MHB John's Implicit Diff Q&A: Horiz/Vert Tangents at Yahoo! Answers
John's question on Yahoo! Answers involves finding points of horizontal and vertical tangents for the equation x^2 + xy + y^2 = y using implicit differentiation. The derivative is calculated as dy/dx = (2x + y) / (1 - x - 2y). Horizontal tangents occur where the numerator equals zero, yielding points (0, 0) and (-2/3, 4/3). Vertical tangents arise when the denominator is zero, resulting in points (-1, 1) and (1/3, 1/3). The discussion includes detailed calculations and plots illustrating the tangent lines.
MarkFL
MHB
John's question at Yahoo! Answers regarding implicit differentiation & horizontal/vertical tangents
Here is the question:
Implicit Differentiation Problem?
For the equation x^2+xy+y^2=y;
(a) Find the points where the tangent line is parallel to the x-axis. (b) Find the points where the tangent line is parallel to the y-axis.
I have posted a link there to this topic so the OP can see my work.
Mathematics news on Phys.org
Re: John's question at Yahoo! Answers regarding implicit differentiation & horizontal/vertical tange
Hello John,
We are given the equation:
$$x^2+xy+y^2=y$$
Implicitly differentiating with respect to $x$, we find:
$$2x+x\frac{dy}{dx}+y+2y\frac{dy}{dx}=\frac{dy}{dx}$$
Solving for $$\frac{dy}{dx}$$, we obtain:
$$x\frac{dy}{dx}+2y\frac{dy}{dx}-\frac{dy}{dx}=-2x-y$$
$$\frac{dy}{dx}(x+2y-1)=-2x-y$$
$$\frac{dy}{dx}=\frac{2x+y}{1-x-2y}$$
Now, the tangent line(s) will be horizontal where the numerator is zero, which implies:
$$y=-2x$$
Substituting this into the original equation, we obtain:
$$x^2+x(-2x)+(-2x)^2=(-2x)$$
$$x^2-2x^2+4x^2=-2x$$
$$3x^2+2x=0$$
$$x(3x+2)=0$$
$$x=0,\,-\frac{2}{3}$$
Hence we have two points from $(x,-2x)$:
$$(0,0),\,\left(-\frac{2}{3},\frac{4}{3} \right)$$
Here is a plot of the curve with its two horizontal tangent lines:
The tangent line(s) will be vertical where the denominator is zero, which implies:
$$y=\frac{1-x}{2}$$
$$x^2+x\left(\frac{1-x}{2} \right)+\left(\frac{1-x}{2} \right)^2=\left(\frac{1-x}{2} \right)$$
$$4x^2+2x(1-x)+(1-x)^2=2(1-x)$$
$$4x^2+2x-2x^2+1-2x+x^2=2-2x$$
$$3x^2+2x-1=0$$
$$(3x-1)(x+1)=0$$
$$x=-1,\,\frac{1}{3}$$
Hence we have two points from $$\left(x,\frac{1-x}{2} \right)$$:
$$\left(-1,1 \right),\,\left(\frac{1}{3},\frac{1}{3} \right)$$
Here is a plot of the curve with its two vertical tangent lines:
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
