Johnson-Nyquist noise of an inductor
In summary, the question at hand is whether inductors have thermal noise and if so, what is the relevant formula for calculating it. It is noted that while perfect inductors do not generate noise, practical inductors with resistance do. Additionally, it is mentioned that capacitors do have thermal noise, and by the same reasoning, inductors should as well. However, there seems to be a lack of literature on this topic. Further research or a master's thesis may be needed to fully understand the noise associated with inductors.
olaney
Although it's easy to find calculations of thermal noise for resistors and capacitors, the equivalent for inductors is not found. What is the relevant formula? Is there some simple conversion for this?
A perfect inductor is a pure reactance. Therefore it can store energy but it cannot absorb it. The energy will come out again when the field collapses. As the inductor cannot absorb energy, it cannot generate it either. It is like a shiny surface in heat radiation. So no noise from a perfect inductor.
No noise from a perfect capacitor either.
With a practical inductor, there is resistance, so you just take the noise EMF across the resistance and consider it in series with the inductance.
Capacitors do have thermal noise, see for instance the wikipedia article for Johnson-Nyquist noise. By the same reasoning so will an inductor.
In the case of an inductor, yes there is series resistance, but I'm interested in the noise associated with the inductance alone.
Thank you very much for drawing my attention to this.
It appears that a pure reactance will develop a noise voltage but cannot deliver noise power.
In thinking more about this, it makes sense that just as capacitor noise is a voltage in the open circuit condition, inductors should have current noise in the short circuit condition. This will apply even for zero resistance as it's just the electrons randomly sloshing back and forth at temperature. I'm just surprised there's nothing in the literature beyond some arm waving generalities. Sounds like a master's thesis for someone with the time and inclination.
FAQ: Johnson-Nyquist noise of an inductor
1. What is Johnson-Nyquist noise of an inductor?
Johnson-Nyquist noise of an inductor, also known as thermal noise or white noise, is the random fluctuation of electrical energy in an inductor due to the thermal motion of electrons. It is a fundamental property of all electronic components and cannot be eliminated, only minimized.
2. How does Johnson-Nyquist noise affect inductor performance?
Johnson-Nyquist noise can affect the performance of an inductor by introducing unwanted noise into the circuit, which can interfere with the desired signal. It can also cause a decrease in the quality factor (Q factor) of the inductor, resulting in a lower efficiency and a higher resistance.
3. What factors influence the level of Johnson-Nyquist noise in an inductor?
The level of Johnson-Nyquist noise in an inductor is influenced by several factors, including the temperature of the inductor, its resistance, and the frequency of the signal passing through it. Higher temperatures, higher resistances, and higher frequencies all result in higher levels of Johnson-Nyquist noise.
4. How can Johnson-Nyquist noise be reduced in an inductor?
Johnson-Nyquist noise can be reduced in an inductor by using materials with lower resistance, such as copper or silver, and by keeping the inductor at a lower temperature. Increasing the inductor's inductance and using shielding techniques can also help reduce the effects of Johnson-Nyquist noise.
5. Is Johnson-Nyquist noise present in all inductors?
Yes, Johnson-Nyquist noise is present in all inductors as it is a fundamental property of electronic components. However, the level of noise may vary depending on the specific design and materials used in the inductor.
9K
12K
