MHB Joko123's question at Yahoo Answers (Sketching a cone)
  • Thread starter Thread starter Fernando Revilla
    Cone
The discussion revolves around demonstrating that the given parametric equations represent the curved surface of a circular cone with height h and base radius r. The equations show that as u varies from 0 to r and v from 0 to 2π, they describe circles in horizontal planes at varying heights, confirming the cone's structure. The transformation leads to the conical equation z² = (h²/r²)(x² + y²), which characterizes an unbounded conical surface. By analyzing the constraints, the sketch of the cone can be accurately created, illustrating the circular base and apex. The solution effectively clarifies how to visualize and understand the geometry of the cone.
Fernando Revilla
MHB
Here is the question:
Consider the Surface: r = ucos(v)i + usin(v)j + (h*u/r)k 0<u<r and 0<v<2*pi
(should be less then equal to for constraints)
Show that this represents the curved surface of a circular cone height h and base radius r. Sketch this cone?I have tried multiple times to solve this and can't seem to grasp a solution. PLEASE HELP
Here is a link to the question:
Please Help, How to Sketch a circular cone, height h and base r? - Yahoo!7 Answers
I have posted a link there to this topic so the OP can find my response.
Mathematics news on Phys.org
Hello Joko123,
Consider the surface: $$S:\left \{ \begin{matrix}x=u\cos v\\y=u\sin v\\z=\dfrac{h}{r}u\end{matrix}\right. \qquad (u\in\mathbb{R},\;v\in\mathbb{R})$$ We have $x^2+y^2=u^2\cos^2v+u^2\sin^2v=u^2(\cos^2v+\sin^2v)=u^2$ and $u=rz/h$, so: $$S:z^2=\frac{h^2}{r^2}(x^2+y^2)$$ and we know that a equation of this form is the equation of an unbounded conical surface. Now, consider the contraints $0\leq u\leq r,\;0\leq v\leq 2\pi$. For $u\in [0,r]$ we have $$\left \{ \begin{matrix}x=u\cos v\\y=u\sin v\\z=\dfrac{h}{r}u\end{matrix}\right. \qquad (v\in [0,2\pi])$$ that is, a circle on the plane $z=hu/r$.
If $u=0$, we get the point $(0,0,0)$ (circle with radius $0$).
If $u=r$, we get $$\left \{ \begin{matrix}x=r\cos v\\y=r\sin v\\z=h\end{matrix}\right. \qquad (v\in [0,2\pi])$$ that is, a circle on the plane $z=h$ with center at $(0,0,h)$ and radius $r$. Now, is easy to sketch the cone (choose only the part above):
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
