MHB Jordan's Question from Facebook
  • Thread starter Thread starter Sudharaka
To maximize the total yield of an orchard with 50 peach trees, where each tree yields an average of 49 peaches, the optimal number of trees to plant is calculated. As additional trees are planted, the average yield per tree decreases by 12 peaches for every 10 trees. Using a parabolic yield function, the maximum yield occurs at approximately 45 trees. This calculation takes into account the decrease in yield per additional tree planted. Therefore, planting 45 trees will yield the highest total production of peaches.
Sudharaka
MHB
Jordan of Facebook writes:
I've tried everything but I keep coming up with 58 as my answer which WebWork tells me is wrong. Please help!
An orchard contains 50 peach trees with each tree yielding an average of 49 peaches. For each 10 additional trees planted, the average yield per tree decreases by 12 peaches. How many trees should be planted to maximize the total yield of the orchard?
Mathematics news on Phys.org
Hello Jordan,
Let's let $T$ be the number of trees and $P$ be the total yield of peaches.
We are given that:
$\displaystyle \frac{\Delta P}{\delta T}=\frac{-12}{10}=-\frac{6}{5}$
We are also given the point $(T,P)=(50,49)$
Using the point-slope formula, we find:
$\displaystyle P-49=-\frac{6}{5}(T-50)$
$\displaystyle P(T)=-\frac{6}{5}T+109$
Now, the total yield $Y$ of the orchard is the number of trees times the average yield per tree:
$\displaystyle Y=T\cdot P(T)$
$\displaystyle Y(T)=T\left(-\frac{6}{5}T+109 \right)$
We know this is a parabolic yield function, and the axis of symmetry (where the vertex, or maximum) will occur midway between the roots, which are:
$\displaystyle T=0,\,\frac{545}{6}$
And so the axis of symmetry is at:
$\displaystyle T=\frac{545}{12}$
Now, since $T$ represents the number of trees, the variable $T$ is discrete rather than continuous, so we must round to the nearest integer:
$T=45$
This is the number of trees that will maximize the yield of peaches from the orchard.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
