MHB Jenny's question at Yahoo Answers (Convergence of a series)
  • Thread starter Thread starter Fernando Revilla
    Series
The series in question is $\displaystyle\sum_{n=1}^{\infty}\dfrac{1-2\sin n}{3n^2+2n+4}$. It is established that the absolute value of the series can be bounded by $\dfrac{3}{3n^2+2n+4}$. Since the series $\displaystyle\sum_{n=1}^{\infty}\dfrac{3}{3n^2+2n+4}$ is convergent, it follows that the original series is also absolutely convergent. Therefore, the conclusion is that the series is convergent.
Mathematics news on Phys.org
Hello Jenny,
Your series is $\displaystyle\sum_{n=1}^{\infty}\dfrac{1-2\sin n}{3n^2+2n+4}$, then $$\left|1-2\sin n\right|\leq \left|1+(-2\sin n)\right|\leq 1+2\;\left|\sin n\right|\leq 1+2=3$$ As a consequence, $$\left|\dfrac{1-2\sin n}{3n^2+2n+4}\right|\leq \dfrac{3}{3n^2+2n+4}$$ But easily proved, the series $\displaystyle\sum_{n=1}^{\infty}\dfrac{3}{3n^2+2n+4}$ is convergent, hence the given series is absolutely convergent.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
