Jeans instabiity & gravitational collapse
In summary, the conversation discusses the concept of Jeans instability in relation to the formation of stars and the Virial theorem. It is mentioned that the equation K = N(3/2)kT represents the thermal energy of a cloud and this can be equated to its kinetic energy because the system as a whole is at rest. The question is then posed about the origin of the 3/2 factor and whether Jeans instability is the only factor in gravitational collapse. The conversation ends with a request for a derivation of Jeans law.
shounakbhatta
288
Hello All,
I am trying to understand how stars are formed and thereby came across Jeans instability. I am new to this subject, however I went through concepts of molecular clouds, nuclear fusions and things like that.
The Virial theorem says E=(1/2)U
As sum of potential energy U and kinetic energy K=0, so we write
K+U=E
K=U=1/2(E)
or 2K+U=0
My question is: if the total atoms is N the equation states that:
K= (N) (3/2kT)
How does this equation comes from?
Thanks
Astronomy news on Phys.org
That's basically the thermal energy of the cloud. All of the particles in the cloud (hydrogen atoms in this case) have their kinetic energy partitioned into the degrees of freedom of the system. Hydrogen atoms have three degrees of freedom because they can only move around in three directions.
Basically, the average energy of a particle in a system of temperature T is
[itex]E_{thermal} = f\frac{1}{2}kT[/itex]
where f is the number of degrees of freedom that the particle has, and k is Boltzmann's constant. To get the average energy of a system of N particles, just multiply that number above by N.
This means that the kinetic energy of a cloud of hydrogen is basically the same thing as its thermal energy, which is
[itex]K = N * E_{thermal} = N\frac{3}{2}kT[/itex]
I believe that one is able to equate these two things (kinetic energy and thermal energy) because the system as a whole is at rest with respect to the observer. Otherwise there would other parts to the kinetic energy. In other words, it's a fairly simplified situation.
Hello,
Thanks for the reply. What I am looking is how the 3/2 factor came into.
Secondly, is Jeans instability the only factor for gravitational collapse (molecular or otherwise.)
Thanks,
-- Shounak
Hello,
Can anyone please provide the step by step derivation of Jeans law?
Thanks,
-- Shounak
for your question. Jeans instability is a fundamental concept in the study of star formation. It refers to the collapse of a molecular cloud under its own gravity, leading to the formation of a protostar.
To understand this, let's first look at the equation you mentioned: K = (N) (3/2kT). This equation comes from the equipartition theorem, which states that in a system in thermal equilibrium, the total energy is equally distributed among all the degrees of freedom in that system. In this case, the degrees of freedom are the particles (atoms) in the molecular cloud.
The equation essentially tells us that the average kinetic energy of each particle is directly proportional to the temperature and the number of particles in the system. This is why as the number of particles (N) increases, so does the kinetic energy (K).
Now, going back to Jeans instability, we know that a molecular cloud is held together by its own gravity. However, there is also thermal pressure from the high temperature of the cloud pushing outwards. When the cloud becomes too massive, the gravitational force overcomes the thermal pressure and the cloud begins to collapse.
The collapse increases the density and temperature of the cloud, leading to an increase in kinetic energy (K). This increase in kinetic energy eventually balances out the gravitational potential energy (U), as seen in the Virial theorem. This is what leads to the formation of a protostar.
I hope this helps to clarify the connection between Jeans instability and the Virial theorem. Keep exploring and learning about these concepts, and you will gain a deeper understanding of how stars are formed. Best of luck on your journey!
FAQ: Jeans instabiity & gravitational collapse
What is Jeans instability?
Jeans instability is a phenomenon in astrophysics where a cloud of gas or dust is unstable to gravitational collapse. This occurs when the thermal pressure of the cloud is not strong enough to counteract the gravitational force, causing the cloud to collapse and potentially form a star or other astronomical object.
How is Jeans instability related to gravitational collapse?
Jeans instability is the initial stage of gravitational collapse. As the cloud of gas or dust collapses due to its own gravity, it becomes denser and the temperature increases, eventually leading to the formation of a star or other object. This process is known as gravitational collapse.
What factors determine the onset of Jeans instability?
The onset of Jeans instability is determined by several factors, including the mass of the cloud, its temperature, and the gas pressure. Generally, larger and colder clouds are more prone to Jeans instability, while higher gas pressure can help to stabilize the cloud.
Is Jeans instability a common occurrence in the universe?
Yes, Jeans instability is a common occurrence in the universe, especially in regions where there are large amounts of gas and dust. It is an important process in the formation of stars, galaxies, and other astronomical objects.
Can Jeans instability lead to the formation of black holes?
Yes, in certain conditions, Jeans instability can lead to the formation of black holes. If the collapsing cloud has enough mass and is unable to form a star, it can continue to collapse until it becomes a singularity, resulting in a black hole. However, this is just one possible outcome of Jeans instability and is not always guaranteed.
