Yoyo_Guru
- 33
I have a program where the user selects image icons in one JPanel and can place them in another JPanel. The program saves the position of the icons as an array of integers where each integer represents the different icons. I need to also save the final result as a .gif image because otherwise it will repaint the icons everytime paint method is called and creates a lot of lag. Basically I want to take the image icons in the JPanel and save them as one .gif file. I've tried googling it but have not been able to determine how. Does anyone have any advice or could show me how to do it? I've gotten it to save the text file but not the image of all the icons together. Here is the code:
Here is the JPanel and JFrame where the tiles can be placed
Here is the code for the selector
and here is the code where it is saved
Code:
public class Map extends JFrame
final int AREA_SIZE_X = 100;
final int AREA_SIZE_Y = 100;
JFrame sWindow;
mapPanel mPanel;
JScrollPane scrollPane;
Map() throws IOException
sWindow = new Selection(this);
sWindow.setDefaultCloseOperation(EXIT_ON_CLOSE);
sWindow.setSize(270,700);
sWindow.setVisible(true);
mPanel = new mapPanel(sWindow);
this.getContentPane().setLayout(new BorderLayout());
scrollPane = new JScrollPane(mPanel);
this.getContentPane().add(scrollPane, BorderLayout.WEST);
mPanel.requestFocus(); // Give the panel focus.
this.setTitle("Map maker");
this.setLocation(400, 0);
this.setResizable(false);
this.pack();
class mapPanel extends JPanel implements MouseListener, MouseMotionListener
//int[][][] back1;
// int[][][] back2;
boolean topLayer=false;
Point mouseLocation;
Point myMouse;
int[][][] tiles = new int[AREA_SIZE_X][AREA_SIZE_Y][4];
ArrayList<BufferedImage> bFS;
//ArrayList<ImageIcon> icons=new <ImageIcon>ArrayList();
BufferedImage tempImage;
Selection sWindow;
public mapPanel(JFrame selWindow)
this.addMouseMotionListener(this);
sWindow = (Selection) selWindow;
bFS = sWindow.getBuffered();
for (int i = 0; i < AREA_SIZE_X; i++)
for (int j = 0; j < AREA_SIZE_Y; j++)
for (int k = 0; k < 4; k++)
tiles[i][j][k] = -1;
// back1= tiles.clone();
// back2=tiles.clone();
this.setBackground(Color.white);
this.setPreferredSize(new Dimension(10*AREA_SIZE_X, 10*AREA_SIZE_Y));
this.addMouseListener(this);
// this.addKeyListener(this); // This class has its own key listeners.
this.setFocusable(true); // Allow panel to get focus
sWindow.updateTiles(tiles);
public void fillBackground()
tiles[i][j][0]= sWindow.getSelected();
for (int k = 1; k < 4; k++)
public void paintComponent(Graphics g)
super.paintComponent(g);
g.setColor(Color.white);
g.fillRect(0, 0, AREA_SIZE_X * 20, AREA_SIZE_Y * 20);
mouseLocation = this.getMousePosition();
if (tiles[i][j][k] != -1)
g.drawImage(bFS.get(tiles[i][j][k]), i * 20, j * 20, this);
//System.out.println(this.hasFocus());
if (this.hasFocus()&&this.contains(mouseLocation))
g.drawImage(bFS.get(sWindow.getSelected()), mouseLocation.x - 20, mouseLocation.y - 20, this);
// g.drawImage(bFS.get(sWindow.getSelected()), mouseLocation.x - 20, mouseLocation.y - 20, this);
g.setColor(Color.red);
g.drawRect(((mouseLocation.x - 10) / 20) * 20, ((mouseLocation.y - 10) / 20) * 20, 20, 20);
@Override
public void mouseClicked(MouseEvent e)
// updateHistogram(tiles);
topLayer=sWindow.isLayered();
// System.out.println(this.hasFocus());
myMouse = this.getMousePosition();
// System.out.println((myMouse.x - 10) / 20+" "+(myMouse.y) / 20);
if(topLayer)
for(int k=0;k<4;k++)
if(tiles[(myMouse.x - 10) / 20][(myMouse.y - 10) / 20][k]==-1)
tiles[(myMouse.x - 10) / 20][(myMouse.y - 10) / 20][k] = sWindow.getSelected();
