Jordan Normal Form of a Linear Transformation
In summary: Yes, this is correct. However, if we can somehow determine which Jordan block corresponds to the given eigenvalue, then the eigenvalues for all other Jordan blocks will be automatically determined as well.
Sudharaka
MHB
1,568
Hi everyone, :)
Here's a question I encountered recently and did partway. I need your advice on how to proceed.
Question:
What can be said about the Jordan normal form of a linear transformation \(f:V\rightarrow V\) where \(V\) is a vector space over \(\mathbb{C}\), if we know that \(f^3=f^2\) ?
My Attempt:
Let \(x\) be a eigenvector of \(f\) and let \(\lambda\) be the corresponding eigenvalue. Than,
\[f(x)=\lambda x\]
\[\Rightarrow f^{2}(x)=\lambda f(x)=\lambda^2 x\Rightarrow f^{3}(x)=\lambda^2 f(x)=\lambda^3 x\]
Since \(f^{3}=f^2\) we have,
\[\lambda^2=\lambda ^3\Rightarrow \lambda =0 \mbox{ or }\lambda =1\]
Now this is where I get stuck. Could you help me out? :)
We want to understand what Jordan blocks have this behavior. I recommend taking a general 2x2 Jordan form matrix $M$ with eigenvalue $\lambda$ and computing $M^2$ and $M^3$ and seeing what conditions are necessary to make them equal (as you have pointed out, you already know what potentially allowable eigenvalues are, but there is no harm in trying this in general).
Then try it again for a Jordan block of size 3x3. I think you'll get a good picture of what kind of Jordan blocks are allowable (make sure to sort out the 1x1 case too, but that's not too hard).
Since a matrix in Jordan form is simply block diagonal with Jordan block entries, you should be able to get a clean description of all possible Jordan form matrices once you understand what Jordan blocks are allowable.
There exists general machinery to solve this problem quickly, but actually getting your hands a little dirty with this computation should help make the general techniques easier to understand.
Hi Turgul, :)
Thank you so much for the reply. When I carry on the procedure you have suggested, it seems to me that only \(\lambda =0\) satisfies all the cases. Therefore the Jordan blocks should have \(0\) in their diagonals. Is this true? :)
Note that, basically due to the computation you did in the original post, the 1x1 blocks must either be 0 or 1, but both work (1x1 Jordan blocks really just being arbitrary complex numbers).
In the n x n case with n > 1, it is necessary that $\lambda = 0$. If not, the super-diagonal entries would differ for $M^2$ and $M^3$. And indeed, in the 2x2 case, it is sufficient. In this case, $M^2$ and $M^3$ should both be the zero matrix. But in the 3x3 case, how do $M^2$ and $M^3$ compare?
How I thought in the 3x3 case was that if we have the Jordan normal form of the matrix as,
\[J=\begin{pmatrix}\lambda&0&0\\0&\lambda&1\\0&0& \lambda\end{pmatrix}\]
then we have,
\[J^2=\begin{pmatrix}\lambda^2&\lambda^2&2\lambda\\0&\lambda^2&2\lambda\\0&0&\lambda^2\end{pmatrix}\]
and
\[J^3=\begin{pmatrix}\lambda^3&\lambda^3&3\lambda\\0&\lambda^3&3\lambda\\0&0&\lambda^3\end{pmatrix}\]
So \(\lambda\) should be equal to zero if \(J^2=J^3\). Is this correct?
Not quite. Your matrix $J$ should look like:
\[J=\begin{pmatrix}\lambda&1&0\\0&\lambda&1\\0&0& \lambda\end{pmatrix}\]
In general, ALL entries of the super-diagonal should be 1's, so a 4x4 would be:
\[J'=\begin{pmatrix}\lambda&1&0&0\\
0&\lambda&1&0\\
0&0& \lambda&1\\
0&0&0& \lambda \end{pmatrix}\]
0&\lambda&1&0\\
0&0& \lambda&1\\
But isn't that only when we know for sure that there's only one Jordan block for the eigenvalue \(\lambda\)? I mean there could be several Jordan blocks for the same eigenvalue isn't? :)
And that is exactly why I propose you solve the problem for a Jordan block and then see what Jordan form matrices you can make out of the allowable blocks.
Also, as a caution, your computations of $J^2$ and $J^3$ are not correct for the $J$ you wrote down.
We can write a Jordan block as:
$J_{\lambda} = \lambda I +N$
where $N$ is a matrix with all 1's on the super-diagonal and 0's elsewhere.
The matrix $\lambda I$ commutes with any other matrix so:
$(J_{\lambda})^2 = \lambda^2I + 2\lambda N + N^2$
Powers of $N$ just move the 1's "up one diagonal".
We also get:
$(J_{\lambda})^3 = \lambda^3 + 3\lambda^2N + 3\lambda N^2 + N^3$
Comparing the values on the super-diagonal, we get from $(J_{\lambda})^2 = (J_{\lambda})^3$:
$\lambda(3\lambda - 2) = 0$
Since $\lambda \in \{0,1\}$, the root $\lambda = \frac{2}{3}$ (of the equation above) cannot be possible for $n > 1$.
