JollyOlly's book 'A Roller Coaster Ride through Relativity'
In summary: The one-way speed of light is not the same as the two-way speed of light, it is the same as the speed of light in any inertial reference frame.
ghwellsjr
150
JollyOlly said:
Baggins101 - you would probably find my book 'A Roller Coaster Ride through Relativity' on Wikibooks of interest.
I'm concerned about your book. I got up to this part:
While most scientists tried to explain this result away by means of various subterfuges, Albert Einstein merely accepted it as a necessary consequence of the Fundamental Principle namely:
The speed of light in a vacuum is a universal constant and will always be the same even when measured by different observers in relative motion.
And I got very concerned. Although what you say is true, the fact that you put the last part of the quote in a box, like you did for what you called the Fundamental Principle and its restated version, gave me the impression that you believe that part of the quote is his second postulate. But you are specifically stating that there really is only one principle or postulate and this misrepresents not only what Einstein said but also the fundamental basis for Special Relativity.
The actual statement of his second postulate from the introduction of his 1905 paper is:
light is always propagated in empty space with a definite velocity c which is independent of the state of motion of the emitting body.
Or later at the beginning of section 2:
Any ray of light moves in the “stationary” system of co-ordinates with the determined velocity c, whether the ray be emitted by a stationary or by a moving body.
When he says the "definite velocity c" or the "determined velocity c", he is referring to his comment at the end of the first section where he defines c to be the measured two-way speed of light.
But his second postulate is about the unmeasurable one-way speed of light which cannot be part of the first postulate. That's what he means by "propagated" or "ray". He's defining the one-way speed of light to be identical to the two-way speed of light in any system of co-ordinates.
This is my concern about your book. Do you eventually clarify this issue?
I agree that I have misrepresented (I would prefer to say reinterpreted!) Einstein's original postulates.
I suppose I have never really understood the need for the second postulate. After all, why should the speed of light depend on the speed of the emitting body in the first place? If I proposed a new law of physics which said that 'the speed of sound is independent of the speed of the emitting body' I would be laughed out of court!
I am afraid I do not understand your distinction between one-way and two-way speeds of light. Please explain.
I don't think Einstein would like this.
Now I know Einstein wouldn't like this.
Einstein published his theory in 1905 before De Sitter performed his experiment showing that it was true. But without an experiment or a postulate, he couldn't just leave it hanging. However, the competing theory at the time, Lorentz Ether Theory (LET) would also claim this part of Einstein's second postulate.
The assertion that light propagates at c in any inertial frame is what distinguished Einstein's new (in 1905) theory from LET which claimed that light propagates at c only in one universal, absolute, but unidentifiable, ether rest frame.
Maybe you should read One-way speed of light.
Newton thought the speed of light depended on the source. So did Ritz, with his emission theory. Galilean relativity can be trivially maintained in such a theory without giving up absolute time.
gwellsjr - Thank you for the reference to one-way speed of light. If I have understood correctly, the statement that the one-way speed of light is the same as the two-way speed (as implied by Einstein's second postulate) is equivalent to the statement that the one-way speed of light is isotropic - ie the same in all directions.
While a rigorous account of SR might have to take into account the possible anisotropy of space and time, in an introductory account I have assumed without question that the laws of physics are isotropic and the same everywhere in space.
Yes.
There's no real need to consider clock synchronization conventions, for inertial frames, other than Einstein's in a standard SR textbook because other clock synchronization conventions in inertial frames will result in (at the best) non-orthogonal simultaneity hyperplanes and (at the worst) curved simultaneity hypersurfaces; the resulting formulas for Lorentz transformations etc. will be absolutely horrendous when compared to the standard formulas obtained using Einstein's synchronization convention. However IMO it is important to distinguish between the one-way and two-way speeds of light since the latter can be measured without any clock synchronization convention whereas the former can only be measured after such a convention is defined and adopted-the two-way speed of light depends only on local time whereas the one-way speed of light requires a global time coordinate constructed from a consistent method of clock synchronization.
Many authors present relativity with the two 1905 postulates telescoped into one. It's perfectly logical. IMO it's silly to make an affectation out of presenting things in the author's original words.
Without the second postulate you just have Galilean Relativity. The emission theory is compatible with the 1st postulate, but not with the 2nd. You need the 2nd postulate to distinguish SR from such theories.
Thank you bcrowell, your support is appreciated
This is a long-running debate, and there's an element of personal taste to it.
A fairly representative earlier thread would be: www.physicsforums.com/showthread.php?t=670253 and a search of this forum for the keyword "postulate" will find many more.
Note that even the pure relativity + homogeneity + isotropy frameworks result in either Galilean relativity or SR. Emission theory accounts for MM experiment, and (with extinction) almost all experiments until the 1970s. So to choose, you have to say:
- based on a series of sophisticated experiments, our universe appears to be SR, with light speed as the invariant speed.
or, you add a light speed is independent of emitter speed as a postulate; or that Maxwell's equations describe EM for all inertial frames; or something equivalent.
