MHB Joey e's questions at Yahoo Answers regarding solids of revolution
  • Thread starter Thread starter MarkFL
    Revolution Solids
Joey e seeks help with two calculus problems involving solids of revolution, specifically using the disk/washer and shell methods. The first problem involves finding the volume generated by revolving the region bounded by the curves y=8√x and y=8x³ around the x-axis, with the solution yielding a volume of 160π/7. The second problem requires calculating the volume of the solid formed by revolving the region defined by x=1/2y³, x=4, and y=0 around the y-axis, resulting in a volume of 192π/7. The discussion emphasizes the importance of understanding the choice of method and includes detailed calculations for both approaches. The thread encourages further questions on solids of revolution.
MarkFL
MHB
Here is the question:
Calculus Disc/washer/shell method.?
I have two problems that I have no idea how to work, and have the test coming up soon.
1) Sketch the region by the following curves and find the volume of the solid generated by revolving this region about the x-axis.
y=8sqrtx
y=8x^3
2) Sketch the region bounded by the following curves and find the volume of the solid generated by the revolving this region about the y-axis.
x=1/2y^3
x=4
y=0
I need to know why you picked the method you did, and the work shown associated with it. THANK YOU SO MUCH
Here is a link to the questions:
Calculus Disc/washer/shell method.? - Yahoo! Answers
I have posted a link there to this topic so the OP can find my response.
Mathematics news on Phys.org
Re: joey e's questions from Yahoo! Answers regarding solids of revolution
Hello joey e,
I am going to work both problems using the disk/washer method and the shell method so you can see both in action and as a means of checking my work, plus it's good practice when practical.
1.) Let's first look at a plot of the region to be revolved about the $x$-axis:
https://www.physicsforums.com/attachments/780._xfImport
Washer method:
Let's find the volume $dV$ of an arbitrary washer:
$$dV=\pi\left(R^2-r^2 \right)\,dx$$
$R$ is the outer radius, and it is given by:
$$R=8\sqrt{x}$$
$r$ is the inner radius, and it is given by:
$$r=8x^3$$
and so we have:
$$dV=64\pi\left(x-x^6 \right)\,dx$$
Summing the washers by integrating, we find:
$$V=64\pi\int_0^1 x-x^6\,dx=64\pi\left[\frac{x^2}{2}-\frac{x^7}{7} \right]_0^1=64\pi\left(\frac{1}{2}-\frac{1}{7} \right)=\frac{160\pi}{7}$$
Shell method:
The volume $dV$ of an arbitrary shell is:
$$dV=2\pi rh\,dy$$
where:
$$r=y$$
$$h=\frac{y^{\frac{1}{3}}}{2}-\frac{y^2}{64}$$
and so we have:
$$dV=\pi \left(y^{\frac{4}{3}}-\frac{y^3}{32} \right)\,dy$$
Summing the shells by integrating, we find:
$$V=\pi\int_0^8 y^{\frac{4}{3}}-\frac{y^3}{32}\,dy=\pi\left[\frac{3}{7}y^{\frac{7}{3}}-\frac{1}{128}y^4 \right]_0^8=\pi\left(\frac{3}{7}8^{\frac{7}{3}}-\frac{1}{128}8^4 \right)=\frac{160\pi}{7}$$
2.) Here is a plot of the region to be revolved about the $y$-axis:
https://www.physicsforums.com/attachments/781._xfImport
Washer method:
The volume $dV$ of an arbitrary washer is:
$$dV=\pi\left(R^2-r^2 \right)\,dy$$
$$R=4$$
$$r=\frac{1}{2}y^3$$
and so we have:
$$dV=\pi\left(16-\frac{1}{4}y^6 \right)\,dy$$
$$V=\pi\int_0^2 16-\frac{1}{4}y^6\,dy=\pi\left[16y-\frac{1}{28}y^7 \right]_0^2=\pi\left(16\cdot7-\frac{1}{28}2^7 \right)=\frac{192\pi}{7}$$
Shell method:
$$dV=2\pi rh\,dx$$
$$r=x$$
$$h=(2x)^{\frac{1}{3}}$$
and so we have:
$$dV=2^{\frac{4}{3}}\pi x^{\frac{4}{3}}\,dx$$
Summing the shells by integration, we find:
$$V=2^{\frac{4}{3}}\pi\int_0^4 x^{\frac{4}{3}}\,dx=2^{\frac{4}{3}}\pi\left[\frac{3}{7}x^{\frac{7}{3}} \right]_0^4=2^{\frac{4}{3}}\pi\cdot\frac{3}{7}4^{\frac{7}{3}}=\frac{192\pi}{7}$$
To joey e and any other guests viewing this topic, I invite and encourage you to post other solids of revolution problems here in our http://www.mathhelpboards.com/f10/ forum.
Best Regards,
Mark.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
