- #36
Soorena
- 6
Astronuc said:Rockets usually used gimbled rocket motors or small rocket motor to 'steer' the rocket. Control surfaces on aircraft and some rockets are made of the lighest possible material and usually do not operate at high temperature - except for those vehicles traveling well beyond supersonic. By contrast turbine blades in a jet engine operated at very high temperatures.
There is a great deal of 'art' in perfecting an alloy composition that retains high strength, toughness and creep resistance at high temperature.
China and India are not backward countries. They have considerable expertise in many high tech areas.
Thanks for the reply.
However I am pretty sure that apart from gimbled engines, "jet vanes" too are used for steering. Some times graphite and sometimes graphite reinforced ceramic composite jet vanes are used.
If you google the phrase "graphite reinforced ceramic composite jet vanes" you will find a blog which is about proliferation control. Over there they talk about advanced composite material jet vanes which are used to steer rockets.
The blog is contributed to by rocket scientists so it is fairly reliable in terms of technical information as far as rockets go.
So I am sure that jet vanes are used for steering rockets and I was just wondering if the technology for making such composite material is related to the technology of making turbine blades?
If there is any similarity in between, would the technical know-how as to make one imply the ability to make the other? or are they completely unrelated to each other?
