Java Java- Set hasDigit to true if the 3-character passCode contains a digit.
  • Thread starter Thread starter dellmac
    Java Set
The discussion revolves around a coding problem related to checking for digits in a passcode string. The initial code attempts to determine if the passcode contains any digits but incorrectly uses `Character.isDigit` with the string length, leading to errors. A user later proposes a solution that checks each character individually, but acknowledges it may be inefficient. Another participant suggests a more efficient approach using a loop to iterate through the entire string, checking each character for digits. This method ensures that the code can handle passcodes of varying lengths effectively.
dellmac
Been working this problem for hours and can't seem to get it right. Any assistance would be greatly appreciated!
Note: Green colored text is the editable text
public class CheckingPasscodes {
public static void main (String [] args) {
boolean hasDigit = false;
String passCode = "";
int valid = 0;
passCode = "abc";
if (passCode.equals(Character.isDigit(passCode.length()))) {
hasDigit = true;
if (hasDigit) {
System.out.println("Has a digit.");
else {
System.out.println("Has no digit.");
return;
Technology news on Phys.org
So I just got it. I believe I used the long way though; not sure if there is an easier way:
if (Character.isDigit(passCode.charAt(0))) {
hasDigit = true;
if (Character.isDigit(passCode.charAt(1))) {
hasDigit = true;
if (Character.isDigit(passCode.charAt(2))) {
hasDigit = true;
hasDigit = true;
hasDigit = true;
hasDigit = true;
Hi dellmac! (Smile)
That looks like the right direction.
But suppose the passCode is not length 3...
In other words, you need a loop:
Code:
for (int i = 0; i < passCode.length(); ++i) {
    if (Character.isDigit(passCode.charAt(i))) {
        hasDigit = true;
Learn If you want to write code for Python Machine learning, AI Statistics/data analysis Scientific research Web application servers Some microcontrollers JavaScript/Node JS/TypeScript Web sites Web application servers C# Games (Unity) Consumer applications (Windows) Business applications C++ Games (Unreal Engine) Operating systems, device drivers Microcontrollers/embedded systems Consumer applications (Linux) Some more tips: Do not learn C++ (or any other dialect of C) as a...
10K
  • · Replies 0 ·
13K
