Jesse's question via email about volume by revolution
In summary, we can calculate the volume of the region under $y=12-x^2$ between $x=0$ and $x=3$ rotated around the x-axis by either subtracting the volume of the region under $y=3$ or by adding the volume of the region between $y=3$ and $y=12-x^2$. Both methods will result in the same volume, which is approximately $\frac{
Prove It
MHB
1,465
24
Here is a sketch of the region to be rotated and the line to be rotated around.
Notice that the volume will be exactly the same if we were to move everything up by 3 units, but with the advantage of rotating around the x axis. So we want to find the volume of the region under $\displaystyle \begin{align*} y = 12 - x^2 \end{align*}$ between $\displaystyle \begin{align*} x= 0 \end{align*}$ and $\displaystyle \begin{align*} x = 3 \end{align*}$ rotated around the x axis, and then subtract the volume of the region under $\displaystyle \begin{align*} y = 3 \end{align*}$ between $\displaystyle \begin{align*} x = 0 \end{align*}$ and $\displaystyle \begin{align*} x = 3 \end{align*}$ rotated around the x axis. Thus the volume we want is
$\displaystyle \begin{align*} V &= \int_0^3{ \pi\,\left( 12 - x^2 \right) ^2\,\mathrm{d}x } - \int_0^3{ \pi\,\left( 3 \right) ^2\,\mathrm{d}x } \\ &= \pi\int_0^3{ \left[ \left( 12 - x^2 \right) ^2 - 3^2 \right]\,\mathrm{d}x } \\ &= \pi\int_0^3{ \left( 144 - 24\,x^2 + x^4 - 9 \right) \,\mathrm{d}x } \\ &= \pi\int_0^3{ \left( 135 - 24\,x^2 + x^4 \right) \,\mathrm{d}x } \\ &= \pi\,\left[ 135\,x - 8\,x^3 + \frac{x^5}{5} \right] _0^3 \\ &= \pi\,\left\{ \left[ 135\,\left( 3 \right) - 8 \,\left( 3 \right) ^3 + \frac{3^5}{5} \right] - \left[ 135\,\left( 0 \right) - 8 \,\left( 0 \right) ^3 + \frac{0^5}{5} \right] \right\} \\ &= \pi\,\left( 405 - 216 + \frac{243}{5} - 0 \right) \\ &= \frac{1188\,\pi}{5}\,\textrm{units}^3 \end{align*}$
Likes chwala
Mathematics news on Phys.org
Hello,
Thank you for sharing your calculation of the volume of this rotated region. I would like to point out that your approach is correct and follows the principles of integral calculus. However, I would also like to suggest an alternative method that may be more efficient and intuitive.
Instead of subtracting the volume of the region under $y=3$, we can simply add the volume of the region between $y=3$ and $y=12-x^2$. This is because when we rotate the region around the x-axis, the volume under $y=3$ will be included in the total volume.
Using this method, we can rewrite the volume as:
$\displaystyle \begin{align*} V &= \int_0^3{ \pi\,\left( 12 - x^2 \right) ^2\,\mathrm{d}x } + \int_0^3{ \pi\,\left( 3 - x^2 \right) ^2\,\mathrm{d}x } \\ &= \pi\int_0^3{ \left[ \left( 12 - x^2 \right) ^2 + \left( 3 - x^2 \right) ^2 \right]\,\mathrm{d}x } \\ &= \pi\int_0^3{ \left( 144 - 24\,x^2 + x^4 + 9 - 6x^2 + x^4 \right) \,\mathrm{d}x } \\ &= \pi\int_0^3{ \left( 153 - 30\,x^2 + 2x^4 \right) \,\mathrm{d}x } \\ &= \pi\,\left[ 153\,x - 10\,x^3 + \frac{2x^5}{5} \right] _0^3 \\ &= \pi\,\left\{ \left[ 153\,\left( 3 \right) - 10 \,\left( 3 \right) ^3 + \frac{2 \cdot 3^5}{5} \right] - \left[ 153\,\left( 0 \right) - 10 \,\left( 0 \right) ^3 + \frac{2 \cdot 0^5}{5} \right] \
FAQ: Jesse's question via email about volume by revolution
1) What is "Jesse's question via email about volume by revolution?"
Jesse's question via email about volume by revolution is a question posed by Jesse via email to a scientist. It likely pertains to the calculation of volume by revolution, which is a mathematical concept used in various disciplines, including physics and engineering.
2) Why is Jesse asking about volume by revolution?
Jesse may be asking about volume by revolution for a variety of reasons. They may be a student or researcher looking for a better understanding of the concept, or they may be encountering a problem that requires the calculation of volume by revolution. Regardless, their question likely stems from a need for clarification or assistance with the concept.
3) How is volume by revolution calculated?
The calculation of volume by revolution depends on the shape being revolved and the axis of revolution. Generally, it involves using integration or other mathematical methods to find the area of cross-sections and then summing those areas to find the total volume. The specific equation used will vary based on the shape and axis of revolution.
4) What applications does volume by revolution have?
Volume by revolution has many practical applications in various fields. It is commonly used in engineering and design to calculate the volume of 3D objects, such as pipes and cylinders. It is also used in physics to calculate the moment of inertia and other rotational quantities. Additionally, volume by revolution is an important concept in calculus and is used to teach students about integration and the calculation of volumes of revolution.
5) Are there any limitations or considerations when using volume by revolution?
Like any mathematical concept, volume by revolution has limitations and considerations that must be taken into account. One limitation is that it is typically used for symmetrical shapes, so it may not accurately calculate the volume of irregular objects. Additionally, the accuracy of the calculation may be affected by the precision of the measurements used. It is also important to consider the units being used and to convert them if necessary to ensure accurate results.
