MHB Joint distribution of a discrete random variable
The discussion revolves around calculating the joint distribution of two random variables, X (the minimum number drawn) and Y (the maximum number drawn) from an urn containing six numbered balls. The user seeks to determine the probabilities for specific outcomes, such as X = 1 and Y = 5, and X = 2 and Y = 6. A suggested method for solving this is to enumerate all possible combinations of drawing four balls from the six, which totals 15 combinations. This approach, while potentially tedious, provides a systematic way to calculate the desired probabilities. Understanding the joint distribution requires careful consideration of the relationships between the values of X and Y based on the drawn combinations.
Yankel
Hello all
I have this question I am trying to solve.
In an urn there are 6 balls, numbered: 1,2,3,4,5,6. We take 4 balls outs, without replacement.
X - the minimal number we see
Y - the maximal number we see
I need to joint distribution.
I understand that X is getting the values 1,2,3 while Y 4,5,6.
The problem is calculating the probabilities. How do I calculate the probability that X = 1 and Y = 5 ? What about the probability that X = 2 and Y = 6 ? And so on...
thanks !
Mathematics news on Phys.org
Yankel said:
Hello all
thanks !
Hi Yankel,
How about enumerating them all?
There are only $\binom 6 4 = 15$ possible combinations.
A little bit hard to count them all, but it works ! Thanks
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