But you have to add something, and the something is not 'trivial'.
PAllen said:
...or that Maxwell's equations describe EM for all inertial frames...
I find it most natural to assume that Maxwell's equation describe E&M for all inertial frames - I'm on record as paraphrasing the second postulate as "And I really mean the first postulate, even when it comes to E&M". But as I said above, there's an element of personal taste in that preference.
I agree that it's not trivial; the half century between Maxwell and Einstein demonstrates that.
Also, before you go calling something a subterfuge you really ought to fully understand what "most scientists" said and meant in a technical sense. Most EM specialists from 1890 to 1920 were exceptionally adept and could speak, interpret and create EM theory to the extent that today's educational system arguably does not produce with equal quality.
I had in mind the theory that motion through the aether would cause a real physical contraction in the length of one of the arms of the MM interferometer and that the absence of a measurable shift in the fringes implied that the Earth was 'dragging the aether along with it'
I am sorry if my use of the word subterfuge caused offence; please bear in mind that my book is intended to explain the amazing predictions of SR to the intelligent layperson and is not intended to be an authoritative exposition of the historical antecedents of Einstein's theory.
Would you have some quick references to experiments which indicate inadequacies of Emission theory + Extinction? Spontaneously, I wonder if SU(2) topology must be further invoked, such as to account for the Sagnac effect.
One example is essential invariance with respect to emitter speed of neutrino speed. Extinction does not apply to neutrinos. Sagnac effect experiments conducted all in vacuo (first done in the mid 1960s, I believe) also act as refutations. Also, around this time (mid 60s) versions of the Majorana experiment all in vacuum were done.
Thanks. I think the Majorana vacuum experiment(s) indicate that macroscopic extinction doesn't account for relativistic effects, but it doesn't eliminate microscopic (single particle generated) extinction in receivers as a cause.
How is single particle extinction (that also includes neutrinos) different from assuming an emitter independent invariant speed? Seems just like changing the words you use at this point. The point is that macroscopic extinction is an an observable phenomenon. After this is ruled out as an explanation of SR effects, you are left with games equivalent to LET: a set of formal definitions that can be adjusted to match any experiment based on effects that can never be directly observed.
Single particle extinction would theoretically leave some tiny residual field components from the emitter that couldn't be detected in the motion or momentum of the receiving particle. Those don't exist in the assumption of emitter independent invariant speed (or anything associated with LET). But right, with our current technology we're unable to make those potential observations.
You keep ignoring the neutrino experiments. This show that high speed emitters of neutrinos have no effect on neutrino speed.
Those are certainly not to be ignored as well as muon lifetime calculations. They certainly appear to be compelling evidence for SR. But until we have a more complete understanding of how those particles are constituted and interact I wouldn't dare to claim the last word has been said.
Do you have any reference for what you are calling "single particle extinction"? The kind of extinction I've read about is based on verified (or plausible) properties of air or interstellar medium. Experiments in the 1960s and 70s directly controlled for this, and emission theories were considered finally and completely ruled out. I have not seen any reference to whatever you're referring to.
In the last 5 or 10 years nanophotonics has become an active field where light extinction from single particles is studied. The absorption rather than scattering case is probably what would be of most immediate interest. Here are some example articles:
Extinction and the optical theorem. Part I. Single particles.
http://www.ncbi.nlm.nih.gov/pubmed/18594605
Optical extinction spectrum of a single metal nanoparticle
http://prb.aps.org/abstract/PRB/v78/i20/e205410
Ensemble and single particle photophysical properties
http://onlinelibrary.wiley.com/doi/10.1002/jemt.20129/abstract
The most direct study about the relationship between electron sponsored extinction, de Broglie theory and relativistic effects was done in the late 1920's by J. J. Thomson and published in his monograph "Beyond The Electron".
Interesting. However, that would still be completely irrelevant to demonstrations of emitter independence of speed for neutrinos. I suspect it also would not explain the gamma ray speed emitter independence. Relativity is not just about light - it is about an invariant speed.
Prior to the actual experiment, no one had considered "that motion through the aether would cause a real physical contraction in the length of one of the arms of the MM interferometer" so I don't know what theory that would be. After the experiment was performed, Michelson assumed that since he couldn't detect any aether wind "that the Earth was 'dragging the aether along with it'" and he proposed in his paper that the experiment be repeated at the top of a high mountain to reduce the dragging and hopefully detect some aether wind.
It was others, notably Lorentz, that claimed "a real physical contraction in the length of one of the arms of the MM interferometer" would explain why the aether wind was not detected even though the aether remained stationary while the Earth moved through it (no dragging).
