Dog object to the tree.  Returns true on success or false on failure (if Dog with that name already exists).
      public boolean addDog(String name, double weight){
          return this.add(new Dog(name, weight));
//     public double getDogWeight(String name){
//         //Returns the weight of the dog with the specified name if it exists in the tree, or returns -1 otherwise.
//         //return
Annndd here is my Dog class.
Code:
public class Dog {
    private String name;
    private double weight;
    public Dog(String name, double weight) {
        this.name = name;
        this.weight = weight;
    public String getName() {
        return name;
    public void setName(String name) {
        this.name = name;
    public double getWeight() {
        return weight;
    public void setWeight(double weight) {
    @Override
    public String toString() {
        return "Dog {" + " name= " + name + ", weight= " + weight;
Any help is greatly appreciated! With a thank you in advance.
Technology news on Phys.org
Your problem is that the order in your binary tree is by weight, not by name. So to search by name, there's really no alternative except to examine each node. Here's a corrected method:
Code:
         return false;
      if (name.compareToIgnoreCase(current.data.getName()) == 0) {
         return (true);
      boolean inLeft = containsRecursive(current.leftChild, name);
      if (!inLeft) {
         return (containsRecursive(current.rightChild, name));
      return (true);
THANK YOU! Thank you for the help. :-)
Hmm...Java is probably going to be what I have to tackle next, unfortunately...thanks here for help)
Thread 'Star maps using Blender'
Blender just recently dropped a new version, 4.5(with 5.0 on the horizon), and within it was a new feature for which I immediately thought of a use for. The new feature was a .csv importer for Geometry nodes. Geometry nodes are a method of modelling that uses a node tree to create 3D models which offers more flexibility than straight modeling does. The .csv importer node allows you to bring in a .csv file and use the data in it to control aspects of your model. So for example, if you...
I tried a web search "the loss of programming ", and found an article saying that all aspects of writing, developing, and testing software programs will one day all be handled through artificial intelligence. One must wonder then, who is responsible. WHO is responsible for any problems, bugs, deficiencies, or whatever malfunctions which the programs make their users endure? Things may work wrong however the "wrong" happens. AI needs to fix the problems for the users. Any way to...