break;
//System.out.println(tiles[(myMouse.x - 10) / 20][(myMouse.y - 10) / 20][0]);
// System.out.println(tiles[(myMouse.x - 10) / 20][(myMouse.y - 10) / 20][1]);
else
tiles[(myMouse.x - 10) / 20][(myMouse.y - 10) / 20][0] = sWindow.getSelected();
tiles[(myMouse.x - 10) / 20][(myMouse.y - 10) / 20][1] = -1;
tiles[(myMouse.x - 10) / 20][(myMouse.y - 10) / 20][2] = -1;
tiles[(myMouse.x - 10) / 20][(myMouse.y - 10) / 20][3] = -1;
//tiles[1][1] = sWindow.getSelected();
//System.out.println(sWindow.getSelected());
this.repaint();
@Override
public void mousePressed(MouseEvent e)
@Override
public void mouseReleased(MouseEvent e)
@Override
public void mouseEntered(MouseEvent e)
this.requestFocus();
@Override
public void mouseExited(MouseEvent e)
//sWindow.requestFocusInWindow()
sWindow.requestFocus();
@Override
public void mouseDragged(MouseEvent e)
if(topLayer)
break;
else
this.repaint();
@Override
public void mouseMoved(MouseEvent e)
// System.out.println("moved");
this.repaint();
Code:
public class Selection extends JFrame
selectionPanel panel;
public Selection(Map mapFrame) throws IOException
panel = new selectionPanel(this, mapFrame);
// panel.setLayout(new BorderLayout());
// JLabel instructions = new JLabel("<html><ul><li>Type text.</li>"
// + "<li>Use arrow keys to move text.</li>"
// + "<li>Press shift arrows to move faster.</li></html>");
// this.getContentPane().add(instructions, BorderLayout.NORTH);
scrollPane = new JScrollPane(panel);
//setViewport(panel);
scrollPane.setVerticalScrollBarPolicy(ScrollPaneConstants.VERTICAL_SCROLLBAR_ALWAYS);
panel.requestFocus(); // Give the panel focus.
this.setTitle("Texture Selecter");
this.pack();
public int getSelected()
//System.out.println(panel.selected);
return panel.selected;
public ArrayList<BufferedImage> getBuffered()
return panel.bFS;
public boolean isLayered()
return panel.layerB.isSelected();
public void updateTiles(int[][][] updatedTiles)
panel.updatePanelTiles(updatedTiles);
class selectionPanel extends JPanel implements MouseListener
Map map;
boolean layered = false;
ArrayList<ImageIcon> icons = new ArrayList<ImageIcon>();
protected ArrayList<JButton> buttons = new ArrayList<JButton>();
ArrayList<BufferedImage> bFS = new ArrayList<BufferedImage>();
int selected = 1;
File file;
JRadioButton layerB;
JButton bSave;
JButton bBackground;
JButton bOpen;
int tiles[][][];
Selection select;
selectionPanel(Selection sel, Map mapFrame) throws IOException
map = mapFrame;
select = sel;
layerB = new JRadioButton("Layer");
this.add(layerB);
layerB.addMouseListener(this);
bSave = new JButton("SAVE");
bSave.addMouseListener(this);
this.add(bSave);
bOpen = new JButton("OPEN");
bOpen.addMouseListener(this);
this.add(bOpen);
bBackground=new JButton("BACKGROUND");
bBackground.addMouseListener(this);
this.add(bBackground);
icons.add(createImageIcon("textures/0.gif"));
JButton tempButton = new JButton("DELETE", icons.get(0));
buttons.add(tempButton);
buttons.get(0).addMouseListener(this);
buttons.get(0).setVerticalTextPosition(AbstractButton.BOTTOM);
buttons.get(0).setHorizontalTextPosition(AbstractButton.CENTER);
file = new File("textures/0.gif");
tempImage = ImageIO.read(file);
bFS.add(tempImage);
this.add(buttons.get(0));
int counter = 1;
while (!(createImageIcon("textures/" + (counter) + ".gif") == null))
icons.add(createImageIcon("textures/" + (counter) + ".gif"));
tempButton = new JButton("" + counter, icons.get(counter));
buttons.get(counter).addMouseListener(this);
buttons.get(counter).setVerticalTextPosition(AbstractButton.BOTTOM);