So these were two competing theories, not one that used both explanations.
I think your confusion on this aspect is tied into your lumping of Einstein's two postulates together. The difference between Lorentz's theory that affirms the existence of a stationary aether that propagates light at c and Einstein's theory that light propagates at c in any inertial frame, is in fact, his second postulate (or something equivalent for those that like a more modern approach). Since it is impossible to measure the propagation of light (the one-way speed of light), it is also impossible to distinguish between these two theories. It is for the philosophical reason that Einstein's theory is simpler that we have adopted his over the notion that light propagates at c only in one preferred inertial frame.
Keep in mind that the prevailing theories in 1905 viewed time and space as absolutes and Einstein's theory required a major paradigm shift. Nowadays, we have gotten so used to the idea that time and space are relative that we have a hard time wondering why it was so difficult for other scientists of the time to see what Einstein was finally able to see until Einstein showed them the way (it wasn't trivial even for Einstein). Nor is it easy for most people today to see that there is just a philosophical difference between LET and SR. I'm speaking of a modern-day version of LET that rejects Einstein's second postulate and replaces it with the postulate the light propagates at c only in one preferred Inertial Reference Frame. Of course, since no one can identify that IRF, it's kind of a wasted effort, not to mention the hassle of always transforming to the unidentified frame, just to be pure and conform to the LET notion.
Agreed. But the strange thing is that extinction must occur according to classical physics. And it matches exactly the results that SR claims for charged particles. If SR effects are to be added then the proposed results no longer coincide with reality. So there is a conundrum there... I can only imagine that we're lacking some important fact to pull it all together...
PhilDSP said:
Agreed. But the strange thing is that extinction must occur according to classical physics. And it matches exactly the results that SR claims for charged particles. If SR effects are to be added then the experimental results no longer coincide with reality. So there is a conundrum there... I can only imagine that we're lacking some important fact to pull it all together...
I don't see the conundrum. In particular, I don't believe the statement: "If SR effects are to be added then the experimental results no longer coincide with reality" is true. My understanding is that if SR effects are added you get no change in prediction (that is, that SR + extinction predicts the same as emissiong + extinction, when extinction applies). You just have inability to choose. Then uncharged particles give you the way to choose.
I think this depends somewhat on interpretation and on exactly how the postulates are stated. Einstein's original formulation of the postulates (translation by Perrett and Jeffery) was:
[T]he same laws of electrodynamics [are] valid for all frames of reference for which the equations
of mechanics hold good.
and
[L]ight is always propagated in empty space with a definite velocity c which is independent of the state of motion of the emitting body.
These postulates are clearly not meant to stand alone, since the first one refers to "the equations of mechanics." The first postulate would probably have been interpreted by most people in 1905, on a first reading, as claiming something about the laws of electrodynamics, probably proposing a property to be expected of some modification of Maxwell's equations. But by the time you're done reading the paper, you see that Einstein doesn't intend to modify Maxwell's equations, he just intends to modify the notions of space and time that Maxwell's equations use as a foundation. That makes it perfectly reasonable to take the first postulate as implying that Maxwell's equations hold. In that case, the first postulate implies the second postulate, since the second postulate is a prediction of Maxwell's equations, if you assume that Maxwell's equations are frame-independent as claimed in the first postulate.
I'll need some time to ponder what you mean here. It isn't completely obvious without thinking more deeply. Thanks.
FAQ: JollyOlly's book 'A Roller Coaster Ride through Relativity'
1. What is the main concept behind "A Roller Coaster Ride through Relativity"?
The main concept behind "A Roller Coaster Ride through Relativity" is to make the complex theories of relativity more accessible and understandable to a general audience. The author, JollyOlly, uses a fun and engaging approach to explain the principles of relativity in a way that anyone can understand.
2. Is this book suitable for someone with no background in physics?
Yes, this book is suitable for someone with no background in physics. JollyOlly does a great job of breaking down complex ideas and explaining them in a way that is easy to understand. However, some basic knowledge of mathematics and science may be helpful in fully grasping the concepts presented in the book.
3. How does "A Roller Coaster Ride through Relativity" differ from other books on the same topic?
Unlike other books on relativity, "A Roller Coaster Ride through Relativity" uses a storytelling approach to explain the concepts. The reader is taken on a journey through different scenarios and thought experiments, making the learning experience more engaging and enjoyable.
4. Can this book be used as a reference for further studies in relativity?
While "A Roller Coaster Ride through Relativity" is a great introduction to the topic, it is not meant to be a comprehensive reference book. It is best suited for those who are new to the subject and want to gain a basic understanding of relativity.
5. Is this book scientifically accurate?
Yes, this book is scientifically accurate. JollyOlly has a background in physics and has taken great care to ensure that the information presented in the book is correct. However, as with any popular science book, some simplifications may have been made for the sake of accessibility.