0&\lambda&1&0\\
0&0& \lambda&1\\
We also get:
I am so sorry, I am so tired with this question I made so many mistakes. Now I think I understand what you are trying to say. If we take the 2x2 Jordan blocks and compare \(J^2\) and \(J^3\) we can see it works for both \(\lambda=0\) and \(\lambda=1\). If we take the 3x3 Jordan block,
\[J^3=\begin{pmatrix}\lambda^2&2\lambda&1\\0&\lambda^2&2\lambda\\0&0& \lambda^2\end{pmatrix}\]
and,
\[J=\begin{pmatrix}\lambda^3&3\lambda^2&3\lambda\\0&\lambda^3&3\lambda^2\\0&0& \lambda^3\end{pmatrix}\]
And comparison of \(J^2\) and \(J^3\) would tell us that both \(\lambda=0\) and \(\lambda=1\) are not satisfied in this case. Therefore it seems to me that for Jordan blocks of size 3 and above are non-existant for these \(\lambda\) values. Therefore the possible Jordan blocks are, the size one blocks, \(J_{1}(0)=0,\,J_{1}(1)=1\) and the size two blocks, \(J_{2}(0)=\begin{pmatrix}0&1\\0&0\end{pmatrix},\,J_{2}(1)=\begin{pmatrix}1&1\\0&1\end{pmatrix}\).
Am I correct? :)
Sudharaka said:
Am I correct?
Sorry, but no.
Perhaps you can recheck $J_1(1)$?
I like Serena said:
Sorry, but no.
Well, I don't quite get this. The Jordan block of size 1 which correspond to the eigenvalue \(\lambda=1\) is 1. And of course, $(J_1(1))^2=(J_1(1))^3=1$. So I don't quite understand why this is incorrect? :)
Sorry, I meant $J_2(1)$.
I tripped and mixed them up.
Note that $J_2$ would usually mean the Jordan block for eigenvalue 2, which is how Deveno used it.
I am sorry. I think it's a confusion of notation. You know I wrote $J_{2}(1)$ to mean the Jordan block of size 2 corresponding to the eigenvalue 1. :)
Yes, and I really tried to write using the notation you introduced. (Angel)
This notation actually is from Wikipedia (see >>this<<). I fancy it 'cause it gives every detail, the size as well as the corresponding eigenvalue. :)
Heh. I surrender. (Tmi)
Anyway, did you recheck the matrix given by a Jordan block of size 2 for eigenvalue 1?
ha ha... well the Jordan block of size 2 for eigenvalue 1 is,
\[J_{2}(1)=\begin{pmatrix}1&1\\0&1\end{pmatrix}\]
Is there a problem in it? :)
Yes. (Headbang) (Wink)
I am sorry, but I don't see the problem. Oh I seem to be so stupid enough not to see this small thing... (Worried)
Note that
\[J_{2}(1)^2=\begin{pmatrix}1&2\\0&1\end{pmatrix}\]
and
\[J_{2}(1)^3=\begin{pmatrix}1&3\\0&1\end{pmatrix}\]
Which are not equal. Thus the allowable Jordan blocks are exactly $J_1(0),J_1(1),J_2(0)$ and nothing else. Thus the allowable Jordan form matrices are exactly the block diagonal matrices with blocks any combination of $J_1(0),J_1(1),J_2(0)$.
As Deveno pointed out, powers of $J_m(\lambda)^n$ have a pretty nice general form which I'll write down explicitly for $m=3$
\[J_{3}(\lambda)^n=\begin{pmatrix}
\lambda^n & n \lambda^{n-1} & n(n-1) \lambda^{n-2}\\
0 & \lambda^n & n \lambda^{n-1} \\
0 & 0 & \lambda^n \end{pmatrix}\]
Unless $n=1,2$ where the formula doesn't quite work once 0's end up in the exponents. In fact what actually happens is that, if $f(x) = x^n$, then
\[f(J_3(\lambda)) = J_{3}(\lambda)^n=\begin{pmatrix}
f(\lambda) & f'(\lambda) & f''(\lambda)\\
0 & f(\lambda) & f'(\lambda) \\
0 & 0 & f(\lambda) \end{pmatrix}\]
This patter persists for powering any $J_m(\lambda)$. More generally it is also true for any polynomial $f(x)$.
We are supposed to have $J^2 = J^3$, but:
$$\begin{pmatrix}1&1\\0&1\end{pmatrix}^2 = \begin{pmatrix}1&2\\0&1\end{pmatrix}$$
$$\begin{pmatrix}1&1\\0&1\end{pmatrix}^3 = \begin{pmatrix}1&3\\0&1\end{pmatrix}$$
Something well worth remembering (because it turns out to be useful) is that the subgroup:
$G = \left\{\begin{bmatrix}1&k\\0&1 \end{bmatrix}: k \in \Bbb Z\right\}$
of $\text{GL}_2(\Bbb C)$ is isomorphic to the ADDITIVE group of the integers
(or more generally, for $GL_2(V),\ G$ is isomorphic to the additive subgroup of the prime ring of $F$).
Turgul said:
Note that
and
Thanks everyone of you for your valuable input on this question. I see my mistakes and see how to approach the problem. :) Thanks so much. :)
FAQ: Jordan Normal Form of a Linear Transformation
What is the Jordan Normal Form of a Linear Transformation?
The Jordan Normal Form of a Linear Transformation is a way of representing a linear transformation in a matrix form. It is useful in understanding the behavior and properties of the transformation.
Why is the Jordan Normal Form important?
The Jordan Normal Form is important because it helps in simplifying the representation of a linear transformation, making it easier to analyze and understand. It also reveals the geometric properties of the transformation, such as its eigenvectors and eigenvalues.
How is the Jordan Normal Form calculated?
The Jordan Normal Form is calculated by finding the eigenvectors and eigenvalues of the linear transformation. These are then used to construct a matrix that represents the transformation in its Jordan Normal Form.
What are the benefits of using the Jordan Normal Form?
Using the Jordan Normal Form allows for easier computation of powers and compositions of linear transformations. It also provides a more intuitive understanding of the transformation and its properties.
In what situations is the Jordan Normal Form used?
The Jordan Normal Form is commonly used in linear algebra, particularly in the study of matrices and linear transformations. It is also applied in various fields such as physics, engineering, and economics.