buttons.get(counter).setHorizontalTextPosition(AbstractButton.CENTER);
//file=new File(RouteBuilderv2.class.getResource("textures/" + (counter) + ".gif").getFile());
file = new File("textures/" + (counter) + ".gif");
// System.out.println("textures/" + (counter) + ".gif");
//System.out.println(file.canRead());
// System.out.println(file.getAbsoluteFile());
bFS.add(tempImage);
this.add(buttons.get(counter));
counter++;
//adds each icon to array without hardcoding number of icons in
this.setPreferredSize(new Dimension(250, 15 * buttons.size()));
protected static ImageIcon createImageIcon(String path) throws MalformedURLException
//java.net.URL imgURL = RouteBuilderv2.class.getResource(path);
//java.net.URL imgURL=new URL(path);
File someFile=new File(path);
if (someFile.exists())
//System.out.println(path);
return new ImageIcon(path);
else
return null;
public void updatePanelTiles(int[][][] updatedTiles)
tiles = updatedTiles;
@Override
for (int i = 0; i < buttons.size(); i++)
if (buttons.get(i).equals(e.getComponent()))
selected = i;
//System.out.println(selected);
if(e.getComponent().equals(bBackground))
map.mPanel.fillBackground();
if (e.getComponent().equals(bSave))
Saver saver = new Saver(tiles);
saver.setVisible(true);
saver.requestFocus();
if (e.getComponent().equals(bOpen))
Opener opener = new Opener(select);
opener.setVisible(true);
opener.requestFocus();
public void updateFileTiles(int[][][] fileTiles)
tiles = fileTiles;
map.mPanel.tiles = tiles;
map.mPanel.repaint();
@Override
@Override
@Override
@Override
Code:
public class Saver extends JFrame
SaverPanel filePanel;
public Saver(int[][][] tiles)
filePanel = new SaverPanel(tiles,this);
this.getContentPane().add(filePanel, BorderLayout.WEST);
filePanel.requestFocus(); // Give the panel focus.
this.setTitle("Save");
this.setAlwaysOnTop(rootPaneCheckingEnabled);
this.pack();
class SaverPanel extends JPanel implements MouseListener, ActionListener
final JTextField x = new JTextField(20);
final JTextField y = new JTextField(20);
JButton done;
int[][][] saveTiles;
Saver closeReference;
public SaverPanel(int[][][] tiles,Saver closeR)
closeReference=closeR;
done=new JButton("SAVE");
done.addMouseListener(this);
JLabel xLabel=new JLabel();
xLabel.setText("x: ");
xLabel.setBounds(0, 50, 50, 30);
this.add(xLabel);
saveTiles = tiles;
x.setBounds(50, 50, 50, 20);
x.addActionListener(this);
this.add(x);
JLabel yLabel=new JLabel();
yLabel.setText("y: ");
yLabel.setBounds(0, 100, 50, 30);
this.add(yLabel);
y.setBounds(50, 100, 50, 20);
y.addActionListener(this);
this.add(y);
this.add(done);
this.setPreferredSize(new Dimension(250, 250));
public void save(int[][][] tiles) throws IOException
String fName = x.getText() + " x " + y.getText();
// Writer writer = null;
File fileNew = new File(fName);
//make variable for name to be saved
FileWriter fWriter=new FileWriter(fileNew);
BufferedWriter writer = new BufferedWriter(fWriter);
String toBeSaved=""+tiles[i][j][0];
writer.write(toBeSaved + ' ');
toBeSaved=""+tiles[i][j][k];
writer.flush();
//fWriter.flush();
// System.out.println(i+" "+j);
writer.close();
//fWriter.close();
// writer.close();
@Override
if (e.getComponent().equals(done))
if (x.getText() != null && y.getText() != null)
try
this.save(saveTiles);
closeReference.dispose();
catch (IOException ex)
Logger.getLogger(SaverPanel.class.getName()).log(Level.SEVERE, null, ex);
else
//display message to fill ouy x and y
@Override
@Override
@Override
@Override
@Override
public void actionPerformed(ActionEvent e)
// throw new UnsupportedOperationException("Not supported yet.");
