Jordan measure on the irrationals
  • Thread starter cragar
  • Tags
    Measure
In summary: Therefore the greatest lower bound for all such sets is 0. In summary, to show that the set {[0,1]}^2-{\mathbb{Q}}^2 has Jordan inner measure zero, we can prove that there is no possible elementary set that fits inside this set, except for the empty set which has measure zero. Therefore, the greatest lower bound for all such sets is 0.
cragar
2,552
Show that [itex] {[0,1]}^2-{\mathbb{Q}}^2 [/itex] has jordan inner measure zero.
Jordan inner measure is defined as
[itex] m_{*}J(E)=sup (m(A)) [/itex]
where [itex] A \subset E [/itex] E is elementary.
elementary means a rectangular measure in n dimensions.
I imagine the proof relies on the fact that there is no sup in E that is elementary that contains all the irrationals in the unit square.
Assume for contradiction that there is a greatest lower bound, call it (x,x) this ordered pair is elementary and is the greatest lower bound for A and A is a subset of the irrationals in the unit sqare. So the sup(A) is an elementary box, so its measure is x*x, now x is some real number between 0 and 1. But it can't be equal to 1 because that is a rational number. So let's assume x is the sup(A).
if x is the sup of A, then [itex] \frac{x+1}{2}=q [/itex] but q is larger than x and less than 1. so x is not the sup(A). because E contains irrationals larger than x , because the irrationals are dense in R.
So E cannot have a positive measure, Since the measure of Q^2 is zero, it means its complement is measureable, so its complement has measure zero,
The definition of Jordan Inner Measure with which I am familiar uses the term 'simple set' rather than 'elementary'. But whichever term is used, it is not a rectangular measure or any other sort of measure. It is a set - specifically a set composed of a finite union of disjoint rectangles, where each rectangle is the product of half-open intervals of the form ##[a,b)##. Its measure is the sum of the measures of those rectangles.
For the measure to be nonzero, there must be at least one collection of such products of half-open sets that is contained in ##S\triangleq [0,1]^2-\mathbb Q^2##. Can there be such a collection? In fact, can there even be a single ##[a,b)\times [c,d)## that is contained in ##S##?
Why/why not?
oh ok thanks for the response, It can be a union of a finite number of rectangular boxes, because it has holes at the rational points (x,y).
It has to be a finite number of boxes, If it was a box of any width it would not be a subset, because it would contain rational points, which our set does not.
I guess to formalize the proof, Let's assume for contradiction that such a finite set of boxes exist, by defintion these boxes exist over some [a,b)x[c,d).
but this Cartesian product contains rational points, because rationals are dense in R, therefore this is a contradiction that such a set exist, therefore no box exists over this set.
Correct. Now remember that our boxes are of the form ##[a,b)\times [c,d)##. If they have no width, in either direction, it will be of the form ##[a,a)\times [b,b)##. How many points does such a box have in it?
each box has one point in it, and the measure of one point is zero. Regular measure theory only allows for countable unions. But there are unaccountably many irrationals. Do we say it breaks down because we can only have finite number of boxes. To me this doesn't prove its measure is zero, it kind of shows the axioms are breaking down.
Think about that again. The interval ##[a,b)## is the set of all points ##x## such that ##x\geq a## and ##x<b##. How many points will that be if ##a=b##?
oh ok, so there won't be any points in the box because it is an open interval.
thanks for your response. In my book it defines elementary measure as a possible interval of being open or closed. [a,b), (a,b), so there are 4 possible intervals. So how do you know which interval to use?
Good. So the only elementary sets that fit inside ##S## are unions of sets the form ##[a,a)\times [b,b)## which are all empty sets. So the only elementary set that fits inside ##S## is the empty set, whose measure is zero.
FAQ: Jordan measure on the irrationals
What is the Jordan measure on the irrationals?
The Jordan measure on the irrationals is a mathematical concept that measures the size or length of a set of irrational numbers. It is based on the idea of partitioning the set into smaller intervals and adding up their lengths.
How is the Jordan measure different from other measures?
The Jordan measure is different from other measures, such as the Lebesgue measure, because it only considers the length of the intervals in a partition and does not take into account the density or distribution of the numbers within the intervals.
What is the significance of the Jordan measure on the irrationals?
The Jordan measure on the irrationals is important in measure theory and real analysis. It helps to characterize the properties of sets of irrational numbers and provides a way to measure their size or length.
How is the Jordan measure calculated?
The Jordan measure is calculated by partitioning the set of irrational numbers into smaller intervals and adding up their lengths. This can be done using various techniques, such as Riemann sums or the Darboux integral.
Can the Jordan measure be extended to other sets of numbers?
Yes, the Jordan measure can be extended to other sets of numbers, such as the rationals or real numbers. However, the definition and calculation of the measure may be different for these sets due to their different properties and characteristics.
